Turbo performance vs non-turbo
Old October 4th 05, 04:44 AM
George Patterson
Matt Barrow wrote:
I believe that's a Turbo Alley turbonormalizer, not a Turbo "supercharger".
If not, I suspect the STC might require some "beefing up" of certain parts.
According to the article, it's a RCM turbonormalization package which contains a
turbocharger. The turbocharger is made by Kelly Aerospace. They say they have
over 1600 hours on one Commander with it.
This unit keeps the manifold pressure at or below 28 PSI. I take it you were
describing systems that do not have this limitation.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old October 4th 05, 05:11 AM
Matt Barrow
"George Patterson" wrote in message
newsUm0f.35172$wb3.22707@trndny03...
"supercharger". If not, I suspect the STC might require some "beefing up"
of certain parts.
contains a turbocharger.
That sounds like being "sorta pregnant". A TN system has a TC, but the
popoff keeps it from running beyonf normal sea level pressure internally.
The turbocharger is made by Kelly Aerospace. They say they have over 1600
That's about typical for a TN system. Mine keeps MP at or below 31.5 inches.
I take it you were describing systems that do not have this limitation.
A TN system will been a TC Lite :~)
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old October 4th 05, 02:44 PM
jmk
Right. A turbonormalized engine never sees any more pressure than one
that is normally aspirated - it just sees it up to a high altitude.
Cooling (at high altitudes) may be an issue, but not cylinder pressure.
Old October 6th 05, 02:42 PM
Paul kgyy
This is sort of OT, but the new Aviation Consumer this month has an
article on an SMA diesel installed in a C182. The SMA diesel uses 85"
MP on takeoff and pretty much stays there for the entire flight.
Old October 6th 05, 08:00 PM
John Doe
sort of OT?
"Paul kgyy" wrote in message
Ram Conversion Performance Specs? O. Sami Saydjari Owning 2 May 29th 05 04:37 PM
Why turbo normalizer? Robert M. Gary Piloting 61 May 20th 05 04:33 PM
Performance World Class design proposal iPilot Soaring 85 September 9th 04 09:11 PM
Kitfox 7/Rotax 914 Performance Questions Jim Carriere Home Built 2 January 22nd 04 04:55 PM
