![]() "Mike Rapoport" wrote in message k.net... "John Doe" wrote in message news ![]() "Mike Rapoport" wrote in message ink.net... My first airplane was a 79 Turbo Lance. I bought it for the roomy cabin for my dogs, reasonably fast cruise and fairly good altitude capibility. It was a releative bargin compared to other six place, 170+kt, turbo airplanes. I found it to be a good airplane for me and it met my expectations. Mine had most of the availible speed mods and an intercooler which I recommend. I only had if for about 16 months so I can't tell you what the long term cost of ownership would be. Mike MU-2 I must admit that I'm not very smart on the turbo options. This would be my first turbo engine. I've seen some Lance's advertised with Turbo and then there are some that specifically advertise Turbo with Intercooler. Are these two seperate options available or are they one in the same? The Lance I'm looking at just says Turbo in the ad and doesn't mention any intercooler. Thanks. The intercooler is a aftermarket STC'd modification. Without it, the airplane will not be able to maintain high power settings above about 16,000' without overheating. Does the intercooler require any maintenance ? I checked on it and it appears that the company that was making the intercooler option has gone out of business. |
![]() "John Doe" wrote in message news:lIQQe.2865$8q.1555@lakeread01... "Mike Rapoport" wrote in message k.net... "John Doe" wrote in message news ![]() "Mike Rapoport" wrote in message ink.net... My first airplane was a 79 Turbo Lance. I bought it for the roomy cabin for my dogs, reasonably fast cruise and fairly good altitude capibility. It was a releative bargin compared to other six place, 170+kt, turbo airplanes. I found it to be a good airplane for me and it met my expectations. Mine had most of the availible speed mods and an intercooler which I recommend. I only had if for about 16 months so I can't tell you what the long term cost of ownership would be. Mike MU-2 I must admit that I'm not very smart on the turbo options. This would be my first turbo engine. I've seen some Lance's advertised with Turbo and then there are some that specifically advertise Turbo with Intercooler. Are these two seperate options available or are they one in the same? The Lance I'm looking at just says Turbo in the ad and doesn't mention any intercooler. Thanks. The intercooler is a aftermarket STC'd modification. Without it, the airplane will not be able to maintain high power settings above about 16,000' without overheating. Does the intercooler require any maintenance ? I checked on it and it appears that the company that was making the intercooler option has gone out of business. No, an intercooler is just a heat exchanger. Mike MU-2 |
Hello,
I'm looking to talk with someone who's owned a Turbo Lance for their opinions on ownership and maintenance. Thanks. I used to fly one for a small company. It's a good airplane overall, lots of room and payload. When this company was looking for an airplane, they asked me to research the Turbo Lance II, specifically a 1979 they were looking at and eventually purchased. I discovered from an analysis of accidents in the NTSB database that this model has had a number of smoke in the cockpit and/or fire in the engine compartment events due to the turbocharger. IIRC, one of the events occurred even though an AD specifically designed to stop this kind of thing was incorrectly done, and some of the fault was laid on the AD itself for being difficult and confusing. While I've since lost the data, somebody posted a question about this make / model in this newsgroup or R.A.P a few years ago and I responded to it (not under this username) by posting my summary of what I learned about the plane. You can probably find it in google / dejanews. Engine temp control is important and you ought to have an all cylinder engine monitor on it like a JPI. Get the cowling mod because it provides a little speed increase and more importantly improves cylinder cooling. |
Wasn't there a change in the exhaust system to iconel that fixed the
problem? Mike MU-2 "Vertical Rate" wrote in message .. . Hello, I'm looking to talk with someone who's owned a Turbo Lance for their opinions on ownership and maintenance. Thanks. I used to fly one for a small company. It's a good airplane overall, lots of room and payload. When this company was looking for an airplane, they asked me to research the Turbo Lance II, specifically a 1979 they were looking at and eventually purchased. I discovered from an analysis of accidents in the NTSB database that this model has had a number of smoke in the cockpit and/or fire in the engine compartment events due to the turbocharger. IIRC, one of the events occurred even though an AD specifically designed to stop this kind of thing was incorrectly done, and some of the fault was laid on the AD itself for being difficult and confusing. While I've since lost the data, somebody posted a question about this make / model in this newsgroup or R.A.P a few years ago and I responded to it (not under this username) by posting my summary of what I learned about the plane. You can probably find it in google / dejanews. Engine temp control is important and you ought to have an all cylinder engine monitor on it like a JPI. Get the cowling mod because it provides a little speed increase and more importantly improves cylinder cooling. |
