#21
he did not land "wrong", the tower cleared him to land, and had forgotten
about the one waiting for take off clearance.. sitting in the Position and Hold wish I could remember what year that was BT "Mike W." wrote in message ... Always a good idea to approach the runway, or stop at the hold line, at an angle that allows you a clear view of final. When I am done doing my run up, and I call tower and am rolling up, I do kind of an 'S' turn so I can see for myself that there is nothing there. And I look both ways before going out onto the runway. Yes, planes do land the wrong way occasionally, even at a towered facility. -- Hello, my name is Mike, and I am an airplane addict.... |
hOn Tue, 11 Oct 2005 19:57:41 GMT, "Steven P. McNicoll"
wrote: Where are older taildragger pilots taught to do a 360 to scan the pattern prior to takeoff when instructed to position and hold? Why is this taught? I was never taught this, but I sometimes do it, most often when I want another look at the windsock (which is directly behind me if I take the shortest route to the runway. What would be difficult, in a taildragger, is to turn 180 degrees and back again. Going around is a piece of cake. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
prior to takeoff when instructed to position and hold? Why is this taught? I do this all the time, control tower, uncontrolled... all the time. Yes, I listen to the radio and keep traffic situational awareness in mind, but I have also "discovered" a JET making RIGHT traffic to runway 33 at Fort Collins - Loveland airport (FNL), when the PUBLISHED and locally-used pattern is LEFT traffic! As I am also a local FAA Aviation Safety Counselor, I also interviewed the crew each time on the ground. Once they were unfamiliar and they were on the wrong frequency. Twice they were cowboys and asserted "We're IFR, traffic patterns don't apply to us". So, I wrote my letter to the FAA and filed an ASRS report... and they were visited and remineded by the FAA about proper procedures. NO, they weren't on an instrument approach they were just going to land at the airport and scatter the little airplanes out of their way. Best regards, Jer/ "Flight instruction and mountain flying are my vocation!" Eberhard -- Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO CELL 970 231-6325 EMAIL jer'at'frii.com WEB http://users.frii.com/jer/ C-206 N9513G, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor CAP-CO Mission&Aircraft CheckPilot, BM218 HAM N0FZD, 234 Young Eagles! |
"Brien K. Meehan" wrote:
zatatime wrote: No where that I know of. At a towered airport you need trust in the tower. I must say this is unsafe advice. I've avoided being squished by landing aircraft TWICE by checking before taking the runway at towered airports. Always, always, always make sure no one is landing before you take any runway. YOU are responsible, not the tower controller, for the safety of your flight. Exactly, I was in a commercial jet that was told to P&H on the runway. Soon thereafter the plane taxied to the first turnoff and I saw another plane on final. I can be on the runway and airborne quickly. P&H is asinine. If the traffic flow is thatv busy then build a new runway...or stagger flights better. Ron Lee |
On 11 Oct 2005 15:47:53 -0700, "Brien K. Meehan"
wrote: zatatime wrote: No where that I know of. At a towered airport you need trust in the tower. I must say this is unsafe advice. I've avoided being squished by landing aircraft TWICE by checking before taking the runway at towered airports. Always, always, always make sure no one is landing before you take any runway. YOU are responsible, not the tower controller, for the safety of your flight. My comments were directly related to doing 360's on an active when issued a position and hold clearance. I didn't go through every detail of what should occur before that clearance was issued. I too have refused a clearance with an airplane on short final at least once in my life. I'm not trying to start a flame war for the thread since, as is typical in usenet, comments are made and taken out of context, however Mike W. summed it up very well: snip Always a good idea to approach the runway, or stop at the hold line, at an angle that allows you a clear view of final. When I am done doing my run up, and I call tower and am rolling up, I do kind of an 'S' turn so I can see for myself that there is nothing there. And I look both ways before going out onto the runway. As far as 360s on a position and hold clearance, I wouldn't do it....There's a better way to see oncoming traffic than that. z |
"Cub Driver" wrote in message ... I was never taught this, but I sometimes do it, most often when I want another look at the windsock (which is directly behind me if I take the shortest route to the runway. What does the tower say about it? Why don't you just ask the controller for the wind? What would be difficult, in a taildragger, is to turn 180 degrees and back again. Going around is a piece of cake. Turning into a stiff wind is a piece of cake. Turning around in one may be impossible. |
wrote in message ... I do this all the time, control tower, uncontrolled... all the time. Haw many times has the tower chewed you out for it? Who issues the position and hold instructions at the uncontrolled airports? As I am also a local FAA Aviation Safety Counselor, And you advocate acting contrary to ATC instructions? Shame on you! |
#28
"Ron Lee" wrote in message ... Position and hold (P&H) is an accident waiting to happen. How much time does it take to wait at the holding line then move into position and depart versus P&H and depart? 15 seconds? Larger aircraft can take significantly longer. It all adds up, dropping position and hold will significantly reduce airport capacity and cause significant delays at busy airports. I prefer to verify that the approach path is clear before venturing out on the runway and departing. If you're uncomfortable with position and hold all you have to do is avoid controlled airports. |
#29
"Ron Lee" wrote in message ... Exactly, I was in a commercial jet that was told to P&H on the runway. Soon thereafter the plane taxied to the first turnoff and I saw another plane on final. How do you know it was instructed to position and hold? Do you know why it taxied off the runway? I can be on the runway and airborne quickly. P&H is asinine. If the traffic flow is thatv busy then build a new runway...or stagger flights better. Fine. It's your job to convince the locals they need a new runway or convince the operators to cut flights. Have at it. |
#30
Steven P. McNicoll wrote:
"Ron Lee" wrote in message ... I prefer to verify that the approach path is clear before venturing out on the runway and departing. If you're uncomfortable with position and hold all you have to do is avoid controlled airports. As PIC, you always have the option of refusing the request from ATC. You can simply reply with "Tower, N1234A would prefer to hold short until cleared for departure." Of course, at a busy airport, you have to wait a while, and you won't make any friends in the tower... -m -- ## Mark T. Dame ## VP, Product Development ## MFM Software, Inc. (http://www.mfm.com/) "Eagles may soar, but weasels don't get sucked into jet engines." |
| Thread Tools | |
| Display Modes | |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| "position & hold" going away | Paul kgyy | Piloting | 86 | August 29th 05 03:43 PM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| Position and Hold at uncontrolled field | dave | Piloting | 42 | February 26th 04 02:25 AM |
| Coordinated turning stall and spins | Chris OCallaghan | Soaring | 20 | November 18th 03 09:46 PM |
