![]() "Robert M. Gary" wrote in message oups.com... In the case of the A320, or the 737, they can both land with a full load of fuel. Then why did Jet Blue fly around for 3 hours burning fuel before landing back in LAX? It seems like if there is a real reason to want to burn off fuel there would be a real way to get rid of the fuel. I can dump fuel even in my Mooney. The crew is paid by the hour? |
![]() "Robert M. Gary" wrote Then why did Jet Blue fly around for 3 hours burning fuel before landing back in LAX? It seems like if there is a real reason to want to burn off fuel there would be a real way to get rid of the fuel. I can dump fuel even in my Mooney. The plane would be able to land at the weight that it was at, but that would have been two negative things. One, it would have meant extra weight on the already overstressed nose gear. Two, it would have meant a faster landing speed, and faster speed that the nose would have been let down. -- Jim in NC |
Robert M. Gary wrote:
In the case of the A320, or the 737, they can both land with a full load of fuel. Then why did Jet Blue fly around for 3 hours burning fuel before landing back in LAX? It seems like if there is a real reason to want to burn off fuel there would be a real way to get rid of the fuel. I can dump fuel even in my Mooney. -Robert They burned off the fuel to reduce weight. Less weight means a lower approach and touchdown speed. Less weight means less mass to slow down once they're on the ground. I would imagine they turned their autobrakes off since, without nosewheel steering, they would need to use differential braking for steering purposes. Minimum weight would allow them to not have to land right at the beginning of the runway and not have to use excessive braking to stop the aircraft within the runway length. This way they could concentrate on a smooth touchdown and slow lowering of the nose gear. I made an emergency landing on 25R at LAX in a 737-200 which had lost all hydraulic power and the electrical emergency flap extension failed also. So we had to make a manual reversion no-flap landing with emergency gear extension. We had no nose wheel steering and used differential braking for steering. We had to be careful with it since we only had accumulator power for brakes and thrust reversers. We got it stopped about half way down the runway and then were towed to our gate. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - |
Does anyone have any insight into why the A320 isn't able to dump fuel. Because it has no need to. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
If you put a fuel dump system in an airplane that doesn't need it, and it
does an inadvertent dump, who is liable for the subsequent water landing? Seth N8100R "George Patterson" wrote in message news:tbl_e.21584$Fh4.12558@trndny03... Robert M. Gary wrote: Does anyone have any insight into why the A320 isn't able to dump fuel. Because it has no need to. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
"Seth Masia" wrote:
If you put a fuel dump system in an airplane that doesn't need it, and it does an inadvertent dump, who is liable for the subsequent water landing? Most dump equipment will not jettison all the fuel. They typically will leave a minimum amount to ensure the scenario you are painting will not happen. |
That's what happened to the Lynard Skynard band. They took off with one
bad engine (some fly by night 135 operator). Once that engine failed they tried to xfer fuel to the other tank to run the one remaining engine. However, what they really did was dump all the fuel overboard. As I recall, they landed in a field, killing the singer and one or two of the spouses on board. -Robert |
It's labeled "Dump" down to a 3000# minimum on NWA 320's. See above.
Enviro in this case perhaps. Have a great one! Bush On 27 Sep 2005 13:29:55 -0700, "Robert M. Gary" wrote: Does anyone have any insight into why the A320 isn't able to dump fuel. What factors would go into such a design compromise? -Robert |
On 27-Sep-05 13:29, Robert M. Gary wrote:
Does anyone have any insight into why the A320 isn't able to dump fuel. What factors would go into such a design compromise? -Robert It almost sounds as if you would be believing that Airbus is French. :-) It is not. It is rather a product of an international consortium (British, German, French, Italian) in which French does not have the largest financial stake anyway... The making of an Airbus is literally like the caricature about the bureaucracy in the "United Europe." It is a maze of parts and subcomponent tourism (Super Goopies and Belugas are being used.) For example wings for the A320 are being made in Bremen, Germany. Many wing components come from Britain, after which they ship the wings to Toulouse, France in a Goopy. etc etc. You name it, every Airbus model has its own subdivision of manufacturing sites and different logistics. Thomas |
ThomasH wrote:
The making of an Airbus is literally like the caricature about the bureaucracy in the "United Europe." It is a maze of parts and subcomponent tourism (Super Goopies and Belugas are being used.) For example wings for the A320 are being made in Bremen, Germany. Many wing components come from Britain, after which they ship the wings to Toulouse, France in a Goopy. etc etc. and who makes the nose gear specifically? :-) --Sylvain |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
About French cowards. | Michael Smith | Military Aviation | 45 | October 22nd 03 03:15 PM |
Ungrateful Americans Unworthy of the French | The Black Monk | Military Aviation | 62 | October 16th 03 08:05 AM |
