I was reading 91.211.
Bob wrote in message ... Bob Gardner wrote: Based on my experience in a USAF altitude chamber, after the chamber has been pumped up (actually down...it is a vacuum) to 25000 feet and the pressure suddenly dumped as would be the case in a decompression, whatever air you have in your lungs comes out forcefully...no way do you have any control over it. Gotta get that mask on and get it on in a hurry, because time is fleetingly short. In US regulations, the magic altitude is flight level 350 (more or less 35000 feet, depending on ambient atmospheric pressure). The Cypriot plane was reportedly at FL 340, if we can believe the media. Under US rules, above FL 350 both pilots must be at the controls and each must have a quick-donning mask at hand. If one pilot has to leave the cockpit for any reason, the other has to put on and use oxygen until he returns. It's FL 250 (121.333 I believe). Above 250 one crewmember must be on O2 when the other leaves the flight deck. As to decompression of an aircraft the size of the 737, there is rapid decompression and explosive decompression. It the packs both trip off or a window blows out it results in rapid decompression, which is quite different than an altitude chamber experience. The cabin ascends at perhaps 10,000 feet per minute. But, if there is some type of structural failure resulting in a whole larger than a window, then the cabin can explosively decompress, similar to your experience in the altitude chamber. |
I wasn't aware that the feds relaxed such a critical safety standard for a
non-commercial turbine aircraft. If anything, because of the smaller pressure vessel, the rule should be more restrictive than the commercial rule. Dead is dead ala Payne Stewart. Bob Gardner wrote: I was reading 91.211. Bob wrote in message ... Bob Gardner wrote: Based on my experience in a USAF altitude chamber, after the chamber has been pumped up (actually down...it is a vacuum) to 25000 feet and the pressure suddenly dumped as would be the case in a decompression, whatever air you have in your lungs comes out forcefully...no way do you have any control over it. Gotta get that mask on and get it on in a hurry, because time is fleetingly short. In US regulations, the magic altitude is flight level 350 (more or less 35000 feet, depending on ambient atmospheric pressure). The Cypriot plane was reportedly at FL 340, if we can believe the media. Under US rules, above FL 350 both pilots must be at the controls and each must have a quick-donning mask at hand. If one pilot has to leave the cockpit for any reason, the other has to put on and use oxygen until he returns. It's FL 250 (121.333 I believe). Above 250 one crewmember must be on O2 when the other leaves the flight deck. As to decompression of an aircraft the size of the 737, there is rapid decompression and explosive decompression. It the packs both trip off or a window blows out it results in rapid decompression, which is quite different than an altitude chamber experience. The cabin ascends at perhaps 10,000 feet per minute. But, if there is some type of structural failure resulting in a whole larger than a window, then the cabin can explosively decompress, similar to your experience in the altitude chamber. |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 07:28 PM |
High Flight NOTAM | Kirk Stant | Military Aviation | 1 | September 10th 03 03:31 AM |
