mhorowit wrote:
What about all the scratches made by clamping it in the vice and using an abrasive to clean before welding? arn't those sources of 'stress risers'? - Mike You don't need to clean back any further than you will be welding. 'Scratches' should be melted away. Use a slightly worn out abrasive pad (sand paper on foam), or 120 or greater grit paper. It will give you a mirror finish. A 'scratch' has to be a significant depth into the parent material to be of consequence. 'Significant' in this case is a weasel word without definite meaning. The precise depth is different for various materials. Consult 43.13B for specific details. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
4130 is not notch sensitive like Plexiglas or aluminum. The occasion light
scratch will not cause any problem. "Ernest Christley" wrote in message ... mhorowit wrote: What about all the scratches made by clamping it in the vice and using an abrasive to clean before welding? arn't those sources of 'stress risers'? - Mike You don't need to clean back any further than you will be welding. 'Scratches' should be melted away. Use a slightly worn out abrasive pad (sand paper on foam), or 120 or greater grit paper. It will give you a mirror finish. A 'scratch' has to be a significant depth into the parent material to be of consequence. 'Significant' in this case is a weasel word without definite meaning. The precise depth is different for various materials. Consult 43.13B for specific details. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
