Landing Critique
Old September 10th 05, 02:18 PM
Icebound
"Peter Clark" wrote in message
On Fri, 9 Sep 2005 23:51:54 -0400, "Icebound"
groups.com...
stall warning horn does not "get louder" it either sounds or
it doesn't.
Did you mean that generically for all aircraft? ... or in this particular
case only?
Perhaps it's to do with the way the horn is activated. I seem to
remember the 172's horn getting louder the closer to stall you got
(pneumatically activated), but don't recall that phenomenon with the
182's horn (electric switch)?
Well, the 172's horn seems to be basically the same principle as blowing
across the mouth of an open beer bottle. If you blow lightly, it makes a
gentle hum and if you blow hard, it gets loud.
I don't know how other stall horns were designed, but it was my impression
that a stall horn is supposed to be designed to go off a little before the
true stall.
For the 172, this means that at a certain AOA, there is *some* air going by
across the opening, producing *some* sound, while you still fly not fully
stalled. It is not until a full stall that the maximum amount of air is
flowing across the opening, producing the loudest sound. Now the 172 has a
pretty thick leading edge, which may contribute to the way this seems to
work.
Since that is all that I am familiar with....
....does that mean that for most other aircraft, I would have to be aware
that the stall horn will go off suddenly and completely?
Old September 9th 05, 08:21 AM
Stefan
Marco Leon wrote:
Or maybe someone fluent in
French can translate what was said as a comment.
Nothing noteworthy.
Right seat: Ah disdonc! (General remark with no particular meaning.
Could be translated with "well...!" or something like that.)
Left seat: "That's a landing!"
and later: "(not understandable)... 400 meters!" (Probably: I needed
only 400 meters to come to a stop.)
It seems to me that it's a student with the instructor.
BTW: They landed at Logues, 10 miles east of Paris. Here's the VAC:
http://www.sia.aviation-civile.gouv....D%202.LFPL.pdf
Note that the circuit (pattern) flight path is mandatory for noise
abatement reasons, as is the case in most European airfields. And yes,
the runway is 08, with a leading zero.
Stefan
Old September 10th 05, 02:20 PM
Blueskies
"Marco Leon" wrote in message ups.com...
See video of a hard(ish) landing at:
http://www.flightlevel350.com/viewer.php?id=4137
Did this guy land a bit short of the runway or was his glidepath a bit
too shallow? Something else? It's hard to tell from the video but maybe
some PA-32 drivers can give some insight. Or maybe someone fluent in
Marco Leon
This is the classic got a video camera in the back seat gotta make a good landing blooper.
All of your really good landings are not going to be seen by anyone, but all of your bad ones will be...
Anyway, this approach was pretty sloppy from way out. The nose was all over the place; I was thinking they were playing
against a gusty wind but they settled down late in the approach...
Old September 10th 05, 04:27 PM
Jon Kraus
Looks like a landing I made last week. I was lazy and didn't fly a
pattern sice no one was around and my flight path was taking me directly
on the final approach course. I always seem to misjudge height from a
long way out and got flat coming in over the numbers. Then it is just a
matter of slowing up and pulling back into a pseudo-flare which really
results in a 3-point landing. I think that the video makes it look
worse than it probably was although he did get a bounce out of it.
Since it appears that he will be able to use the airplane again I would
call it a good landing. :-)
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Marco Leon
Old September 10th 05, 05:29 PM
N93332
"Jon Kraus" wrote in message
(The old saying) A 'good' landing is one you can walk away from, a 'great'
landing is one that you can reuse the plane...
So far, all my landings have been 'great'! ;-)
-Greg B.
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 04:35 PM