I found some readings that said the Turbo Lance has a fixed wastegate and
that there are other systems out there that have a manual wastegate that allows the pilot to better control the turbo. How much of this is really a factor and should I really care? |
You could interpret a manual wastegate as something that you have more
control over or you could say that it just provides more workload :-). The Turbo Lance wastegate is attacked to the throttle linkage and works pretty well. The best system is a compensated automatic wastegate but that is considerably more expensive and complex. Mike MU-2 "John Doe" wrote in message news:R5nOe.17574$Co1.9024@lakeread01... I found some readings that said the Turbo Lance has a fixed wastegate and that there are other systems out there that have a manual wastegate that allows the pilot to better control the turbo. How much of this is really a factor and should I really care? |
On Mon, 22 Aug 2005 16:44:12 +0000, Mike Rapoport wrote:
You could interpret a manual wastegate as something that you have more control over or you could say that it just provides more workload :-). The Turbo Lance wastegate is attacked to the throttle linkage and works pretty well. The best system is a compensated automatic wastegate but that is considerably more expensive and complex. Mike MU-2 "John Doe" wrote in message news:R5nOe.17574$Co1.9024@lakeread01... I found some readings that said the Turbo Lance has a fixed wastegate and that there are other systems out there that have a manual wastegate that allows the pilot to better control the turbo. How much of this is really a factor and should I really care? On cars, the waste gate is basically a variable rate spring inside a metered valve. As the pressure increases, the valve opens...as it decreases, the valve closes. The valve releases excessive pressure within the turbo, thusly preventing overboost. On cars, they are simplistic. I'm not sure how much is different between a waste gate on a car and a waste gate on a plane. Having said all that, I'm 100% sure I would not own a turbocharged anything that did not have an automatic wastegate on it. Greg |
![]() "Oracle" wrote in message news ![]() On Mon, 22 Aug 2005 16:44:12 +0000, Mike Rapoport wrote: You could interpret a manual wastegate as something that you have more control over or you could say that it just provides more workload :-). The Turbo Lance wastegate is attacked to the throttle linkage and works pretty well. The best system is a compensated automatic wastegate but that is considerably more expensive and complex. Mike MU-2 "John Doe" wrote in message news:R5nOe.17574$Co1.9024@lakeread01... I found some readings that said the Turbo Lance has a fixed wastegate and that there are other systems out there that have a manual wastegate that allows the pilot to better control the turbo. How much of this is really a factor and should I really care? On cars, the waste gate is basically a variable rate spring inside a metered valve. As the pressure increases, the valve opens...as it decreases, the valve closes. The valve releases excessive pressure within the turbo, thusly preventing overboost. On cars, they are simplistic. I'm not sure how much is different between a waste gate on a car and a waste gate on a plane. Having said all that, I'm 100% sure I would not own a turbocharged anything that did not have an automatic wastegate on it. Greg The difference is that the airplane wastegate should compensate for different altitudes. Mike MU-2 |
You could interpret a manual wastegate as something that you have more control over or you could say that it just provides more workload :-). The Turbo Lance wastegate is attacked to the throttle linkage and works pretty well. The best system is a compensated automatic wastegate but that is considerably more expensive and complex. As should also add, I would imagine that a turbo-normalized engine has a much more complex wastegate. That's obviously a guess on my part. Greg |
John Doe wrote:
I found some readings that said the Turbo Lance has a fixed wastegate and that there are other systems out there that have a manual wastegate that allows the pilot to better control the turbo. How much of this is really a factor and should I really care? For my money, I'd care. There is a series of 6 articles on turbocharging by John Deakin at avweb.com. Here's a link to the index of John's Pelican Perch articles: http://www.avweb.com/news/columns/182146-1.html Scan down the list to the "Those Fire-Breathing Turbos" articles. Dave |
Why turbo normalizer? | Robert M. Gary | Piloting | 61 | May 20th 05 04:33 PM |
Turbo prop AT-6/SNJ? | frank may | Military Aviation | 11 | September 5th 04 02:51 PM |
Opinions on Cessna 340, 414 and 421 | john szpara | Owning | 55 | April 2nd 04 09:08 PM |
OPINIONS: THE SOLUTION | ArtKramr | Military Aviation | 4 | January 7th 04 10:43 PM |
Piper Lance | Renee Purner | Owning | 22 | November 4th 03 07:47 PM |
