Metric Instruments
Old August 24th 05, 11:08 PM
Paul Remde
Hi,
Winter instruments are available with either 6 O'clock or 12 O'clock zero
for airspeed indicators and altimeters. 12 O'clock is standard.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
"Stig Oye" wrote in message
No. I believe that it is an old German standard, but if you buy
PZL instruments you can specify it to either top or bottom.
http://www.pzl.com.pl/en/produkty/os...e/pw-12-a.html
BTW, these instruments are very high quality but somewhat heavy.
Highly recommended.
Regards Stig Oye
In article , Roy Bourgeois
says:
This may be a silly question - but are all metric altimeters
configured with 'Zero at 6 O'clock' as I saw in France?
I did not have trouble converting to meters/kilometers
but I did have trouble quickly reading the altimeter
with the zero at the bottom of the instrument face
(especially on the little 57mm instruments). Just
curious.
Roy
Old May 27th 13, 08:18 AM posted to rec.aviation.soaring
Default Metric Instruments
curious.
Roy
http://www.rlkswitches.com/
Old May 27th 13, 01:53 PM posted to rec.aviation.soaring
Paul Remde
Hi Roy,
That is very common. It is the standard. I suppose it is similar to most
industrial gauges which have the zero at the bottom.
Best Regards,
Paul Remde
__________________________________________
curious.
Roy
Metric measuring tool source? DL152279546231 Home Built 12 April 29th 04 02:13 AM
Reverse Vacuum Damging to Instruments? O. Sami Saydjari Owning 8 February 16th 04 04:00 AM
metric system newsgroup call for votes #1 Paul Hirose Military Aviation 72 November 16th 03 06:59 PM
Edwards air show B-1 speed record attempt Paul Hirose Military Aviation 146 November 3rd 03 05:18 PM
Wanted - Metric Altimeters RHWOODY Soaring 0 September 13th 03 10:20 PM
