Taxi Clearance
Old September 25th 05, 03:47 AM
Steven P. McNicoll
"Russ MacDonald" wrote in message
news:_WmZe.2255$WT3.2244@trnddc03...
I teach my students to call before engine start to get their clearance
(controlled fields). You are allowed to call up to two hours before your
proposed departure, so why waste your gas waiting for the clearance to be
issued?
Allowed by whom? The strip doesn't print until 30 minutes prior to the
proposed departure time.
Old September 24th 05, 11:40 PM
Brenor Brophy
I'm based in California, but I've flown from controlled fields in both
Ireland (EIWF) and Sweden (ESSB) and I never had to get an engine start
clearance. So I'm not so sure that this is a pan European thing.
-Brenor
Old September 25th 05, 08:08 PM
Chris
"Brenor Brophy" wrote in message
-Brenor
It depends on each airfield and how they want to organise things, therefore
it is important to either read the latest airfield information or check out
the ATIS before start.
Old September 25th 05, 01:32 AM
john smith
I always call on the handheld to get my clearance prior to engine start.
That way, if there is a delay, I am not paying to keep the engine
running while I wait.
Old September 25th 05, 03:13 AM
Ron Rosenfeld
The way I've been taught, that is certainly your option. My posting was
that many, including myself, do not do so routinely and that appears to be
in conflict with the AIM.
In the US, have you ever received a clearance that includes a clearance to
start you engine? (which was the thrust of my original question). The
only time that has occurred to me was at BOS and only at a time when the
requirement to call CD prior to engine start was clearly stated on the
ATIS.
Old September 25th 05, 03:16 AM
Lynne
Santa Monica (KSMO) requires you to call ground prior to engine start.
ATIS.
Old September 25th 05, 03:45 AM
Steven P. McNicoll
"Lynne" wrote in message
So just how do they require that?
Old September 25th 05, 05:03 AM
Lynne
It is broadcasted on the ATIS. If you do not call for engine start, and
simply call ground to taxi, you WILL be told to hold your position. The
airport is very tight, so they don't want aircraft that do not have
their IFR release blocking access to the runway.
In other words, when you call for start clearance, your IFR release is
coordinated.
Lynne
Old September 26th 05, 08:34 PM
Dave Butler
- CURFEW: NO ENGINE STARTS OR DEPS EXPECT PPR LIFEGUARD FLTS 2300-0700 MON-FRI
AND 2300-0800 WKENDS.
Old September 25th 05, 01:35 PM
Ron Rosenfeld
But the requirement to do so is, according to another post of yours, so
stated on the ATIS at SMO.
My point is that it seems to be an AIM requirement that is not generally
followed in the US, in the absence of a specific instruction (e.g. on the
ATIS).
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Touch and Goes versus Full Stop Taxi Backs Kevin Dunlevy Piloting 81 September 18th 05 09:26 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
