Ttransponder question #3
Old September 19th 05, 06:45 AM
Jay Beckman
"Newps" wrote in message
Wow, lots of misunderstanding out there. Recycle transponder means to
turn it off and then back on again. "Check your transponder on" means you
have taken off and we are not receiving it when we expect to. "Check mode
C on" means we are getting the transponder but no altitude information.
If we are getting the transponder return and an altitude but you didn't
tag up properly it is because the code is wrong. 75% of the time it is
because you entered it wrong, the other 25% of the time is because you are
hangaing on to that piece of **** and even though you entered the code
right it decided to transmit a different code. Banging on it usually
clears it up.
Here's one that's maybe a bit different...
Tucson, AZ Clearance Delivery gives me a squawk of YYYY for departure from
the Class C airspace.
When I get handed off to ZAB Center, I check in with them for flight
follwing and the controller says "Recycle Transponder, Squawk XXXX."
They only mean to enter the new code, right? They aren't really asking me
to go to STBY, enter the new squawk, then go back to ALT, are they?
Is this correct phrasiology on their part?
Jay Beckman
PP-ASEL
AZ Cloudbusters
Chandler, AZ
Old September 19th 05, 02:32 PM
Newps
They should be saying..."reset transponder, squawk xxxx."
Old September 19th 05, 07:56 PM
Steven P. McNicoll
"Jay Beckman" wrote in message
news:FfsXe.253826$E95.128149@fed1read01...
Right.
They aren't really asking me to go to STBY, enter the new squawk, then go
No.
No, correct phraseology would be just "Squawk XXXX".
I want to ask you the most important question of your life. Douglas Olson Owning 1 May 22nd 05 05:15 AM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 01:11 AM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
