Full deflection = missed approach ???
Old October 18th 05, 01:43 PM
Peter R.
Default Full deflection = missed approach ???
"Steven P. McNicoll" wrote:
"Peter R." wrote in message
As you know, when first being vectored for the ILS, most times the
glideslope will be pegged.
What are you using for guidance when you're being vectored for the ILS?
The method of guidance was not a stated criterion in this thread.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old October 19th 05, 03:17 AM
Steven P. McNicoll
Did it have to be? Full deflection of the localizer or glideslope is rather
meaningless when neither is being used for guidance.
Old October 19th 05, 10:14 PM
S Narayan
"Steven P. McNicoll" wrote in message
hlink.net...
Nothing, you are on a vector. You have to trust the controller that he (or
she) knows what he's doing and doesn't forget about you. It would be wise to
be situationally aware by using GPS or VOR radials (or other means) to tell
if you are likely to run into rocks.
Old October 20th 05, 04:55 AM
Steven P. McNicoll
"S Narayan" wrote in message
news:1129756596.12a76fd6c4f812e4bd3f4ab173da5476@t eranews...
to be situationally aware by using GPS or VOR radials (or other means) to
tell if you are likely to run into rocks.
Correct. You are not yet using the glideslope or localizer for guidance so
a full deflection of either is meaningless.
Old October 20th 05, 10:00 AM
Also, a lot of the high end stuff won't even try to resolve deflections beyond a
certain angle, so the needles are centered with off flags even though there's a
LOC ident.
Old October 20th 05, 10:02 AM
TCAS, or even a Garmin 296, removes a lot of concern about rocks during
vectors. A moving map of the MVA would even be better and is being evaluated by
some high-end avionics vendors.
Old October 20th 05, 11:00 AM
Peter Clark
vectors.
Rocks have transponders? Cool!
Old October 13th 05, 02:36 PM
jmk
I see another case where, while you may want to abandon the approach,
you may not want to automatically fly the missed approach. The issue
would be a full L/R deflection, especially significantly before the
MAP, in mountainous terrain. A missed approach procedure which calls
for a left or right climbing turn may put you into the granite, where
the correct option would be to get back closer to the centerline and
maybe closer to the official MAP point first.
Old October 13th 05, 05:28 PM
Curtis Dean Smith
This happened to me just the other day. The FAF of a VOR approach is
the station, so the needle goes full deflection as you reach FAF. You
then have to wait until about 1/3 of the way to MAP before it comes
back in. As long as you were stabilized before loosing the needle,
you just have to stick it out. Of course, one problem is that, with
strong winds, you begin your dive at the FAF, winds shift, and you may
very well come out quite a bit off the center.
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 03:54 AM
Why an NDB approach with a miss to an intersection? Ben Jackson Instrument Flight Rules 10 March 25th 04 03:53 AM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 05:22 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
