Running dry?
Old August 22nd 05, 01:46 PM
Dylan Smith
On 2005-08-22, Jay Honeck wrote:
1. Refuel after every flight. You will be ready to go for your next flight,
and can rest assured that you have gas on board. (Renters will have to
switch this to refueling BEFORE every flight.)
Again, this is not a hard and fast rule. It is NOT stupidity to NOT do
this, and often it's necessary. Indeed, airlines routinely fly without
full tanks.
I'm making an assumption here - by refuelling, you mean top the tanks. I
apologise if this isn't what you really mean, but let's assume that you
(or the generic 'you') do mean that. It probably works well for you with
your aircraft and your typical mission. But consider this.
I did my multi training in a Piper Apache (Geronimo conversion) which
carried rather a lot of fuel. Seven hours of fuel in fact. 7 hours of
fuel weighs quite a bit, even at the fuel burn of a Piper Apache. The
plane has 5 seats. I need to be able to trade off fuel for payload in
case a bunch of us are going somewhere. 7 hours of fuel and 5 filled
seats = way over gross, which in a Piper Apache means you are not going
anywhere other than down should one of the donkeys decides to take the
day off. To fly with half fuel to go to an airport an hour away is
NOT bad decision making - it is called trading off range for payload,
and as I said, it's common practise with the airlines.
Really, the same goes for taking 4 people in a Cessna 172 or a Warrior -
you're going to have to trade off fuel for payload. I don't consider it
"stupid" to carry only 2.5 hours of fuel to take three friends on a 30
minute sightseeing trip around the local area.
About 2 weeks ago, I was flying with my friend Paul in his Cessna 180.
We were departing from an 860 foot long back country airstrip with a
field elevation of 4200 feet. If the airfield sold fuel (it doesn't), it
would have been foolish in the extreme to top the tanks before departing
this airfield. (Of course, some people may argue it's foolish in the
extreme to use that airstrip at all, but IMHO the rewards exceeded the
risks).
My old Cessna 140. I've flown it up in the mountains. Flying with half
fuel was a given. With 85 horsepower you need all the help you can get
at high elevations.
Towing the gliders at Andreas. Taking a full tank of fuel in the Auster
simply prolongs the climb and means you have to run the engine at full
power (where it gets hot because the installation doesn't exactly have
the best cooling in the world). Much better to avoid flying with more
than half tanks.
If your normal mission and your aircraft allows it, by all means top off
after every flight. However, it is not stupid or wrong NOT to top off
after every flight - especially if you don't know what your next flight
will be and you fly a plane where you can usefully trade range for
something else (rate of climb or non-fuel payload). The main thing is to
use your brain when deciding how much fuel to carry.
4. Measure your gas with your watch, never your fuel gauges.
No. Measure your gas with your watch AND KEEP THE FUEL GAUGES IN YOUR
CROSS CHECK. If the fuel gauges indicate less fuel than you expect to
have at the given stage of the flight, land and check it out. Do NOT
ignore your fuel gauges. If you own the plane, it behooves you to make
sure your fuel gauges are at least useful enough so that you can detect
the situation where you have less fuel than you calculated. If you rent,
get to know the planes you fly and know how useful the fuel gauges are
for cross-checking.
Working fuel gauges provide a useful cross check. In most things in
aviation - you should avoid relying on a single source of data and at
least have a cross check. For your watch and fuel calculations, cross
check with the gauges. For your GPS, cross check by using VOR and
pilotage. There's lots of emphasis on cross checks when flying IFR. It's
not just IFR that benefits from cross checking - pretty much anything is
less likely to land you with an unpleasant surprise if you can perform a
cross check.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old August 22nd 05, 04:18 PM
James Ricks
Here's an easy way to make sure you never run out of gas
Have a 4-hour bladder and 5 hours of fuel.
Jim Ricks
2. Install a fuel totalizer. They are cheap (in aviation money), and will
tell you your fuel usage to within a few ounces. (Sorry, renters. Get on
the FBO to install one.)
3. Never try to stretch your range. Bite the bullet, land and buy gas.
Old August 22nd 05, 09:23 PM
RST Engineering
And saying something as misinformed as this is worse yet. 99.9% of the
"crap" is heavier than fuel, and sinks, so it is the FIRST thing out of the
tanks, not the last. The 0.1% that is still left floating is eventually
going to be visible in the filler neck.
Get a life, not a totalizer.
"Jay Honeck" wrote in message
news:4Z9Oe.272046$_o.92006@attbi_s71...
Running a tank dry probably won't lead to anything worse than sucking all
the crap out of your gas tanks -- but you're missing my point.
Old August 22nd 05, 10:23 PM
Mark T. Dame
Are those the little gauges on either side of the fuel pressure gauge
with needles that move from right to left as you as you fly? I thought
those measured how tired the plane was: make sure you land before they
all reach zero or the plane will take a nap.
I trust my fuel gauges like I trust the IRS to help me with my taxes.
They'll tell me when I'm in deep doo-doo, but they won't keep me from
getting there.
-m
## Mark T. Dame
## VP, Product Development
## MFM Software, Inc. (http://www.mfm.com/)
"Madness has no purpose. Or reason. But it may have a goal."
-- Star Trek: Spock, "The Alternative Factor"
Old August 22nd 05, 10:33 PM
Gig 601XL Builder
"Mark T. Dame" wrote in message
getting there.
Luv it! Can I quote you on that?
Old August 23rd 05, 04:46 AM
Jay Honeck
getting there.
Most excellent. Me, too?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 23rd 05, 02:58 PM
Mark T. Dame
getting there.
Quote away. That and $5.00 will get you a coffee at Starbucks. (-:
-m
## Mark T. Dame
"All your base are belong us!!"
Old August 23rd 05, 08:14 PM
Brian
Hi Jay
You missed #5 and #6
#5. check the fuel level before every flight. with a little research I
bet I could find the NTSB report where the Arrow crashed on its 2nd
time around the pattern after being refueled the night before. NTSB
report doesn't say, but sounds like fuel was stolen or leaked out
overnight.
#6 Drain excess fuel becuase you have been reading the Do you fly over
Gross Thread.
Just a quick note. I agree that running tanks dry on a regular basis is
a very bad idea. However I think running tank dry under controlled
conditions can be very educational and safe. BTW. That is all that John
D was proposing in his artical as well.
You would be surprised at how many students have been taught to
simulate trying the starter after an engine failure and how many don't
switch fuel tanks at the 1st sign of an engine failure.
Brian
CFIIG/ASEL
Old August 24th 05, 12:49 AM
Jose
I had a tank run dry unexpectedly on me; I've never seen myself hit the
mixture, carb heat, fuel selector, fuel pump, and have my hand on the
mags so fast! It was =way= different from the simulations my CFI pulled.
Jose
Quantum Mechanics is like this: God =does= play dice with the universe,
except there's no God, and there's no dice. And maybe there's no universe.
Old August 24th 05, 10:23 PM
Jay Honeck
mixture, carb heat, fuel selector, fuel pump, and have my hand on the mags
Same here. I didn't think it was possible to change tanks as fast as I
did -- but a little adrenaline goes a long way!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Engine running again, the good, bad and ugly Corky Scott Home Built 34 July 6th 05 05:04 PM
It's finally running! Corky Scott Home Built 19 April 29th 05 04:53 PM
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 04:56 PM
Leaving all engines running at the gate John Piloting 12 February 5th 04 03:46 AM
