Most passenger O2 systems use chemically generated O2.
There are no bottles to check. There are cabin walk around bottles and the flight deck is bottled O2, but passengers are not. Remember the Valujet crash. The initiating event was a cargo bay/cabin fire casued by improperly shipped O2 generators igniting in flight. |
"pbc76049" wrote
Most passenger O2 systems use chemically generated O2. There are no bottles to check. Depends on the age of the B-737. Boeing used pax bottles for a long time. But this is immaterial to the discussion of why the pilots did not have O2. Bob Moore ATP B-707 B-727 PanAm (retired) |
![]() "pbc76049" wrote in message ... Most passenger O2 systems use chemically generated O2. There are no bottles to check. There are cabin walk around bottles and the flight deck is bottled O2, but passengers are not. Remember the Valujet crash. The initiating event was a cargo bay/cabin fire casued by improperly shipped O2 generators igniting in flight. Even if the passengers have chemically generated O2, the pilots have O2 from a bottle. Pilots are required (and most do) check their O2 before take-off. The chemically generated O2 units cannot be turned off once in use and then must be replaced. Therefore pilot positions have bottled O2. Duane |
![]() "Bob Moore" wrote in message My thoughts on yesterday's accident. My thoughts were tending in the same direction, Bob. Speculation on the availability of O2, or the system integrity, is fine, but the first and most obvious question to me was as to why the airplane was still at altitude. Job 1, superceding all others, is to get the craft to breathable air. What was going on? All it takes is one body in the cockpit to initiate the descent. JG |
![]() CO2 is generated by cellular respiration. This is essentially independent of oxygen, as a matter of fact, anaerobic respiration can occur in the absense of adequate oxygen, but it is VERY inefficient, and makes LOTS of waste products. Arterial CO2 concentration, having left the lungs, is around 35-45 torr (mmHg). In mixed venous blood, returning to the lungs, it is around 50 torr/mmhg or so. At sea level, atmospheric CO2 is in the high 20's/low 30's mmhg. The body's buffer system in a healthy individual will RAPIDLY move the CO2 level back towards normal if it vary's too much from those values. So, even at altitude, your venous blood gas values are pretty much normal after one pass around the body. You hold your breath, and this blood with "venous" levels of CO2 will make a second pass, and when it hits the chemo and baro receptors in in your carotid (artery) bodies you will start getting that URGE to breath. All of this is independent of how oxygen is handled by the blood. Each gas's function in the body is more or less independent of each other. Even though your body uses oxygen to make CO2 as a waste product, your body will continue to make CO2 for a short time without adequate oxygen. As an example: the burn in your muscles after a sprint - lactic acid generated along with CO2 when the oxygen requirement of the muscles outstrips the oxygen supply. To say "the lungs stop working" is at best, technically inaccurate. You are just too hypoxic to make the muscles responsible for gas exchange to work properly. Dave |
