On Thu, 25 Aug 2005 09:43:46 +0200, "Bert Willing"
wrote: Well, even if there is only one owner involved, I'm not going to rely on electrically power instruments only. Never.^ I still remember one competition back in 1991 when the US shut down GPS and suddenly a gaggle of 30 standard class gliders lost their navigation in the vicinity of Sobernheim (several airbases and restricted airspace there). I got to know a new definition of the term "confusion". Bye Andreas |
Whatever technology is behind the panel (analog or digital), the human
interface for instruments where trends and relative magnitude are important then the "analog style" gauge is far superior to a digital readout. It is easily discerned for ballpark, trends up or down, and actual value rather precisely. So for airspeed indicators, varios, and the like, the "analog style" interface is the way to go. For battery voltage levels, radio frequencies, etc. where precision is more important than trends or "ballpark" then a digital readout is just the ticket. Regards, Larry "Bill Daniels" wrote in message : Does it strike some of the digerati here that expensive mechanical altimeters with easily mis-read clock-like hands locked into either the metric or US measurement systems are archaic? GPS provides highly accurate, although not ATC compliant, altitude. Various vendors provide electronic pressure altimeters with digital displays that can be switched between meters and feet with the push of a button. Digital pressure altitude sensors drive the "glass cockpits" of new GA aircraft. I seems to me that clock-like altimeters designed 70 years ago and maintained by watchmakers must be nearing their well-deserved retirement. Bill Daniels "Bert Willing" wrote in message ... Yes, they are. -- Bert Willing ASW20 "TW" "Roy Bourgeois" a écrit dans le message de news: ... This may be a silly question - but are all metric altimeters configured with 'Zero at 6 O'clock' as I saw in France? I did not have trouble converting to meters/kilometers but I did have trouble quickly reading the altimeter with the zero at the bottom of the instrument face (especially on the little 57mm instruments). Just curious. Roy |
Bill Daniels wrote:
snip GPS provides highly accurate, although not ATC compliant, altitude. I am afraid that the claim that GPS altitude is recorded "highly accurately" in IGC files from IGC-approved GPS recorders, is unfortunately not true. The second part of the statment above IS true, that the GPS altitude datum is not the same as the pressure altitude datum used worldwide in aviation for altimeter settings for aircraft separation and for controlled and restricted airspace. In theory, due to the angle of cut of the lines-of-position from the satellites, GPS altitude errors should be, on average, about 1.8 times those for horizontal position or lat/long. Measurements over many years by the IGC GNSS Flight Recorder Approval Committee (GFAC) show an average lat/long error of 11.4 metres, taken from a moving vehicle at surveyed points at about 51N 001W (Southern England, near Lasham Gliding Centre). Going on this, an average GPS altitude error could be expected as about 20.5 metres. However, in a significant proportion of IGC-format flight data files, there are significant anomalies in the GPS altitude figures that have been recorded, in excess of the 20 metres mentioned above. Only today I was commenting in another email on aspects of an IGC file from a recent glider flight in the USA that had a 1500 foot overshoot in GPS altitude (compared to the much more reliably recorded pressure altitude) for reasons unknown. The problem seems to be, particularly in low-cost GPS boards, that, rather than processing a fix in three dimensions, it is processed separately as lat/long and then separately as altitude. The algorithms for lat/long and for altitude appear to be different, hence the regular occurrence in IGC files or GPS altitude anomalies despite few lat/long anomalies. Naturally, more attention seems to be paid by GPS board manufacturers to lat/long rather than altitude. In a survey made in year 2000 after the deliberate Selective Availability error was removed from the GPS system by Presidential Decree, no less than 27% of over 400 IGC flight data files analysed from 7 countries in both hemispheres, had anomaliesof one sort or another in the GPS altitude recorded in the file. From IGC files that I have seen since, there is no reason to believe that this proportion is much improved today. Just look at a large selection of IGC-format flight data files and see for yourselves. In my database, I have literally hundreds of IGC flight data files that show major