![]() "Philippe Vessaire" wrote The fuel/water heat exchanger is standard on diesel cars. For an hombuilt, juste take one and bolt in somewhere bear the engine. The return fuel is able to do the job and the whole tank will be warmer enought for safe operation. For biodiesel cars, some people juste run a copper tube near exhaut and the same job is done. These cars still need a pure diesel start and stop. Right. It is a good idea to warm the fuel, but you can not use the fuel to get rid of all of the engine's waste heat. -- Jim in NC |
Philippe Vessaire wrote:
For biodiesel cars, some people juste run a copper tube near exhaut and the same job is done. These cars still need a pure diesel start and stop. Biodiesel does _not_ require a petrodiesel start/stop fuel. You're thinking of straight vegetable oil systems. The only thing you need to do to convert a diesel vehicle to biodiesel is pour it into the tank. AP |
![]() wrote The other possibility would be to stick a radiator in each wing root and funnel ram air through the radiator into the wing cavity. The warmed air would then be the heating element. I wonder if that would be sufficient to prevent gelling and also provide some minor wing heat without all the complexity. You really need to take some physics and thermodynamics. Right now, you need to buy a vowel. I'm only kinda kidding. What you are proposing isn't being done, because it won't work. Sorry. -- Jim in NC |
![]() Morgans wrote: wrote The other possibility would be to stick a radiator in each wing root and funnel ram air through the radiator into the wing cavity. The warmed air would then be the heating element. I wonder if that would be sufficient to prevent gelling and also provide some minor wing heat without all the complexity. You really need to take some physics and thermodynamics. Right now, you need to buy a vowel. I'm only kinda kidding. What you are proposing isn't being done, because it won't work. Sorry. -- Jim in NC No need to apologise. I would first have to take you seriously in order to be disappointed. This is usenet afterall, and a forum about _experimental_ aircraft. I would think enthusiasm towards innovation would be met with a slightly more positive attitude. Can I buy an "A"? -Matt |
![]() wrote No need to apologise. I would first have to take you seriously in order to be disappointed. This is usenet afterall, and a forum about _experimental_ aircraft. I would think enthusiasm towards innovation would be met with a slightly more positive attitude. Right but experiments are take on,, when models and calculations show that the proposed idea might work. It has been shown via well respected concepts, that the numbers will not let it work. Sure, try it if you want, but I would not want to waste my time and mones=y on something that falls way short by the numbers. Can I buy an "A"? Sure! ;-) -- Jim in NC |
Morgans wrote:
wrote The other possibility would be to stick a radiator in each wing root and funnel ram air through the radiator into the wing cavity. The warmed air would then be the heating element. I wonder if that would be sufficient to prevent gelling and also provide some minor wing heat without all the complexity. You really need to take some physics and thermodynamics. Right now, you need to buy a vowel. I'm only kinda kidding. What you are proposing isn't being done, because it won't work. Sorry. Well, again, has anyone done the engineering on this? As I understand it, what he's talking about is simply using underwing radiators and ducting the exhaust air from the radiators through the interior of the wings before allowing it to flow out of exhaust ports. I can see how it might work, the question is how well it would work. Would it provide enough heat to the wing skin to keep ice from adhering to it? AP |
![]() Alan Petrillo wrote: Morgans wrote: wrote The other possibility would be to stick a radiator in each wing root and funnel ram air through the radiator into the wing cavity. The warmed air would then be the heating element. I wonder if that would be sufficient to prevent gelling and also provide some minor wing heat without all the complexity. You really need to take some physics and thermodynamics. Right now, you need to buy a vowel. I'm only kinda kidding. What you are proposing isn't being done, because it won't work. Sorry. Well, again, has anyone done the engineering on this? As I understand it, what he's talking about is simply using underwing radiators and ducting the exhaust air from the radiators through the interior of the wings before allowing it to flow out of exhaust ports. I can see how it might work, the question is how well it would work. Would it provide enough heat to the wing skin to keep ice from adhering to it? AP Thanks Allan, One of the remaining issues of course is that it is my understanding that it typically isn't the wing ice that kills you. It is the ice on the elevator and horizontal stab. Doh! You end up trimming out the effect of the ice until there is no more trim left and... Bonzai! I only have 250 hours, and have never experienced icing personally. Given that cabin heaters are only a foot or two of exhaust pipe, I to have to second guess Jims assessment of the situation. Though I do remember being a little frosty at 10K MSL in the winter in my M20E, I did at least get _some_ heat. 1. With a liquid cooled engine you _have_ to have an auxillary heat sync of some kind. 2. If waste heat can be used to improve safety or performance it should be. 3. Using biodiesel presents additional safety hazards related specifically to loss of thermal energy that _have_ to be engineered out for the fuel to become suitable for aviation use. From where I stand all of that kind of goes together. Wait... let me get my rain coat. I hear Jim comming. -Matt |
On 26 Sep 2005 14:47:36 -0700, "
wrote: Jet A1 is a little bit cheaper, but it need oil addition (2 strokes oil is good but normal oil would be ok) for high pressure pump. Have you heard of anyone cutting Jet A like your describing? I would expect those engines are quite sensative. I'd be really nervous about fuel/oil ratios doing that! I recognize that they don't fly, but trucks have mixed kerosene (sometimes called #1 fuel oil) and diesel (sometimes called #2 fuel oil) in cold weather. One of the company's that my father dealt with had a small kerosene tank which they used before shutdown and to start. It is interesting that #2 has more BTU/gallon than #1, so mileage is slightly better on #2. The lubricity issue is one that I asked a buddy of mine aobut when Thielert said their "auto based" engine would run JetA ... Enquiring minds would like to know more. |
GeorgeB wrote:
On 26 Sep 2005 14:47:36 -0700, " wrote: Jet A1 is a little bit cheaper, but it need oil addition (2 strokes oil is good but normal oil would be ok) for high pressure pump. Have you heard of anyone cutting Jet A like your describing? I would expect those engines are quite sensative. I'd be really nervous about fuel/oil ratios doing that! I recognize that they don't fly, but trucks have mixed kerosene (sometimes called #1 fuel oil) and diesel (sometimes called #2 fuel oil) in cold weather. One of the company's that my father dealt with had a small kerosene tank which they used before shutdown and to start. It is interesting that #2 has more BTU/gallon than #1, so mileage is slightly better on #2. The lubricity issue is one that I asked a buddy of mine aobut when Thielert said their "auto based" engine would run JetA ... Enquiring minds would like to know more. I have a picture somewhere of a Twin Otter in a small arctic community being fueled from a truck clearly marked "Furnace Oil". Apparently these areas get one boatload of fuel each summer to last the year, and it is Arctic Diesel or "P-50", suitable for aircraft, diesel generators, stoves and just about anything else. Normal diesel is definitely not used in aircraft because it can get cold at altitude and the fuel jells. -- John Halpenny Truth is stranger than fiction. This is why writers and readers are more comfortable with fiction. |
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB | Mal | Soaring | 59 | October 4th 05 05:39 AM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
New Military Aviation Books from Germany | ArtKramr | Military Aviation | 0 | November 23rd 03 11:43 PM |
New Military Aviation Books from Germany | ArtKramr | Military Aviation | 0 | October 29th 03 02:33 AM |
New WWII books from Germany | ArtKramr | Military Aviation | 0 | October 13th 03 12:54 AM |
