Matt Barrow wrote:
But not, usually, to the pilot, and never to the pilot simply for declaring an emergency. Unless the declared emergency stems from a violation of the FAR's. In that case, the pilot has not simply declared an emergency. The pilot has violated FARs. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
![]() "George Patterson" wrote in message news:EQqIe.14414$2y2.11236@trndny02... Matt Barrow wrote: But not, usually, to the pilot, and never to the pilot simply for declaring an emergency. Unless the declared emergency stems from a violation of the FAR's. In that case, the pilot has not simply declared an emergency. The pilot has violated FARs. So every time a pilot violates the FAR's they must file a report? |
Matt Barrow wrote:
"George Patterson" wrote in message news:EQqIe.14414$2y2.11236@trndny02... Matt Barrow wrote: But not, usually, to the pilot, and never to the pilot simply for declaring an emergency. Unless the declared emergency stems from a violation of the FAR's. In that case, the pilot has not simply declared an emergency. The pilot has violated FARs. So every time a pilot violates the FAR's they must file a report? I can come up with four different scenarios: 1) You clip class D without comms. You violated a FAR, but unless the Administrator (or rep) asks for an incident report, nothing is required. 2) You have a control fail just after takeoff from a towered airport, so (with or without declaring an emergency over the air) you turn back and land without clearance. You violated a FAR, but your emergency authority allows you to to deviate as necessary for the safe completion of the flight. A report is required for the control failure, but not required for the landing. 3) Same scenario as (2) (you have a major oil leak on takeoff and land again without clearance, say), but you were a student pilot and had a passenger. Oops. The emergency let you land without clearance, but you had (unrelated to the emergency) also busted a FAR. Report will probably be requested on just the FAR bust grin. 4) You overloaded your aircraft and/or in flight realized your W&B was so messed up that you had little control, and had to declare an emergency to land as quickly as possible. Ooops again. The FAR bust _caused_ the emergency to begin with. Scenario 4 is the worst case, of course. If breaking a FAR causes the emergency, your emergency powers can't protect you... nor can an ASRS form, if you deliberately overloaded the aircraft. (Let's say the passengers lied to you about their weight... that would mean you didn't deliberately screw up.) Cheers, Kev |
Pilots | Slick | Piloting | 4 | November 20th 04 11:21 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
F15E's trounced by Eurofighters | John Cook | Military Aviation | 193 | April 11th 04 03:33 AM |
Rwy incursions | Hankal | Piloting | 10 | November 16th 03 02:33 AM |
