A Piper Cherokee 140... good first plane?
Old September 1st 05, 09:57 PM
three-eight-hotel
This same story probably extrapolates to the Cherokee 235
But you can fill a Cherokee 235 up with led anvils and still not exceed
gross! ;-) I'd want a 235 for that reason alone (I'm not getting any
slimmer as I get older) LOL!!!
Old September 2nd 05, 04:37 AM
: I bet if you run a 180hp cherokee at the same TAS as a 140/150/160,
: the fuel burn will be damn close to the same. The 180 simply provides
: the option to run at a higher power setting, and hence higher speed
: and fuel flow.
: This same story probably extrapolates to the Cherokee 235.
It does. Take any specific airframe that has the options of different engines. The PA28 with a
150/160/180/235 hp engine will cruise the same speed with the same fuel burn at a constant *total* hp. For example,
75% in a 160 hp, 65% in a 180 hp, and 45% in a 235... all will be 8.5 gph. Drag power goes as the cube of the speed.
Consider a PA24 (available with a 180/250/260/400 hp engine)... it scales with the cube.
The only difference is that compression ratio is "free" power... more "bang for the bang." A 160 hp will have
the same fuel flow gph as a 150 (percentage-wise).
- Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old September 2nd 05, 03:49 AM
Bob Noel
In article 1125604186.490738@sj-nntpcache-3, Dave Butler wrote:
Some random observations:
The up-front cost of a higher powered Cherokee is higher.
The fuel cost for a higher powered Cherokee is higher.
not for mine. I had my cherokee 140 for nine years before upgrading
the engine to 160hp during an overhaul. I'm still burning about 8 gph.
And a friend had a 180, his fuel burn was 10 gph when running at 75%.
He usually ran it less than that and would see 8 gph at speeds at least
as fast as a 140.
Bob Noel
no one likes an educated mule
Old September 1st 05, 09:03 PM
three-eight-hotel
Cecil,
I went through the same struggle, before I bought my 172... I liked
the 140, because of the thought of throwing my 2 young children in the
back, but decided to go with the 172 (160 hp).
I can't really say it was a one vs. the other decision I came to,
because I could have gone either way... To be fair though, I've had
more experience in a 172 and probably was leaning that way in my mind
anyway. I really like the overall stability and flying characteristics
of the 172. It's the classic trainer and seems to want to fly itself.
I have never had a bad experience with a cherokee (flew a 180 and a
couple of 140's), and enjoyed most of my flights in them, so I'm not
trying to sell you one way or the other.
I think bottom line is... what purpose do you hope either plane will
fill for you? Are you planning on upgrading down the road? Will you
be training others in it, or getting trained yourself? What are you
most used to and comfortable flying? What's your budget?
Go out with the willingness to buy either and let the "right" plane
come to you! I had a few shady prospects go bad before I stumbed onto
my 172, and let me tell you... it was destiny! I knew from the minute
I saw it, that it was going to be the plane I would be getting my
instrument rating in and would be taking my kids to Disneyland in! I
came sooo close to pulling the trigger on a 140, and was mid-way
through a deal on another 172 that fell through. Neither of those felt
right, as I had buyers remorse even before finalizing the purchase.
The 172 I did buy though.... I have never doubted in my mind, that she
wasn't meant to be mine!
It's funny though... I bought the plane to be a family plane, and as
hectic as family can tend to be at times, they've all been in the
plane, together at one time, only a handful of times. However, those
handful of times have been some of my best experiences as a pilot!
Especially our last trip to your neck of the woods (left the plane at
Watsonville for a week and stayed in a beach house at Aptos).
A 152 or something similar would have probably served most of the
purpose of my flying for the last 3 years, but those few times of
wanting to go somewhere with the family have made it all worth it. I
know I could always rent for trips like that, but I REALLY like the
fact that I know the plane is going to be where I left it last, I know
it has been well maintained, and I know how hard the last landing was
in it! ;-)
Don't think so hard about it, and just start shopping! Physically
inspect and fly a few planes. You'll start to develop a taste for what
you are looking for, much like buying a house. Then one day... "Your"
plane is going to find "You"!
Best of luck to you! Keep us posted!
