Light Electric Rotorcraft
Old October 1st 05, 01:47 PM
Default Light Electric Rotorcraft
Hi,
I was looking at pictures of Yamaha's recently announced Deinonychus
motorbike, and was struck by how functional and light it looked, due to
having been designed around electric wheel-motors:
http://www.gizmag.com/go/4686/
Somehow this same barebones functional look reminded me a bit of the
Mosquito helicopter, also featured on the same site:
http://www.gizmag.com/go/4628/
And so it made me wonder whether some of the same elements used to make
the Deinonychus motorbike couldn't be rearranged to make a light
electric-powered mini-helicopter.
Ugh, here's my ascii-art pic ;P
_||____
__ /
\__/
So the top part is the rotor and the = signs are the wheel motor that
turns it.
Then you have the shaft with the seat coming off near the bottom of it.
And the circular shape at the bottom is supposed to be a tire for
landing gear, meant to take the main shock of landing, but the pilot's
legs are supposed to provide lateral stability on landing and takeoff.
Some Segway-style control logic on the bottom wheelmotor could be used
to provide stability on the forward-backward axis during
landing/takeoff. This would include allowing the swivel-arm, on which
the bottom tire is mounted, to move and change its angle.
So the tire underneath is supposed to have fan-blades as the spokes,
and is spun by its wheelmotor to provide the counter-rotative thrust
like a tail-rotor. After takeoff, the swivel arm slowly swivels the
tire back and up to position it at the rear. Likewise, during landing
approach it swivels down and forward to serve as the Segway-style
landing gear.
While landing, the wheelmotors will use regenerative braking to stop
the rotors as quickly as possible.
What do you think? Comments, critiques, suggestions?
Old October 1st 05, 09:40 PM
Orval Fairbairn
In article .com,
Hi,
_||____
__ /
\__/
turns it.
landing gear.
Of course, they can! All you will need is a really LONG extension cord!
Old October 2nd 05, 03:21 AM
Montblack
("Morgans" wrote)
My bet is that the batteries will weigh too much, and be too expensive.
I HATE being a pessimist!
Diesel turning a generator?
Montblack
Old October 2nd 05, 03:55 AM
Morgans
I didn't see what the engine was on the heli, but if you know what it is, do
some calculations. Figure the wattage for the gas engine heli, then convert
it into amp hours for the length of time that you want to fly, then figure
out how much weight of batteries you will have to carry.
Jim in NC
Old October 2nd 05, 05:18 AM
Morgans
And this is supposed to be saving weight? g
Why not just turn the rotor with the diesel? Too obvious?
Jim in NC
Old October 2nd 05, 02:51 PM
Morgans wrote:
wrote
SNIP
Jim in NC
Then stop. It's a simple 12 step program... :-)
-Matt
Old October 2nd 05, 09:44 PM
red
manofsan,
That's an interesting idea. Now put another lifting rotor on top of the
main shaft, counter-rotating, and you can forget the tail rotor, with all
of its' complexities. Use spider gears idling between the rotors, so both
rotors will turn at equal rates, even if one motor fails.
Pivot the entire rotorhead like a Benson autogyro, and control that with a
joystick. Steer it with a large rudder behind the pilot that can tilt (for
yaw axis control in hovering flight) *and* swing left-and-right (for
directional control in forward flight). You could do that very simply,
with a rudder hinge line angled 45 degrees back from the main rotor shaft,
and rudder cables that pull the lower end of the rudder directly.
The flight control system at the pilot's position could be identical to an
autogyro. You would need rudder pedals, throttle, and joystick only.
There would be no cyclic controls, no collective pitch controls, and no
tail rotor controls (because there is no tail rotor). This is *much* less
machinery than the AirScooter:
http://www.gizmag.com/go/3056/
Feed it with fuel cells (aviation ain't cheap).
Watch out for birds... Don't forget the BRS :-)
http://brsparachutes.com
My ASCII art:
____
|BRS |
counter-rotating ||
-------------------(motor)--------------------
lift rotors *||* --spider gears
______||-----\
_____/h\.....|| \ autogyro
( i\....||\ \--joystick
( n\...|| \ \
(rudder g\..|| \seat pedals
(__________e\.|| \______ /
/ main frame w/fuel cells \
o O
(Replies *will* bounce, unless you delete
the letter A from my email address)
Cheers,
Red
_||____
__ /
\__/
turns it.
landing gear.
Old October 2nd 05, 10:09 PM
Frank van der Hulst
It *might* be possible that diesel-electric system would be lighter than
pure electric or pure diesel.
A small diesel could be optimised to run continuously at its most
economical RPM, producing only a little more electricity than needed to
drive the rotor in level flight. For additional power, electricity from
the battery would also drive the rotor. When descending, the battery
gets charged faster.
Old October 2nd 05, 10:45 PM
Hi red, thanks for the great ideas.
Hmm, I read about how a coax design can use differential rotation speed
between the 2 rotors for the purpose of turning the aircraft. That'd be
pretty easy to do with a wheelmotor for each rotor.
Here's a link to a new kind of wheelmotor which is attracting
attention:
http://www.wavecrestlabs.com
The company is headed by General Wesley Clark, former NATO commander.
Regarding portable fuel cell for propulsion, here's another link:
http://www.intelligent-energy.com/in...6&artID=3 709
And hydrogen is a lightweight fuel too, for lower fuel load.
But suppose you want some extra juice sometimes, for more
maneuvering/lifting power. Then use the new Toshiba battery:
http://www.dpreview.com/news/0503/05...sh1minbatt.asp
It can apparently discharge and absorb energy at a very high rate. This
might be useful for using regenerative braking to recover energy from
your rotor when you're reducing airspeed/altitude, since a wheelmotor
can convert torque/rpm back into electricity. Once you've landed,
regenerative braking would allow you to quickly bring the rotors to a
stop while recovering energy from them.
I'd also imagine the electric motors would be quieter too, so your
eardrums don't take a beating.
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB Mal Soaring 59 October 4th 05 05:39 AM
Skycraft Landing Light Question Jay Honeck Owning 15 February 3rd 05 06:49 PM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
OT but very funny after some of the posts we have had of late. Mycroft Military Aviation 1 August 8th 03 10:09 PM
Electric whine in the light circuit - Help Victor J. Osborne, Jr. Owning 1 July 29th 03 11:36 PM
