C182 / SMA Jet Fuel Engine?
Old September 30th 05, 10:06 AM
Mike
After a bit more digging here is some more information I have found:
Current cost of the C182Q kit is about $77K soon to be
reduced by "at least $10K" so around $67K
Installation, at the dealer I contacted, runs about $9K.
Or about 120-hrs @ $75/hr.
So the installed price should be about $76K. Which
includes almost everything from the firewall forward.
"Normal" recurring maintenance is expected to be:
100 hour oil changes.
200 hour fuel filter change and glow plug inspection.
500 hour compression check
With estimated time at 3~5 hrs.
Annuals were - Quote:
"Your overall annual inspection will be much
less then an avgas engine by virtue of the
fact that the engine contains 70% less parts
and therefore there is virtually nothing left
to change out or replace."
So how much that will really mean ... ?
Overhaul is estimated to run around $24K+ based
on the 3000-hr TBO. So in the perfect world, I
could either do 2 "cheaper" overhauls on the
SMC or 3 regular overhauls on a Lyc or 3+ on
a TCM engine over a 6000hr life.
If you look at burning less cheaper (if available) JetA fuel than avgas
over the life of the TBO. Might save a few bucks. Also saving on price
of a few other pieces and parts (sparkplugs, etc.) there might be a few
more bucks saved. And starting off with a new prop.
So since I am rather new at this how much does an overhaul on a regular
avgas burning C182 engine run?
It almost looks like it might be something to look a little closer at.
Old September 30th 05, 02:59 PM
xyzzy
The current Aviation Consumer magazine has an article about the SMA 182.
They also did a general review of 182 series in May quoted overhaul
cost of $17K for the continentals and $23K for the Lycs.
"You can support the troops but not the president"
--Representative Tom Delay (R-TX), during the Kosovo war.
Old September 30th 05, 06:51 PM
George Patterson
Probably this. The annual inspection on a gas engine is basically to run a
compression test, clean and rotate the plugs, check and adjust the ignition
timing, and check the air filter. All shops in this area also change the oil and
filter, though the FAA doesn't require it. Of course, an AD check is also run.
I would bet that the inspection for the diesel will involve running a
compression test (whether it's been 500 hours or not), cleaning the glow plugs,
checking the air filter, and changing the oil and filter. Plus an AD check. That
basically will save you the cost of the magneto work (since there aren't any).
The time needed to check the glow plugs will also be less than messing around
with 8 spark plugs.
Now, if the FAA will allow owners/operators to actually follow the 100, 200, and
500 hour inspection periods recommended by the manufacturer, you would see a
*big* decrease in costs, but I bet they won't.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old September 30th 05, 08:45 PM
NW_PILOT
You forgot about the fuel injection system inspection? Injectors fail become
leaky or clogged
"George Patterson" wrote in message
news:lWe%e.22$DO2.21@trndny06...
ignition
oil and
run.
plugs,
check. That
any).
around
with 8 spark plugs.
200, and
a
George Patterson
neighbor.
Old October 1st 05, 03:21 AM
George Patterson
leaky or clogged
Well, according to SMA, the injector *setting* has to be checked every 500
hours. No note about anything more extensive in that system.
George Patterson
Old October 1st 05, 09:16 AM
nuke
Here's one for sale:
http://www.aso.com/i.aso3/aircraft_v...craft_id=90840
In article . com,
"Mike" wrote:
Is there any information available about the new SMA jet fuel engines
that are being offered for the C182?
I'm curious if maintenance would be much of an issue. Are there many
shops that can handle working on them?
Is it a replace only like the Centurion 1.7 on the Diamond airplanes?
Or can it be overhauled to get flying again?
Cost for an annual?
How would they perform at high altitudes? - Colorado rockies region for
example.
Any way lots of questions so if any one knows where I might be able to
find information it would sure be appreciated. I've already checked the
www.smaengines.com web site and it is just a little light on
information.
Thanks
Old October 1st 05, 08:52 PM
Montblack
("nuke" wrote)
(SMA Diesel installed in a 1980 182Q Skylane)
Seller says 6.0 gal @ 65%
Link says 6.9 gal @ 64%
Someone is lying!!! :-)
(Seller)
SMA SR305-230 Engine
230 HP Turbo-Diesel Engine
Burns JetA Fuel
3000 Hours TBO
Full Power up to 10k Feet
Burns 6 GPH at 65% Cruise Power Settings
SMA info is in middle doccument thumbnail link
Montblack
Old October 2nd 05, 01:03 AM
George Patterson
Well, just my opinion, but I think the cowling looks a lot better than the stock
aircraft.
George Patterson
Old October 19th 05, 06:01 PM
Darrel Toepfer
Default C182 / SMA Jet Fuel Engine?
the stock aircraft.
But, where'd they steal that throttle quadrant from?
Old October 19th 05, 11:04 PM
Guy Byars
That quadrant is cool, but looks like it would be impossible to see the
rudder and elevator trim indicators.
"Darrel Toepfer" wrote in message
the stock aircraft.
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
"Out of fuel, out of hope: 'Help, I'm in the water'" [email protected] Piloting 145 May 3rd 05 11:21 PM
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 06:13 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