Todd
Old September 2nd 05, 12:46 AM
Roger
On Thu, 01 Sep 2005 18:56:18 GMT, "Cecil Chapman"
I'm beginning the process of looking for my own plane and have heard lots of
advice. Most have advised against getting something like a Cherokee 140 and
opt instead for something like a Cessna 172 or a Cherokee 180. Now, most
172 N's that I've flown have a 160 HP engine. It is my understanding that
the Cherokee 140 has a 150 HP engine (about comparable to the engine size of
a 172M). Will I really miss out on the extra 10 hp difference between the
C172N and the Cherokee 140?
And adding still more confusion... :-))
My opinion and preference would be hands down for the Cherokee 180.
Having flown the 140 and 180 into and out of a relatively short field
on two consecutive flights about a half hour to hour apart, the 180
was off and climbing sooner and steeper than the 140. Yes, the old
Hershey bar wing has a *lot* of sink, but that makes it a relatively
good short field airplane and I could hit pattern altitude by the end
of the runway here at 3BS.
A note he Most Cessna 172 and Cherokee 140/180 pilots use at least
twice as much runway as they really need for landing. Fly them by the
numbers, use good technique and both will really open eyes at how
short they will really land.
The Cessna 172 with 180 or 190 HP (Hawk) has the ability to get out of
some really tight spots and it scoots right along, but one of those in
good shape might be a tad pricey.
Even pushing hard, the Cherokee 180 doesn't burn all that much more
fuel than the 140. I used to burn about 8 GPH at 75% and maybe 130 to
135 MPH (the speed is a bit hazy). Coming from Gainesville GA to
Cincinnati Lunken we hit some strong winds. I went up high, throttled
back, leaned it out and about 5 hours later landed with something on
the order of 22 gallons left.
Surprisingly, under normal conditions the 172 is more likely to float
than the Cherokee 180. Full flaps on the 180 add a lot of drag and
that wing has a lot of dihedral.
Maintenance should be about the same through the range of these planes
depending mostly on their history.
If you are just going to fly around looking at the scenery the 172
offers a much better view. The Cherokee will ride the bumps much
better. The heavier 180 a little bit better than the 140.
www.rogerhalstead.com
Confused....
Old September 2nd 05, 02:13 AM
Jon Kraus
Since you can't fly all the time anyway have you concidered getting a
partner to split all the costs with? We have had our Mooney almost a
year now and there have been several times when I was glad that my
portion of the bill was only half. We have a nice plane that fits our
missions well. A nice traveling plane that is a very stable instrument
platform. Perfect for when I decide to get my commercial ticket (having
too much fun now to even think about it). My partnership runs so well it
seems like I own the aircraft but only pay half the bills. I have not
had one scheduling conflict yet. I also was able to get a much better
aircraft than I would have been able to afford by my self. Remember to
put 10% of the aircraft price back for first year gotcha's. You will
need it.
I have found airplane ownership a very rewarding, life and checkbook
altering experience. The bottom line is going to be that ownership is
going to be more expensive then you think it is. Unless you fly 150-200
hours a year (very doubtful) than ownership will be more than renting.
The good news is that the market for used airplanes is very soft right
now. You should be able to find a very good deal. Determine what kind of
plane you want and then start the search. The joy is truley in the
journey. You will get a lot of good advise in these groups. Probably
some bad advise too. Good luck and let us know how it goes.
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Confused....
Old September 2nd 05, 04:35 AM
of advice. Most have advised against getting something like a Cherokee
140
and opt instead for something like a Cessna 172 or a Cherokee 180. Now,
most
engine (about comparable to the engine size of a 172M). Will I really
between the C172N and the Cherokee 140?
For a given airframe, going from 150 to 160 hp will have a negligible impact
of cruise speed. Maybe a couple of knots in this category of airplane. The
bigger difference will be in climb performance.
I have owned (with partners) both a Cherokee 140 and a 172M and have
hundreds of hours in each (and now fly an Arrow). Some observations:
If you routinely carry more than two people, a Cherokee 140 may cause you
some frustrations. The back seat will accommodate children comfortably
enough, and the useful load will allow carrying 4 adults (with fuel
restrictions), but back seat space isn't great. Also, there is minimal
baggage room behind the rear seats. But it's fine for carrying 4 off for a
$100 burger. If your typical mission is one or two on a XC, I would
actually prefer the 140 because of its large fuel capacity and resulting
excellent range, particularly for IFR.
