Should a W&B list gross weight?
Old October 19th 05, 01:49 AM
Ron Rosenfeld
Default Should a W&B list gross weight?
On Tue, 18 Oct 2005 15:54:02 -0400, Andrew Gideon
Ron Natalie wrote:
Well since the max weight or CG doesn't change (unless you're doing a
major modfication), just the empty weight, the equipment list with a ne
emtpy weight/moment would seem not to need to duplicate that information.
That's the conclusion to which I've been coming. I'd be more comfortable,
though, if I found something (ie. in part 43) which discussed what to do
when the maximum gross weight is altered. Since two of our club aircraft
have had such upgrades, it would just be more clear to me if I could see
the distinction drawn between modifications that do and do not alter gross
weight.
What does the STC say? (I think they are available on line if you could
post the info regarding the STC).
I'd also have liked to see some mechanism whereby a line was drawn for those
modifications which might or might not impact gross weight. Yes, it should
be obvious. But that uses common sense, and I fear the outcome should I
make the mistake of applying common sense to legal (esp. FAA {8^) matters.
- Andrew
Old October 16th 05, 06:29 PM
Andrew Gideon
Ron Natalie wrote:
Mine doesn't.Â*Â*TheÂ*grossÂ*weightÂ*andÂ*theÂ*CGÂ*enve lopeÂ*areÂ*listedÂ*inÂ*the
operating limitations book.Â*Â*Â*TheÂ*TypeÂ*CertificateÂ*requiresÂ*the
equipment list AND the operating limitations book.
But what documentation is required for aircraft changes which alter the
empty weight and CG? If that documentation doesn't list the gross weight,
is it safe (ie. safe in a ramp check {8^) to assume that it's unchanged?
- Andrew
Old October 16th 05, 10:48 PM
Newps
Andrew Gideon wrote:
Ron Natalie wrote:
Mine doesn't. The gross weight and the CG envelope are listed in the
operating limitations book. The Type Certificate requires the
You're talking empty weight. Gross weight is the max the airplane can
weigh.
Old October 17th 05, 12:32 AM
Andrew Gideon
weigh.
No, I'm not. That's part of the problem. It is completely reasonable to
expect, with work that involves neither airframe nor powerplant, that the
gross weight won't change (even though empty weight has). But is it
*legal* to operate under that assumption, or must a new W&B list the "new"
gross weight even if it is not changed?
It appears, from some of the other postings, that a new W&B need not
describe the gross weight if it's not altered. I (and some others) have
merely been "spoiled" by always seeing the gross weight on any W&B.
- Andrew
Old October 17th 05, 01:23 AM
Mike W.
I am not sure why you are so worried about the gross weight. You have
documentation for the new empty weight and CG, right? So whatever you decide
to put in the airplane, animal, vegetable or mineral, you can weigh and/or
calculate to do your W&B for a particular filght. As long as you are inside
the CG envelope and not over takeoff weight (and can show your work) you
should have no hassles. Right?
"Andrew Gideon" wrote in message
gonline.com...
weigh.
- Andrew
Old October 18th 05, 11:22 PM
Mike W.
A new weight and balance.
online.com...
- Andrew
Old October 17th 05, 02:33 AM
Ron Rosenfeld
On Sat, 15 Oct 2005 19:51:19 -0400, Andrew Gideon
Some work was done on an airplane. The new W&B is of the "removed/added"
sort and computes a new empty weight and moment arm. But the document
doesn't state the gross weight.
The changes were all avionics; no airframe or power plant work was done. So
I'd expect the gross weight to remain unchanged from the prior W&B.
But does the new W&B need to state the gross weight, even if it is
unchanged? If not, do we then need both documents to cover the legalities
of documentation in the airplane?
Or did the person that wrote the new W&B err?
- Andrew
The aircraft gross weight, also called maximum weight,is the maximum
authorized weight of the aircraft and all of its equipment as specified in
the Type Certificate Data Sheets (TCDS) for the aircraft.
It is usually listed on the loading graph or chart supplied by the
manufacturer, or perhaps elsewhere in the POH/AFM.
The FAA publishes a handbook (FAA-H-8083-1) on weight and balance. With
regard to GA aircraft, the following seems to pertain:
"Weight and Balance Revision Record
"Aircraft manufacturers use different formats for their weight and balance
data, but Figure 5-2 is typical of a weight and balance revision record.
"The weight and balance revision sheet should clearly show the revised
empty weight, empty weight arm and/or moment index, and the new useful
load."
HOWEVER, figure 5-2 shows NO sign of an entry of useful load (or maximum
weight). It shows the old empty weight of the airplane; the various
adjustments for removal and addition of various avionics with regard to
weight, arm and moment; and the computed new empty weight, moment and CG of
the aircraft.
And you were looking for clarity?
Good luck. Bottom line -- it's probably not a requirement. And changes in
allowable maximum weight should be reflected in the STC data for the
modification that allowed that change; and documented according to the
requirements in that STC.
"We're from the FAA, and we're not happy until you're not happy!"
Old October 17th 05, 02:56 AM
Andrew Gideon
Laugh Yes.
- Andrew
Old October 18th 05, 12:07 AM
Mike W.
Let it go, Louie. Let it go.
online.com...
Laugh Yes.
- Andrew
Old October 20th 05, 03:08 AM
Fly
Here is another one for youse guys..
What requirement is there that mandates a recomputation of the W&B?
The below mentioned handbook states a percentage change, but that will
calculate to be more than any simple radio change! IIRC, About 1/2 percent
of the maximum gross weight.
I have stopped putting useful load and gross figures on the weighing data
sheets that I sign off.
Take for instance, some turbo sytems allow a gross weight increase. Some
tip tank systems allow a gross weight increase. Some jet paperwork allows
for a gross weight increase.
Beechjet 400 can have a 200 pound takeoff weight increase. All it consists
of is paperwork.
It means another person can be carried.
Wanna know how much. A few years ago, $8k. now about $12K. !!
How do I know this/ I weigh one and put tdown the max takeoff weight,
useful load etc.
A few days later the operators called me and asked for a revision of my
document.
gee whiz
Kent Felkins
Tulsa Ok
s more mentions
"Ron Rosenfeld" wrote in message
So
legalities
- Andrew
load."
of
the aircraft.
in
Gross Weight Fred Choate Piloting 153 July 14th 05 12:19 AM
Max gross weight Chris Piloting 21 October 5th 04 08:22 PM
Apache Alternate Gross Weight Jim Burns Owning 1 July 6th 04 05:15 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 07:32 PM
