Ocean waves are very far apart so even a 30 foot wave is no big deal,
great lakes waves are very close together and very steep. Get down in the trough of an ocean wave and the water just rolls underneath you. Get in a trough of a good sized wave on the great lakes and you are looking at a near verticle wall of water. Remember the "Wreck of the Edmund Fitzgerald"? That was a giant (729 foot) lake freighter, which was either broken in two or driven under by the waves of a Great Lakes November storm. See http://www.ssefo.com/ fore more info. The Great Lakes are nothing like an inland lake. I've watched many awesome storms (thankfully from shore) that generated waves of almost unbelievable violence, frequency and intensity. And the closest I've ever felt to death was on a small car ferry, crossing "Death's Door" (the gap between Washington Island and Gill's Rock, at the tip of the Door Peninsula in Lake Michigan) during an October storm. The waves were awesome, and the skeletons of many, many wrecks litter the bottom of Lake Michigan in that area. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Matt Barrow" wrote BIG difference between fresh water and salt? Or _relatively_ shallow water? Just curious...the closest I ever got to water was McHales Navy. The shallow water of the Great Lakes is the major factor, but the strength of the sudden squalls also makes it wicked. It is hard to explain how steep the waves get in Lake Erie. I have no direct experience on Lake Michigan, or on the Eastern end of Erie. As I said in another post, the depth of West Erie is less than 30 feet. I think 28 sticks in my mind. To try an explain how steep a 12 foot wave is, let me relate a tale of mine, on the lake. I was with my Dad, and other family members on a fine day, with relatively calm waves of 2 to 4 feet. The sky darkened up ahead, and we turned on the weather radio. A storm warning was up for a fast moving squall line, moving fast towards us. We were way out of sight of land; about 12 miles, which might have been 100, as far as getting out of the way of the storm was concerned. We prepared the boat by reefing the main sail (reducing the surface area of it, by almost half), and taking down the jib. (front sail) The wind came up, and it was so strong that we could not control the boat, so we took the main down. Our next option was starting the motor to try to keep at 45 degrees to the waves; reducing the chance of being turned over, and reducing the strength of the waves from hitting them head on. Soon the wind was blowing around 50 to 60 MPH, and the waves had gone from 4 feet to 12 feet or more, all in the time span of 20 minutes. On the ocean, a sudden squall would have made the boat harder to handle because of the wind, but the waves would not have increased nearly that quickly; taking hours instead of minutes. Depth is the factor, again. Here is what I was leading up to, to help you understand. The waves were so steep, that while we were on top of the wave, the propeller was OUT of the water. The faces of the waves had to have been more than 45 degrees, as we went up and down them. The top of one wave to next was very close together, with the front and the back of the boat touching the last wave and the next one, all at the same time. Soon, we were not able to control the direction of the boat in relation to the waves, since the prop was out of the water for so long. The only thing we had left was to throw the anchor out and hope it held, and tie it to the bow. (front) It held, and we rode out the storm for another 30 minutes, and then the waves started to get smaller, and another 30 minutes we were on our way. I feared for my life, that day. Now, for all of you sailors out there, we did very little right, that day. It was the first year, (we didn't know nearly enough) and we were still learning, and not well equipped for such storms. We got a storm jib (very small) and another set of reefs for the main, (to make it smaller, yet) and purchased a sea anchor. That is a unit that looks somewhat like a wind sock, and provides a way to let the boat drag through the water, and pull on the boat to keep it pointed in the direction that you need. The ocean wind makes big waves, but if you are in deep water, the angle of the faces of the waves are maybe 15 or 20 degrees. (until you get to the perfect storm type of waves g) Compare that to more than 45 degrees for Lake Erie. A 25 foot boat seems big, but unless sailed correctly, is no match for those conditions. I hope this helps you understand a little bit more of how quickly it gets fierce on the Great Lakes. It has killed many experienced sailors, and in much bigger boats, and even ships. -- Jim in NC |
![]() There is a somewhat famous picture of a J30 (IIRC) that launched off the back side of a wave off Michigan City at the south end of Lake Michigan. The boat was totally out of the water with the sails still pulling. Kinda reminded one of the Morrow Bay incident picture. "Morgans" wrote in message ... "Matt Barrow" wrote BIG difference between fresh water and salt? Or _relatively_ shallow water? Just curious...the closest I ever got to water was McHales Navy. The shallow water of the Great Lakes is the major factor, but the strength of the sudden squalls also makes it wicked. It is hard to explain how steep the waves get in Lake Erie. I have no direct experience on Lake Michigan, or on the Eastern end of Erie. As I said in another post, the depth of West Erie is less than 30 feet. I think 28 sticks in my mind. |