The C-172 has much more rear seat room, plus a real baggage compartment. It
is an excellent "family" airplane, but without much performance.
For comparable equipment and condition you will pay considerably more for
the 172. Maintenance costs will likely be about the same. Flying
characteristics? I prefer the Cherokee. It seems to handle more precisely,
and to my taste is more fun to fly.
If you like the Cherokee but need the ability to carry 3 or 4 on a regular
basis, and want to stick to an airplane in the 150-160 HP class, consider
the Piper Warrior
-Elliott Drucker
Old September 2nd 05, 04:42 AM
: $100 burger. If your typical mission is one or two on a XC, I would
: actually prefer the 140 because of its large fuel capacity and resulting
: excellent range, particularly for IFR.
That's what finally sold me on the PA28. Remember that even though the "book" fuel capacity of a PA28-140 is
36 gallons, it can hold 50... that can be very useful for a two-person cross-country. Something like a 6-7 hour
endurance at low power cruise... not too bad for a trainer-class plane.
: The C-172 has much more rear seat room, plus a real baggage compartment. It
: is an excellent "family" airplane, but without much performance.
True... the PA28-140 has pretty bad baggage room unless the back seats are removed. Also, back seats have no
legroom for a real adult. In a pinch they work, though.
: If you like the Cherokee but need the ability to carry 3 or 4 on a regular
: basis, and want to stick to an airplane in the 150-160 HP class, consider
: the Piper Warrior
Stretched fuselage by a few inches... good call. They fetch a fair bit more price, however.
-Cory
* Cory Papenfuss *
Old September 4th 05, 01:14 PM
Mike Spera
We have owned a 74' 140 for 11 years now. With no kids and few other
couples interested in flying, it has worked out pretty well. Climb
performance with the 150hp engine is pretty weak. The average 105kt
cruise speed is also not stellar, but O.K. with light winds. We usually
only travel 1/2 hour to 4 hour flights with the bulk being less than 1
hour, so it is not a real concern. Useful load is also a bit light (mine
is 729lbs.).
There are times when another 20kts of speed, 300fpm climb, and 150lbs.
of load would have been great. But, I suspect that once we had it, we
would only want more.
Maintenance has been on "our" schedule, not the plane's. This is because
the previous owner did it right and we continue the pattern.
The biggest trouble with 140s is that most were/are used as trainers
and/or are beat up with lots of hours. We now have 2600 hours and have
painted it, replaced the interior, and replaced (not overhauled) or
upgraded most other things. Few 140s have had this life. Matter of fact,
most are flying junk in my opinion. This is also true of may 180s. I
keep my eyes peeled for the "right" deal. After 11 years, I have not
seen one I would go back into hock for. Since the 140 now has nearly
everything we need, it is even harder to justify a swap. Almost every
Warrior I look at is even in worse shape. 5000 HARD hours plus and worn
out in nearly every way. Archers are out of the question financially. I
could afford it, but there is no way I want that kind of money tied up
in an airplane. If you go with an Archer, most have led pampered lives
and you will pay for it.
We have just adjusted our expectations to match the plane instead of the
reverse. I also find new "projects" to keep it interesting.
Skyhawks are a lot like Apple computers. They have quite a few tricks of
their own to make them interesting. They also have a fierce "fan club"
of people willing to pay unreasonable prices to get them. Hence, they
may not be worth the money for people not similarly afflicted.
The best thing going for 140s and Skyhawks are the vast numbers
available, especially for 172s. Plenty of parts, upgrades, STCs, and PMA
parts available. Once you own an airplane for a while you will
appreciate this fact.
Good Luck,
Mike
My first aerobatic lesson Marco Rispoli Piloting 6 April 13th 05 02:21 PM
Four States and the Grand Canyon Mary Daniel or David Grah Soaring 6 December 6th 04 10:36 AM
Newbie seeking glider purchase advice Ted Wagner Soaring 19 January 2nd 04 07:00 PM
Piper Pacer , trade $$ plus plane for R 22 GASSITT Rotorcraft 0 December 22nd 03 02:35 AM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 08:52 PM
