"Jim" wrote in message
... The probability of a person having successfully made 9999 jumps surviving his 10000th jump is very different (and less) than the probability of a person who has made no jumps, successfully making 10000 safe jumps. I've been inclined to see each event as independent of and not influenced by any preceding events. Well, in a case like this, it's not true. While each jump taken in isolation has the same probability, the odds of a successful 10,000th jump certainly *are* dependent on having 9,999 successful jumps before hand. If any of those previous 9,999 jumps are unsuccessful, then the probability of a successful 10,000 jump is 0%. Jeff Shirton jshirton at cogeco dot ca Keep thy airspeed up, lest the earth come from below and smite thee. - William Kershner Challenge me (Theophilus) for a game of chess at Chessworld.net! |
If I haven't completely mangled this then, the probability of
surviving through TWO sequential occurrences of an event, each occurrence of which carries a 9-in-10 probability, is: .9 * .9 = .81 If one were to survive through these two trials and try a third the odds of surviving all three would be: .9 * .9 * .9 = .729 Doesn't look good for an event with a 1-in-10 chance of dying! Have I got this sorted out? Yep. And you even got the part about multplying survival rates rather than death rates (a sometimes subtle point - the sequence depends on multple survivals, not multple deaths) Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
Jim wrote:
Have I got this sorted out? Yep. I knew this but couldn't figure out how to put it clearly. You did it very well. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
jumps surviving his 10000th jump is very different (and less) than the probability of a person who has made no jumps, successfully making 10000 safe jumps. Well, I just don't see this. Think of it this way - the =reason= the probability "adds up" (so to speak) is that the more jumps you make, the greater the chance that you have already died from a jump in the past. (to imagine this as a non-silly example, suppose you did make 10,000 jumps, either self-propelled (while alive) or tossed out of the plane on a static line (if already dead). They toss you out (dead) as many times as necessary to bring the total jumps to 10,000 (because the pilot is paid by the jump and he needs the money) Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
![]() wrote in message oups.com... "Jim" wrote in message ... It isn't dangerous to go skydiving (1-in-10000 chance of dying) once. But "being a regular skydiver" where one jumps 100 or perhaps 1000 times in a lifetime gives you a much less trivial chance of being killed Curious. Not really. If each jump carries a 1-in-10000 chance of dying, wouldn't the 1000th jump also carry a 1-in-10000 chance of dying? Yes, assuming the jumper survived the first 9999 jumps. The probability of a person having successfully made 9999 jumps surviving his 10000th jump is very different (and less) than the probability of a person who has made no jumps, successfully making 10000 safe jumps. No, if the abolute odds of not surviving A jump are 1:10,000. The odds of death are 1:10,000 on jump #1,#2,...#10000...#20000. The dice don't have a memory. Which is exatly what you say below so I think you just mis-spoke above. The difference is that the first jumper's probability of the first 9999 jumps are all 100% successfully, having been made in the past. If one flips a fair coin, over the long run there is a 1-in-2 chance of either side coming up. Yes, but there isn't a 1-in-2 chance of flipping ten heads (say) in a row. Except, of course, if one is improbable enough to flip nine heads in a row, then the tenth head is 1-in-2. If one flips a fair coin 1 million times do the odds of either side coming up change? One is not just loooking at the last flip, one is looking at the accumulation of *all* the flips. For instance, it's no good surviving the 10000th jump, if you didn't survive the 7359th. :-) :-( :-S "Don Tuite" wrote: Actuary's numbers relate to populations, not individuals. Does the parachute know whether 10,000 jumpers made one jump each, or whether one jumper made 10,000 jumps? -- Jeff Shirton jshirton at cogeco dot ca Keep thy airspeed up, lest the earth come from below and smite thee. - William Kershner Challenge me (Theophilus) for a game of chess at Chessworld.net! |