![]() Morgans wrote: Now, for all of you sailors out there, we did very little right, that day. It was the first year, (we didn't know nearly enough) and we were still learning, and not well equipped for such storms. We got a storm jib (very small) and another set of reefs for the main, (to make it smaller, yet) and purchased a sea anchor. That is a unit that looks somewhat like a wind sock, and provides a way to let the boat drag through the water, and pull on the boat to keep it pointed in the direction that you need. Every experienced sailor has been there at one time or another. One thing that's good to know is how to heave-to. You basically set the headsail on an opposing tack and lash the tiller hard to windward, and the boat *should* just sort of hang right there. Depending on wind direction this may give you a better option than dragging on a drogue, especially if you've got a lee shore nearby. http://www.sailonline.com/seamanship...ng_to_man.html The "should" part of this is that not all boats heave-to equally well depending on the keel and rig design, so it's good to practice before it's a real emergency. -cwk. |
On 2005-08-26, Jay Honeck wrote:
"Turbulence" on Lake Michigan will turn the stoutest blue-water Navy man green. When it gets rough on the Great Lakes, get off the water -- period. Probably no worse than the north Irish Sea (where we had two hurricane force storms within a week last winter, and it's not that unusual either). I've been on the Ben my Chree (a bloody great big car/truck/passenger/cargo ferry belonging to the Isle of Man Steam Packet Company) when it was so rough that people weren't just going green, they were being thrown out of their seats. The lights went out once or twice, and the ship was slamming. I'm glad I wasn't on a fishing vessel that day. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
![]() "Jay Honeck" wrote: "Turbulence" on Lake Michigan will turn the stoutest blue-water Navy man green. Tee-hee! Don't be silly: http://www.newscientist.com/article.ns?id=dn7793 |
Yep that one was silly
![]() been across the ocean. I have seen waves coming over the flight deck of a carrier and destroyers spending more time under the water than on the surface. The outside of a hurricane is a very interesting experience at sea. I think you under estimate the power of the open sea and definitely under estimate the ability of a professional sailor. Those destroyer boys are sure a special breed. I tip my hat to them. Sailing the seas was an adventure I'll never forget. Some of the most beautiful sunsets and sunrises I've ever seen. Tranquil waters that looked like the ship was sailing over glass,..and then all of a sudden the most destructive , powerful force in nature sets it's eyes upon you and you are looking down a valley of ocean like looking off a mountain top...the next minute you are looking up at the ocean on either side of you like you are in the valley looking up at the tops of mountains. Sitting on the bow of that carrier with your legs hanging off the front of the ship, playing guitar under a beautiful clear sky full of stars as far as you can see, the sounds of the waves on the hull as she pushes her way onward to the next port. Sometimes when you are there it is hard to believe the awesome force and violence that the same ocean can give you on any other day at any other time. A great experience that I wish more people could share. Sailor green on the Great Lakes? I don't think so. A newbie, sure ..but not a stout old salt. We did have a boy from NYC that stayed green the entire time we were out at sea...I mean the entire trip! I know he was miserable but it was still pretty funny ![]() Patrick student SPL aircraft structural mech "Dan Luke" wrote in message ... "Jay Honeck" wrote: "Turbulence" on Lake Michigan will turn the stoutest blue-water Navy man green. Tee-hee! Don't be silly: http://www.newscientist.com/article.ns?id=dn7793 |
W P Dixon wrote:
Sitting on the bow of that carrier with your legs hanging off the front of the ship, playing guitar under a beautiful clear sky full of stars as far as you can see, the sounds of the waves on the hull as she pushes her way onward to the next port. Sometimes when you are there it is hard to believe the awesome force and violence that the same ocean can give you on any other day at any other time. You're making me miss it... Nothing quite like being on a flattop in the middle of the Pacific as far away from land as possible without leaving the planet... It was the same feeling I get now on a long cross-country flight on a calm moon-lit night. -m -- ## Mark T. Dame ## VP, Product Development ## MFM Software, Inc. (http://www.mfm.com/) "SCSI is *not* magic. There are *fundamental* *technical* *reasons* why you have to sacrifice a young goat to your SCSI chain every now and then." -- John F. Woods ) |
![]() W P Dixon wrote: Yep that one was silly ![]() been across the ocean. I have seen waves coming over the flight deck of a carrier and destroyers spending more time under the water than on the surface. The outside of a hurricane is a very interesting experience at sea. I think you under estimate the power of the open sea and definitely under estimate the ability of a professional sailor. There is a great book out there called "Fatal Storm" about the 1998 Sydney-Hobart yacht race, which was hit by a massive storm in a similar fashion to the 1979 Fastnet race. There are a few great stories in it of rescues made by other sailboats and one account of an oceangoing tramp steamer pulling alongside a stricken 40' sailboat and winching the crew right off the deck--in Beaufort 11 conditions. Puts the Perfect Storm to shame, largely because there were survivors to tell what really happened. Definitely not a book to take on your next cruise. -cwk. |
![]() "W P Dixon" wrote Sailor green on the Great Lakes? I don't think so. A newbie, sure ..but not a stout old salt. Don't be so sure. I would not take anything away from your tales of the ocean's violence, but the Great Lakes are rough in a totally different way. They will get your attention. I'm sure there are some out there that have seen the worst of both. Some have died, not believing the Great Lakes could be more than they could handle, even though they were experienced open ocean sailors. -- Jim in NC |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
God Honest | Naval Aviation | 2 | July 24th 03 04:45 AM |
