On Fri, 07 Oct 2005 00:46:46 GMT, "Steven P. McNicoll"
wrote: "Ron Rosenfeld" wrote in message .. . If I understand your scenario properly, I have intercepted the FAC about 15 miles South of DEPRE and then turned inbound (to the N, towards DEPRE). I am at 3000'. At 5 miles from DEPRE I am cleared for the approach. I should be below the GP at that point so I would just continue along until intercepting the GP, and then descend into the airport. The presence of an aircraft behind me is irrelevant. What is your point? Why did you not execute the procedure turn? You've not been vectored to a final approach course or fix, you're not an a segment marked NoPT, and you've not been cleared for a timed approach from a holding fix. Is it not your position that if the procedure has a PT charted it must be flown unless one of those applies? I would have assumed this was a "radar vectors to final" situation and queried ATC to verify, since they didn't use the magic words that I understand to be necessary for me to assume radar vectors. But ATC has had me lined up with the FAC for quite some distance; I've been in radar contact; I've been assigned an appropriate altitude to intercept the GP from below; I've not crossed any IAF prior to DEPRE. If that confirmation is not forthcoming, then I would inform ATC that I am obliged to execute a procedure turn at DEPRE. I would maintain my last assigned altitude of 3000' until crossing DEPRE. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Ron Rosenfeld" wrote in message news ![]() I would have assumed this was a "radar vectors to final" situation and queried ATC to verify, since they didn't use the magic words that I understand to be necessary for me to assume radar vectors. Why would you have assumed it was a "radar vectors to final" situation if they didn't use the magic words that you understand to be necessary to assume radar vectors? You're not being vectored in this situation, that should be clear. But ATC has had me lined up with the FAC for quite some distance; I've been in radar contact; I've been assigned an appropriate altitude to intercept the GP from below; I've not crossed any IAF prior to DEPRE. The approach controller did nothing to line you up with the FAC. He simply told you to intercept the FAC as your previous clearance of direct GRB VORTAC crossed it some fifteen miles from the LOM at a shallow angle. If that confirmation is not forthcoming, then I would inform ATC that I am obliged to execute a procedure turn at DEPRE. I would maintain my last assigned altitude of 3000' until crossing DEPRE. And when they informed you that you weren't being vectored you'd proceed to fly the PT turn, which upon completion you'd be in the exact same position. Of course, that wouldn't happen. Upon informing ATC you felt obligated to fly the PT they'd vector you out of the way of the following traffic. Then they'd either vector you back to the FAC, which would prohibit flying the PT, or send you direct to the IAF so you could happily fly your PT without endangering anyone else. |
... On initial contact you're told "descend and maintain 3,000 join the runway
36 localizer"... As I understand things, the PT is what you do when a course reversal is required. So, is a course reversal required here? I think not. Therefore I would not do a PT - I'd just fly the localizer when cleared for the approach. When doing a PT, the manner of turn is up to the pilot (90-270, 45-180-45, racetrack, immelman). So what is special about a PT? It's just a U-turn (within the protected area), and not even a special kind of U-turn. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message . .. As I understand things, the PT is what you do when a course reversal is required. So, is a course reversal required here? I think not. Therefore I would not do a PT - I'd just fly the localizer when cleared for the approach. Then you'd be in agreement with the thousands that have actually flown this example. I've never heard of anyone that decided to fly the PT, and never heard of anyone violated for not flying the PT. |
example. Ok, now let's change the example a bit. This time, on initial contact you're told "maintain 5,000 join the runway 36 localizer" Then, five miles from DEPRE the approach controller says "AWI123 cleared ILS runway three six contact tower one one eight point seven." You acknowledge, then lose coms. Dive? PT? Racetrack? Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message . .. Ok, now let's change the example a bit. This time, on initial contact you're told "maintain 5,000 join the runway 36 localizer" Then, five miles from DEPRE the approach controller says "AWI123 cleared ILS runway three six contact tower one one eight point seven." You acknowledge, then lose coms. Dive? PT? Racetrack? I don't get in that position. When I'm about nine miles from DEPRE, as I'm about to intercept the GS at 5,000', I ask the controller if I'm cleared for the approach. He responds, "AWI123 cleared ILS runway 36 approach", and I start down on the GS. When my comm radios mysteriously fail four miles down the road while all my other avionics continue operating flawlessly I just continue on a normal ILS approach and land. |
Steven P. McNicoll wrote:
Alright, here's a real world example for you. You're flying AWI123 from KORD to KGRB, Chicago departure puts you in the east departure track on a 360 heading and hands you off to Chicago Center. Around the Kenosha, WI, area Chicago Center tells you to proceed direct to GRB VORTAC. Down the road a piece you're handed off to Green Bay approach. At GRB the ILS RWY 36 approach is in use, and the approach controller notices you're present track will intercept the localizer about fifteen miles from DEPRE, the LOM/IAF. On initial contact you're told "descend and maintain 3,000 join the runway 36 localizer". About three minutes later you hear the same instruction issued to EGF456. When you're about five miles from DEPRE the approach controller says "AWI123 cleared ILS runway three six contact tower one one eight point seven." When you reach DEPRE will you continue towards the runway or will you start a procedure turn? As someone who knows a couple of AWI pilots, I can tell you what they would do. They'd point her one or two LRCH's to the left of DEPRE, peg it a 250 kts to stay ahead of Eagle, a couple of miles from DEPRE chop the power, deploy the airbrake, flaps, gear, some more flaps, stable at 1000', make the first turn-off, and be at the gate drinking Starbucks while the rest of you try to make up your minds about flying a proceedure turn or not. |
GPT (Gulfport MS) ILS 14 question | A Lieberman | Instrument Flight Rules | 18 | January 30th 05 04:51 PM |
Required hold? | Nicholas Kliewer | Instrument Flight Rules | 22 | November 14th 04 01:38 AM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
IFR in the 1930's | Rich S. | Home Built | 43 | September 21st 03 01:03 AM |