"Gig 601XL Builder" wr.giacona@coxDOTnet wrote in message
news:ed0Re.6670$7f5.4709@okepread01... The probability of a person having successfully made 9999 jumps surviving his 10000th jump is very different (and less) than the probability of a person who has made no jumps, successfully making 10000 safe jumps. No, if the abolute odds of not surviving A jump are 1:10,000. The odds of death are 1:10,000 on jump #1,#2,...#10000... #20000. The dice don't have a memory. Yes, but a jumper *does* have a memory. A jumper cannot have a second jump *unless* the first jump was successful, correct? Above, I was comparing two jumpers, one who had 9999 jumps under his belt, and another who had 0 jumps under his belt. For the new jumper, his odds are 1:10,000 (if that is accurate) for his first jump. For the experienced jumper, his odds of surviving his *first* jump are 100%, since he already survived his first jump. It is no longer in the realm of "probability", it is now in the realm of certainty, since it is in the unchangeable past. To give another example that might make things more clear, suppose we have two people: 1) One person is going to take a revolver, put one bullet in the gun, and play "Russian Roulette" 1000 times. 2) A second person has already played (and survived) a game of Russian Roulette 999 times, and only has to play it for one more time. The second person has a 5/6 chance of survival. Do you honestly give the first person 5/6 chance of survival? I would give him (without calculating precisely) somwhere around 0.005 % chance of survival. There is a difference. -- Jeff Shirton jshirton at cogeco dot ca Keep thy airspeed up, lest the earth come from below and smite thee. - William Kershner Challenge me (Theophilus) for a game of chess at Chessworld.net! |
![]() wrote in message oups.com... "Gig 601XL Builder" wr.giacona@coxDOTnet wrote in message news:ed0Re.6670$7f5.4709@okepread01... The probability of a person having successfully made 9999 jumps surviving his 10000th jump is very different (and less) than the probability of a person who has made no jumps, successfully making 10000 safe jumps. No, if the abolute odds of not surviving A jump are 1:10,000. The odds of death are 1:10,000 on jump #1,#2,...#10000... #20000. The dice don't have a memory. Yes, but a jumper *does* have a memory. A jumper cannot have a second jump *unless* the first jump was successful, correct? Above, I was comparing two jumpers, one who had 9999 jumps under his belt, and another who had 0 jumps under his belt. For the new jumper, his odds are 1:10,000 (if that is accurate) for his first jump. For the experienced jumper, his odds of surviving his *first* jump are 100%, since he already survived his first jump. It is no longer in the realm of "probability", it is now in the realm of certainty, since it is in the unchangeable past. To give another example that might make things more clear, suppose we have two people: 1) One person is going to take a revolver, put one bullet in the gun, and play "Russian Roulette" 1000 times. 2) A second person has already played (and survived) a game of Russian Roulette 999 times, and only has to play it for one more time. The second person has a 5/6 chance of survival. Do you honestly give the first person 5/6 chance of survival? I would give him (without calculating precisely) somwhere around 0.005 % chance of survival. There is a difference. The odds for an something to happen on any given roll,trigger pull or jump don't change |
![]() "Jim" wrote in message ... On 30 Aug 2005 06:01:00 -0700, wrote: It isn't dangerous to go skydiving (1-in-10000 chance of dying) once. But "being a regular skydiver" where one jumps 100 or perhaps 1000 times in a lifetime gives you a much less trivial chance of being killed. Curious. If each jump carries a 1-in-10000 chance of dying, wouldn't the 1000th jump also carry a 1-in-10000 chance of dying? If one flips a fair coin, over the long run there is a 1-in-2 chance of either side coming up. If one flips a fair coin 1 million times do the odds of either side coming up change? No. Gambler's Fallacy. moo |
Ten Years of Flying | Jay Honeck | Piloting | 20 | February 19th 05 02:05 PM |
How safe is it, really? | June | Piloting | 227 | December 10th 04 05:01 AM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flying is Life - The Rest is Just Details | Michael | Piloting | 55 | February 7th 04 03:17 PM |
