In article .com,
"Robert M. Gary" wrote: In the case of the A320, or the 737, they can both land with a full load of fuel. Then why did Jet Blue fly around for 3 hours burning fuel before landing back in LAX? It seems like if there is a real reason to want to burn off fuel there would be a real way to get rid of the fuel. I can dump fuel even in my Mooney. I would think landing at a minimum weight would help reduce the probability of nose gear failure. Also, 3 hours of fuel burned in the air is far better than burning on the ground, if you know what I mean. With respect to flying around for 3 hour... well... they could. There was no need to land immediately. -- Bob Noel no one likes an educated mule |
![]() "Robert M. Gary" wrote in message Then why did Jet Blue fly around for 3 hours burning fuel before landing back in LAX? It seems like if there is a real reason to want to burn off fuel there would be a real way to get rid of the fuel. The prime objective of the three-hour fly-around was not to burn off fuel. The time was used consulting with engineering to make sure all alternatives and technical sources had been considered before committing to a compromised landing. Having said that, burning off the fuel didn't hurt. While a reduced landing weight wasn't technically required, it was still more desirable than a heavier landing weight in the instance. |
In the case of the A320, or the 737, they can both land with a full load of fuel. Then why did Jet Blue fly around for 3 hours burning fuel before landing back in LAX? It seems like if there is a real reason to want to burn off fuel there would be a real way to get rid of the fuel. I can dump fuel even in my Mooney. As others have said, they first consulted with their dispatch and maintenance, which took time. The original intent was to land in Long Beach, but when they found the gear rotated, they changed to LAX. That took more time. LAX was picked because of the longer runways, and better emergency services. Once they decided to head toward LAX, they had already burned a fair amount of fuel. Any additional time flying around helped: - Lower landing speed - Less impact force when the nose gear dropped - Shorter stopping distance once on ground As to why no provision for fuel dump, I suspect it is a cost driver: Something else to fix, something else to go wrong, plus it adds unproductive weight. |
Of course, everything is a cost driver. Whether or not to have carpet is a cost decision. The real question is what the benefit side looked like in their cost/benefit talks. -Robert |
Put another way, why provide a way to dump fuel when you can just run it
through the engines. They didn't need to lose weight that fast, they didn't need to land 'right now'. The fact that they flew around in circles for three hours was probably a good thing, time to examine every possibility and double check everything before landing. "Robert M. Gary" wrote in message ups.com... As to why no provision for fuel dump, I suspect it is a cost driver: Of course, everything is a cost driver. Whether or not to have carpet is a cost decision. The real question is what the benefit side looked like in their cost/benefit talks. -Robert |
![]() "Robert M. Gary" wrote in message ups.com... As to why no provision for fuel dump, I suspect it is a cost driver: Of course, everything is a cost driver. Whether or not to have carpet is a cost decision. The real question is what the benefit side looked like in their cost/benefit talks. Why is dumping fuel needed? It can still climb at engine out with full fuel, no need to dump there. If they can get up, and stay up, no need to dump; they are safe. What in this case? Were they in danger, flying around? No? Why dump, then? Could they have landed immediately, in a case of immediate danger? Absolutely. Still, you are asking. Why would they need to dump? They were in no danger. -- Jim in NC |
Robert M. Gary wrote on 9/27/2005 14:07:
In the case of the A320, or the 737, they can both land with a full load of fuel. Then why did Jet Blue fly around for 3 hours burning fuel before landing back in LAX? The last link provided by Kev has the likely answer: "The primary reason to burn off the extra fuel was that a heavier plane has a faster landing speed. Since a slower airspeed on landing was the objective in this case, the course of action was to lighten the load by burning off some fuel and when landing, lower the nose gear at as slow an airspeed as possible." -Joe |
"The primary reason to burn off the extra fuel was that a heavier plane has a faster landing speed. Since a slower airspeed on landing was the objective in this case, the course of action was to lighten the load by burning off some fuel and when landing, lower the nose gear at as slow an airspeed as possible." Joe, You sound like an EXCELLENT advocate for having the ability to dump fuel too!!! -Robert |
The FAA certification requirement for a fuel dump system is a takeoff
weight that is greater than 135% (I think) of the max landing weight. They don't add the complexity and cost of a dump system unless it is required for certification. The 707-123 I flew had a empty weight of 120,000 lbs, max TO weight of 256,000 lbs, 112,000 lbs of fuel, a max landing weight of 190,000 pounds,(135%) had a dump system. A 757-200 at 256,000 lbs carries 83,000 lbs of fuel, max landing weight of 198,000 lbs (130%) does not. BTW the 757 with 29,000 lbs less fuel has the same range as a 707-100 with the same passenger load. The 707 system has standpipes that let you dump only to get you down to max landing weight, leaving in our case about 70,000 lbs of fuel. That being said, I'd have flown around several hours after dumping, if there was no immediate emergency , to get as light and non-flamable as possible before landing. Their gear problem was not an emergency and I doubt the crew declaired one even though they asked for the equipment. Emergencies require immediate action. (think fire) BTW a single engine failure is not classified as an emergency either. The aircraft is certified to climb at max takeoff weight on a single engine. I'm sure the airlines, EPA, and everyone else would rather the fuel be burnt as normal rather than dumped into the air and sea. In an emergency, planes that don't have a dump system will do an overweight landing and and have to do an overweight landing inspection prior to next flight. Given the choice, it's better to burn it down than do the inspection. |
![]() Robert M. Gary wrote: Joe, You sound like an EXCELLENT advocate for having the ability to dump fuel too!!! -Robert Robert, Why are you in such a hurry to dump fuel? Doing that starts to limit your time / options available for trouble shooting the problem and diverting to another airport. The first two memory items on any emergency checklist a 1. FLY THE AIRPLANE 2. DON'T HURRY Dumping fuel violates #2. Besides, IF you really need to land in a hurry, the A320 can do that at any weight. These guys took off for NY with a full load of passengers. That means that they had a lot of fuel onboard and a heavy takeoff weight. To land at that weight would have required a much higher landing speed. Since they had the hydraulics (green system) turned off to the nosewheel steering system, (per emergency checklist) this also reduced their braking ability because this same hydraulic system also controls the #1 engine reverse, and normal braking, i.e. antiskid assisted braking. BJ A320 Capt. |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
About French cowards. | Michael Smith | Military Aviation | 45 | October 22nd 03 03:15 PM |
Ungrateful Americans Unworthy of the French | The Black Monk | Military Aviation | 62 | October 16th 03 08:05 AM |