anomalies in recorded GPS altitude data. Fortunately, anomalies in lat/long data in the same IGC files are very rare. This is not an attack on the accuracy of the GPS system or even its altitude recording capability. It is a reporting of results of GPS altitude recording in IGC flight data files derived from a number of low-cost GPS boards made by a number of different companies from different parts of the world. I guess that in more expensive "professional aviation standard" GPS boards, and in differential-GPS systems with local beacons, the GPS altitude figures are more accurate and with less anomalies. But such (expensive) systems do not apply to the current 27 types of GNSS flight recorders that are IGC-approved (from 11 manufacturers) and whose IGC-approval documents appear on the IGC gliding/gnss web site: http://www.fai.org/gliding/gnss/igc_approved_frs.pdf Ian Strachan Chairman IGC GNSS Flight Recorder Approval Committee |
By my checking, WAAS enabled, dual antenna DGPS receiver boards are cheap -
on the order of $10US in OEM quantities. The specs say 1 meter RMS in Lat Long and 6 meters RMS in altitude when a DGPS signal is available. Of course, they probably aren't in approved loggers. 6 meters in altitude is a lot better than a barometric altimeter on a non-standard atmospheric day. I wouldn't want to change ATC's reliance on barometric altimeters. On a hot day, they understate the real altitude, giving us western US guys another 1000 or so feet to play in below the floor of Class A airspace. I checked GPS altitude a couple of times by putting a hand held Garmin GPS on a prime US Geodetic Survey marker. The marker said 10,346 feet. The GPS said 10,350 feet + or - 70 feet. The + or - error estimate seemed pretty pessimistic. Those are pretty typical numbers. Bill Daniels "Ian Strachan" wrote in message ups.com... Bill Daniels wrote: snip GPS provides highly accurate, although not ATC compliant, altitude. I am afraid that the claim that GPS altitude is recorded "highly accurately" in IGC files from IGC-approved GPS recorders, is unfortunately not true. The second part of the statment above IS true, that the GPS altitude datum is not the same as the pressure altitude datum used worldwide in aviation for altimeter settings for aircraft separation and for controlled and restricted airspace. In theory, due to the angle of cut of the lines-of-position from the satellites, GPS altitude errors should be, on average, about 1.8 times those for horizontal position or lat/long. Measurements over many years by the IGC GNSS Flight Recorder Approval Committee (GFAC) show an average lat/long error of 11.4 metres, taken from a moving vehicle at surveyed points at about 51N 001W (Southern England, near Lasham Gliding Centre). Going on this, an average GPS altitude error could be expected as about 20.5 metres. However, in a significant proportion of IGC-format flight data files, there are significant anomalies in the GPS altitude figures that have been recorded, in excess of the 20 metres mentioned above. Only today I was commenting in another email on aspects of an IGC file from a recent glider flight in the USA that had a 1500 foot overshoot in GPS altitude (compared to the much more reliably recorded pressure altitude) for reasons unknown. The problem seems to be, particularly in low-cost GPS boards, that, rather than processing a fix in three dimensions, it is processed separately as lat/long and then separately as altitude. The algorithms for lat/long and for altitude appear to be different, hence the regular occurrence in IGC files or GPS altitude anomalies despite few lat/long anomalies. Naturally, more attention seems to be paid by GPS board manufacturers to lat/long rather than altitude. In a survey made in year 2000 after the deliberate Selective Availability error was removed from the GPS system by Presidential Decree, no less than 27% of over 400 IGC flight data files analysed from 7 countries in both hemispheres, had anomaliesof one sort or another in the GPS altitude recorded in the file. From IGC files that I have seen since, there is no reason to believe that this proportion is much improved today. Just look at a large selection of IGC-format flight data files and see for yourselves. In my database, I have literally hundreds of IGC flight data files that show major anomalies in recorded GPS altitude data. Fortunately, anomalies in lat/long data in the same IGC files are very rare. This is not an attack on the accuracy of the GPS system or even its altitude recording capability. It is a reporting of results of GPS altitude recording in IGC flight data files derived from a number of low-cost GPS boards made by a number of different companies from different parts of the world. I guess that in more expensive "professional aviation standard" GPS boards, and in differential-GPS systems with local beacons, the GPS altitude figures are more accurate and with less anomalies. But such (expensive) systems do not apply to the current 27 types of GNSS flight recorders that are IGC-approved (from 11 manufacturers) and whose IGC-approval documents appear on the IGC gliding/gnss web site: http://www.fai.org/gliding/gnss/igc_approved_frs.pdf Ian Strachan Chairman IGC GNSS Flight Recorder Approval Committee |
