In accounts of the crash of the Cypriot airliner in Greece, all I've
read say that loss of cabin pressure could not, by itself, incapacitate the pilot. Yet, I was once told by an ATP that at 40k feet (admittedly this plane was at 35k) O2 supply by itself will not suffice to keep you conscious and that the drop down masks only give a false sense of security. He said that the ambient pressure is so low that even 100% O2 does not provide enough to keep you conscious without a pressure breathing mask. If he's right, that could explain the crash, especially given that all it would take is 20 seconds of distraction (i.e., not donning the mask) to knock out the pilot as indicated in the table below. On the other hand, I checked and a standard atmosphere at 35k feet is 7.0 in of Hg, which is more than the partial pressure of O2 at sea level (6 in = 20% of 30 inches), which would seem to contradict the info given by the ATP. Any thoughts or corrections to my reasoning? Tlme of useful consciousness Altitude (ft) without oxygen 40,000 15 seconds 35.000 20 seconds 30,000 30 seconds 28,000 1 minute 26,000 2 minutes 24,000 3 minutes 22,000 6 minutes 20,000 10 minutes 15.000 Indefinite |
The "partial pressure of O2" has nothing to do with it.
Your premise is wrong. Loss of cabin pressure IS what incapacitates pilots. The lungs need atmospheric pressure to exchange gasses with hemoglobin in the alveoli. It doesn't matter what gas it is - without the pressure, respiration stops happening. As altitude increases and pressure decreases, respiration becomes less effective. Below a certain pressure, you can suffocate on 100% oxygen. |
"Bucky" wrote in message
oups.com... I don't get it. Can't a person stay conscious for longer than 30 seconds without breathing? Most people can hold their breath for over a minute. When they do that, they are using up a small reserve of oxygen-filled air contained in their lungs. Exhale as much air from your lungs as you can, and THEN see how long you can hold your breath. |
Peter Duniho wrote:
When they do that, they are using up a small reserve of oxygen-filled air contained in their lungs. Exhale as much air from your lungs as you can, and THEN see how long you can hold your breath. Even then, there's still a lot of oxygen in the lungs, the human lung is pretty inefficient. What happens at altitude is that you don't feel the absence of oxygen, hence just continue to breath normally. This empties your oxygen reserves rather quickly. On airliners, though, there are instruments which alarm the pilot of pressure loss and drop the mask immediately. So there must have been another problem. Stefan |
"Bucky" wrote in message oups.com... I don't get it. Can't a person stay conscious for longer than 30 seconds without breathing? Most people can hold their breath for over a minute. When they do that, they are using up a small reserve of oxygen-filled air contained in their lungs. Exhale as much air from your lungs as you can, and THEN see how long you can hold your breath. Partially crap. Learn how lungs work. moo |
"Bruce Hoult" wrote in message news:bruce-566936.
wrote: In accounts of the crash of the Cypriot airliner in Greece, all I've read say that loss of cabin pressure could not, by itself, incapacitate the pilot. Yet, I was once told by an ATP that at 40k feet (admittedly this plane was at 35k) O2 supply by itself will not suffice to keep you conscious and that the drop down masks only give a false sense of security. He said that the ambient pressure is so low that even 100% O2 does not provide enough to keep you conscious without a pressure breathing mask. I personally know glider pilots here in New Zealand who have flown to betweeen 35,000 and 37,000 ft with only an ordinary oxygen mask, not a pressure system. It's OK at 34,000 ft and above 38,000 ft. And all other altitudes, partialy. You were asleep or missed this class, right? moo |
Brien K. Meehan opined
The "partial pressure of O2" has nothing to do with it. Your premise is wrong. Loss of cabin pressure IS what incapacitates pilots. The lungs need atmospheric pressure to exchange gasses with hemoglobin in the alveoli. It doesn't matter what gas it is - without the pressure, respiration stops happening. As altitude increases and pressure decreases, respiration becomes less effective. Below a certain pressure, you can suffocate on 100% oxygen. Seems to me that astronauts use 3psi of pure O2 during EVAs. -ash Cthulhu in 2005! Why wait for nature? |
Tlme of useful
consciousness Altitude (ft) without oxygen 40,000 15 seconds 35.000 20 seconds 30,000 30 seconds 28,000 1 minute How, then, can someone like Ed Viesturs repeatedly climb the tallest mountain peaks in the world without supplemental oxygen? Is it because of the slower ascent and the time spent acclimating to the higher altitudes? John K. |
| Thread Tools | |
| Display Modes | |
| O2 and Cypriot airliner crash | [email protected] | Piloting | 68 | August 25th 05 01:07 PM |
