Runway ID
Old October 17th 05, 02:44 AM
Morgans
Default Runway ID
"Steven P. McNicoll" wrote
"On a single runway, dual parallel runways and triple parallel runways,
designation number is the whole number nearest one-tenth of the magnetic
azimuth when viewed from the direction of approach."
Roger that.
What was being discussed, was -renaming- a runway, due to the -changing-
magnetic variation.
Jim in NC
Old October 17th 05, 02:21 AM
Steven P. McNicoll
Default Runway ID
"Morgans" wrote in message
Roger that.
magnetic variation.
Yes, that's what I addressed. It says, "the designation number is the whole
number nearest one-tenth of the magnetic azimuth". It offers no exceptions.
Old October 16th 05, 10:56 PM
Newps
Default Runway ID
Morgans wrote:
"Newps" wrote
You would choose the number to which the magnetic variation is taking
the runway. For example around the western US you would choose the
higher number as if you don't you'll have to renumber the runway that
much sooner.
What??? You don't rename a runway after it has been named.
You most certainly do. Our parallel runways here at BIL were renumbered
from 27 R+L to 28 R+L several years ago. They did this at the same time
they rotated the VOR for the same reason. Another example is MSP. The
parallel runways there were 11/29 until a few years ago when they were
renumbered to 12/30
Old October 16th 05, 11:31 PM
Martin Hotze
Default Runway ID
and another one is PHX, IIRC.
#m
Repeat an assertion four times and it becomes a fact. Repeat an assertion
four times and it becomes a fact. Repeat an assertion four times and it
becomes a fact. Repeat an assertion four times and it becomes a fact.
Old October 17th 05, 02:50 AM
Morgans
Default Runway ID
renumbered to 12/30
I have never heard of that, before now. I'm sure they must do that to make
people keep buying new, up to date charts. g
Jim in NC
Old October 17th 05, 03:09 AM
Mike W.
Default Runway ID
The thing that causes runways to get renumbered is the fact that the
magnetic variation itself, shifts. It may shift six minutes ( a tenth of a
degree ) per year. So after ten years, the local mag. variation may change
from 6° W to 7° W . So every few years, runways get assigned new numbers.
This gradual shift varies by locality on the globe. Areas that are
volcanically active can have huge shifts of 30 minutes or more per year.
"Newps" wrote in message
news
much sooner.
Old October 16th 05, 05:27 AM
Steven P. McNicoll
Default Runway ID
"Mike W." wrote in message
No, Bill has this right. If rounded correctly, 045 becomes 'runway 4' and
055 becomes 'runway 6'.
So why is it correct to round 045 down to 'runway 4' and 055 up to 'runway
6'?
Old October 16th 05, 03:53 PM
GeorgeB
Default Runway ID
On Sun, 16 Oct 2005 04:27:48 GMT, "Steven P. McNicoll"
6'?
Ah, because the REAL rounding rule, designed so that averages will not
become distorted high from rounding 1/2 up, is to round 1/2 to the
EVEN number.
I know of almost no teacher nor textbook that remembers this, much
less why it is so.
Old October 16th 05, 04:16 PM
Jose
Default Runway ID
EVEN number.
less why it is so.
That's because it's not so.
The standard rounding rule is 5 goes up.
The catch is that you ONLY round from the digit after the one you're
rounding to. For example, .2447 rounds to .245 or to .24 or to .2
although a common error is to round (to the hundredths) as .25, because
the "rounded to the thousanths" version would end in a five. When
rounding, always round from the source, not an already adulterated version.
Jose
Money: what you need when you run out of brains.
Old October 17th 05, 02:56 AM
Mike W.
Default Runway ID
"Jose" wrote in message
EVEN number.
less why it is so.
If you have 0.245, it is 0.24 rounded to hundreths. How is that '5 goes up?'
The rounding rules I am talking about are for preventing rounding bias in
data. If you took a big pile of numbers, rounded them all up, added them,
you would have a value that was way off of the true value of the sum.
0.247 0.25 0.2550.26 is that what you mean? That's exactly what I
stated.
version.
Jose
Yes, you don't round a number, then round it again.
"GeorgeB" wrote in message
If these runways were at the same field, your method would have runway
designators that differ by twenty degrees for runways that have a difference
in azimuth of only ten degrees. I think I'd round both in the direction
that local magnetic variation was moving.
Yes, that would be logical.
Pilots Slick Piloting 4 November 20th 04 11:21 AM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 05:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Piloting 114 July 22nd 04 05:40 PM
Rwy incursions Hankal Piloting 10 November 16th 03 02:33 AM