Bill Daniels wrote:
Does it strike some of the digerati here that expensive mechanical altimeters with easily mis-read clock-like hands locked into either the metric or US measurement systems are archaic? I have both a mechanical and digital altimeter. When i want to check my altitude, I tend to rely on the mechanical. Like a watch with hands, I don'd read it as much as glance at it and I find that easier. YMMV. Tony V. |
![]() "Bill Daniels" wrote in message ... Does it strike some of the digerati here that expensive mechanical altimeters with easily mis-read clock-like hands locked into either the metric or US measurement systems are archaic? GPS provides highly accurate, although not ATC compliant, altitude. Various vendors provide electronic pressure altimeters with digital displays that can be switched between meters and feet with the push of a button. Digital pressure altitude sensors drive the "glass cockpits" of new GA aircraft. I seems to me that clock-like altimeters designed 70 years ago and maintained by watchmakers must be nearing their well-deserved retirement. Bill Daniels Yeah, now if they can just make them so they don't need batteries. Tim Ward |
![]() "Tim Ward" wrote in message ink.net... "Bill Daniels" wrote in message ... Does it strike some of the digerati here that expensive mechanical altimeters with easily mis-read clock-like hands locked into either the metric or US measurement systems are archaic? GPS provides highly accurate, although not ATC compliant, altitude. Various vendors provide electronic pressure altimeters with digital displays that can be switched between meters and feet with the push of a button. Digital pressure altitude sensors drive the "glass cockpits" of new GA aircraft. I seems to me that clock-like altimeters designed 70 years ago and maintained by watchmakers must be nearing their well-deserved retirement. Bill Daniels Yeah, now if they can just make them so they don't need batteries. Tim Ward What's the big deal with batteries? IMHO, batteries are at worst a minor inconvenience easily worth enduring for the benefits of the technology they make possible. Every portable gadget uses them. Most folks have a cell phone, PDA, portable GPS, digital camera, maybe a camcorder and who knows what else. Even your car, tug or winch won't start without a battery. They're cheap and they work fine with a little TLC and regular replacement. My glider uses a standard 7.5 AH 12V SLA that now sits on a shelf connected to a charger that quietly maintains the charge. I know for sure that it will work at least 10 hours and still show more than 12.5 volts while transmitting. It has a three year "replace by" date written on it whereupon I will plunk down $20 for another at "Batteries-R-Us" even if it still seems OK. I don't trust old batteries. Bill Daniels |
![]() "Bill Daniels" wrote in message ... "Tim Ward" wrote in message ink.net... "Bill Daniels" wrote in message ... Does it strike some of the digerati here that expensive mechanical altimeters with easily mis-read clock-like hands locked into either the metric or US measurement systems are archaic? GPS provides highly accurate, although not ATC compliant, altitude. Various vendors provide electronic pressure altimeters with digital displays that can be switched between meters and feet with the push of a button. Digital pressure altitude sensors drive the "glass cockpits" of new GA aircraft. I seems to me that clock-like altimeters designed 70 years ago and maintained by watchmakers must be nearing their well-deserved retirement. Bill Daniels Yeah, now if they can just make them so they don't need batteries. Tim Ward What's the big deal with batteries? IMHO, batteries are at worst a minor inconvenience easily worth enduring for the benefits of the technology they make possible. Every portable gadget uses them. Most folks have a cell phone, PDA, portable GPS, digital camera, maybe a camcorder and who knows what else. Even your car, tug or winch won't start without a battery. They're cheap and they work fine with a little TLC and