How common are aircraft partnerships compared to outright ownerships?
Old August 12th 05, 07:31 PM
Oracle
On Tue, 09 Aug 2005 10:09:19 -0500, Gig 601XL Builder wrote:
"Peter R." wrote in message
Newps wrote:
Peter R. wrote:
I have about 450 hours in a C172SP and I would probably need a couple
of hours of instruction/flying just to become familiar with carb heat
usage if
I hypothetically needed to rent an older C172 model.
Pull out the carb heat below the green arc. Push it in aboove the
green arc. There. You're checked out.
Thanks. If it is really that easy, then why are there so many NTSB
accident reports that list carb icing as a contributory cause?
Because there are a lot of folks out there who forget. Many of these are
those that switch between injected and carbureted engines. No amount of
check ride is going to make you remember. That is why we have checklists
and the checklists are different for each aircraft. It's no different
that those that have non mechanical failure gear up landings.
Not to mention some that don't think it's needed because they took off on
a hot day. August issue of AOPA Training has a pretty good write up on
carb heat. Of course, they also address the down side of forgetting to
turn it back off too. Seems there is a large number of accidents steming
from that as well. Long story short, carb heat steals HP and yes, you
really can ice your carb on a 90+ F degree day.
Old August 15th 05, 07:24 PM
Dave Butler
http://www.ez.org/carb_ice.htm
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
