So, you're ok over the Sierras without the motor running?
On 2005-08-19, Michael wrote:
Are your gauges accurate enough to reliably tell the difference between 30 minutes fuel at 60% power and empty in tyubulent air? Will your fuel computer account for fuel that leaves via a cap that has developed a leak? I think this is why it is important to have fuel gauges that are at least useful, and give a reasonable indication of how much fuel is left - so you can tell if there's less fuel in the tank than you expected there to be. It can alert you to a problem. The first time I took a Cessna 182 (the 1960 model, which didn't have overly capacious fuel tanks to start with) for a long cross country, I landed short of my destination because the fuel gauges showed that I had less fuel than my time/fuel burn calculation said I had. The fuel gauge was right - I did have less fuel than I expected. Reasonably working fuel gauges can alert you to fuel leaks, missing fuel caps and other sources of having less fuel than you expected to have. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
"Robert M. Gary" writes:
Flying over the Sierras, dodging TS's is exciting enough, Yeah, been there, didn't enjoy it. I don't need to turn off the fan to add more excitment to my life. We seem to have diverging groups. Some of us see running a tank (nearly) dry as a non-event. Others see it as "turn[ing] off the fan". I've seen a few references to the *possibility* that some planes will actually lose power for more than an instant if the tank is run down. Are any of us who run the tanks "dry" actually experiencing this? I suspect that the reason most of us who do this don't get so excited about it is because it is such a non-event. Is that plane-specific? (I've had it take a long time to figure out which tank just went dry when an engine started surging. It wakes me up but it's sure not so exciting that I'd avoid the practice.) --kyler |
On 19 Aug 2005 10:48:45 -0700, "Robert M. Gary"
wrote: Too many of you have been reading "The Cheap *******'s Pilot's Guide". I have good working gauges and a fuel computer that has been professionally calibrated and verified at each 100 hour inspection. I don't need to make the wife want to leave me in order to know how much fuel I have. Flying over the Sierras, dodging TS's is exciting enough, I don't need to turn off the fan to add more excitment to my life. What happens if a tank develops a leak? We had a Comanche go down a few years ago due to running out of fuel. He took off with full fuel and at that point should have had near half left. The verdict? Mice had chewed holes in the bladders. When he fueled up the pressure kept the bladders sealed against the metal so no leaks were apparent, but once in the air the turbulence kept him bouncing enough that the tanks lost a lot of fuel. He knew how much he burned, but the gauges were bouncing too, or at least until they were near empty. He was doing really well on that paved mountain road until he found that mail box sent on a steel pipe full of concrete. No injuries except for the airplane and with a new wing it's been back flying for some time. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Engine running again, the good, bad and ugly | Corky Scott | Home Built | 34 | July 6th 05 05:04 PM |
It's finally running! | Corky Scott | Home Built | 19 | April 29th 05 04:53 PM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