regular replacement. My glider uses a standard 7.5 AH 12V SLA that now sits on a shelf connected to a charger that quietly maintains the charge. I know for sure that it will work at least 10 hours and still show more than 12.5 volts while transmitting. It has a three year "replace by" date written on it whereupon I will plunk down $20 for another at "Batteries-R-Us" even if it still see ms OK. I don't trust old batteries. Bill Daniels Upon reflection, Bill, I'm sure that an instrument could be built that could satisfy both of us. Digital, easily scalable, there's no reason it can't have both an analog display (or quasi-analog, with LCD) for trends, and a 5 digit display for accuracy. It could have a lithium cell recharged by the expansion and contraction of an aneroid . Several "perpetual clocks" have used that scheme to drive mechanical gear trains with far smaller pressure changes than you'll get going up and down in a glider or airplane. An update rate of twice a second should be plenty fast enough. With LCDs, and CMOS circuitry running a few microamps at two volts or so, it's probably not impossible to build. You could probably build one with a primary lithium battery that would only need to be changed once every ten years or so. That would be the cheapest way to go. What will it cost to get it approved? How many people are going to buy it? In the small market that is aviation, what will it cost to build? If you could sell it cheaper than a mechanical altimeter, you might have a shot. In enough volume, you might be able to do that. I don't know if the altimeter market is large enough for that to be possible. The combined output of all the altimeter manufacturers is probably not as big as a run of, say, a cheap DVD player. I dunno. I'm afraid good enough is the enemy of best. If you don't care whether or not it's approved, or whether it takes batteries, then you should look at the Flytec hang glider varios. They have a lot of options as to what they display and how they display it, and I believe they'll display altitude both digitally and analog. They'd take up a bit more space on a panel, though. Tim Ward |
I have to fall firmly and loudly into the "digital is good, electrical
insturments can be reliable, mechanical varios belong in museums" group. I would love to see a serious study that shows that classic analog airspeed and altimeters (as used in gliders) are easier to read and less susceptible to misinterpretation than a properly designed (but unfortunately, theoretical) replacement digital airspeed and altimeter. With the advent of Head-up-Displays (HUDs), fighter planes have moved to almost completely digital displays of most values - only those where trend is crucial, such as vertical velocity and radar altitude, continue to have a companion analog display. Otherwise, its a straight number, usually rounded off to the nearest knot and 10 feet. Works fine in an F-15E, should work pretty good in an LS6 By comparison, trying to interpret a three-needle altimeter is like trying to read sanskrit! And then there are 1 1/2 revolution airspeed indicators! If you have a PDA in your cockpit, try setting it up to have a nice big font altitude (and speed, if available) display on it and try it - you might find that it is really easy to glance at and read. I have two seperated battery systems, and no mechanical vario. I'm stuck with a "steam-gauge" airspeed indicator and altimeter, but what I would really like is a digital airspeed, digital altimeter, and an accurate AOA indicator. For tradition, I'll keep the vario needles - since there I'm looking for trend (to provide a value to the audio), and read a digital averager for real decision making. Heck, last year I took off on a fine day only to find my airspeed inop (bug in the pitot) - but that didn't prevent me from flying a nice little 500+ k XC with some friends of mine. The only time I really missed the airspeed indicator was in the pattern. Just flew it a bit faster than usual (that AOA indicator sure would have been nice to have then...). Now the huge caveat - this is all fine in a private ship - I don't see how a the average club ship would manage. Kirk 66 |
Metric measuring tool source? | DL152279546231 | Home Built | 12 | April 29th 04 02:13 AM |
Reverse Vacuum Damging to Instruments? | O. Sami Saydjari | Owning | 8 | February 16th 04 04:00 AM |
metric system newsgroup call for votes #1 | Paul Hirose | Military Aviation | 72 | November 16th 03 06:59 PM |
Edwards air show B-1 speed record attempt | Paul Hirose | Military Aviation | 146 | November 3rd 03 05:18 PM |
Wanted - Metric Altimeters | RHWOODY | Soaring | 0 | September 13th 03 10:20 PM |
