![]() "Darrel Toepfer" wrote in message ... Juan Jimenez wrote: Nope. The Cri-cri is _longer_ than the BD-5J. That's why the BD-5J has held the record for more than 25 years. I think they need to reconsider by using weight and surface area... While you're at it, throw size of the country of the designer into it... sheesh. Knock yourself out. |
On Fri, 12 Aug 2005 14:00:59 -0500, "Montblack"
wrote: ("Darrel Toepfer" wrote) Does the twin-jet Cri-Cri still exist or does someone need to build one to get the Guiness mistake fixed? Light Sport Pilot has the restrictions of no turbines and no twins, however, Part 103 has no such restrictions - but 103 does have the fuel limit of 5 gallons, speed limit of 63 mph and the weight limit of 254 lbs. Safety equipment can be added above and beyond the 254 limit ...like how about another 5 gallons of fuel please - for safety! Hmmmm at 30 GPH per side, (those little engines use a lot of fuel) That's about 5 minutes total . Yah outta be able to make some where around 5,000 to 10,000 feet before flame out. Gas is needed for climb, but optional for landing. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com http://www.ultralighthomepage.com/FAR.part103.html FAR Part 103: Montblack |
Roger wrote:
Hmmmm at 30 GPH per side, (those little engines use a lot of fuel) That's about 5 minutes total . Yah outta be able to make some where around 5,000 to 10,000 feet before flame out. Gas is needed for climb, but optional for landing. Wow, that RC/B52 had 8 of them... Seems excessive, without going back to research it on the manufacters website for a looksee... |
On Fri, 12 Aug 2005 20:51:20 -0500, Darrel Toepfer
wrote: Roger wrote: Hmmmm at 30 GPH per side, (those little engines use a lot of fuel) That's about 5 minutes total . Yah outta be able to make some where around 5,000 to 10,000 feet before flame out. Gas is needed for climb, but optional for landing. Wow, that RC/B52 had 8 of them... Seems excessive, without going back to research it on the manufacters website for a looksee... I didn't see this line back in the thread so here's some shots of the twin engine Kri Kri http://www.amtjets.com/gallery_real_plain.html The larger engine uses 22.5 ounces of fuel per minute, or 1,350 per hour. That at roughly 6# per gallon that is 14 GPH. (The add said they had improved efficiency ) Go to http://www.amtjets.com and select specifications. The fuel consumption is near the bottom of the chart. That works out to be 28 per hour or a whole 10 minutes with 5 gallons on board. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Anyone know of any flying CriCri in the Eastern US?
Thanks, Bryan "The Monk" Chaisone |
![]() Roger wrote: On Fri, 12 Aug 2005 20:51:20 -0500, Darrel Toepfer wrote: Roger wrote: Hmmmm at 30 GPH per side, (those little engines use a lot of fuel) That's about 5 minutes total . Yah outta be able to make some where around 5,000 to 10,000 feet before flame out. Gas is needed for climb, but optional for landing. Wow, that RC/B52 had 8 of them... Seems excessive, without going back to research it on the manufacters website for a looksee... I didn't see this line back in the thread so here's some shots of the twin engine Kri Kri http://www.amtjets.com/gallery_real_plain.html The larger engine uses 22.5 ounces of fuel per minute, or 1,350 per hour. That at roughly 6# per gallon that is 14 GPH. (The add said they had improved efficiency ) Go to http://www.amtjets.com and select specifications. The fuel consumption is near the bottom of the chart. That works out to be 28 per hour or a whole 10 minutes with 5 gallons on board. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com 28 lbs/hour......or am i missing something, but 28 lbs/hour gives you almost a full hour with 2 pound researves.......I also believe those fuel flow figures to be at max thrust.......anyone know |
