Just got engines for my T310-Q (TSIO 520-B). I had light Crankcases and non
VAR Crankshafts, so I couldn't get any core credit for either. So overhaul was not an option. Called AirPower and found that there are no new TSIO 520-B's available. So I opted for factory remans. They dont care if the cases are light or the cranks are non VAR. $31,000 each, included the Turbo's. I was about 150 hrs over TBO and have replaced 5 cylinders in the 800 hrs I have owned the airplane. I had 2 first run rebuilt Milleniums that never really had good compressions, so we didn't do that any more. The 3 new continentals are still on the old engines and still have compressions over 75. That's just my experience your milage may vary! Call a couple of the places and ask you may not get core credit for the cracked case. Good Luck Mark Manes N28409 "f" wrote in message ... Today was not a good day for the Baron. While replacing a cylinder I found a crack (confirmed with Dye Pent) off the #5 cylinder leading up towards the case halves. The engine has 2750 Hr since new and about 1000 Hr since a TW Smith overhaul. The case is repairable, but it seems like a waste to not do the overhaul. The question is has anyone recently purchased a Factory New engine? The cost is about $4K more but the parts are not a mix of old parts. The engine is an IO-470L. Any thoughts and opinions will be a great help. Paul |
Opinion:
If you have a first run engine, you are a good candidate for a fancy overhaul. And you keep track of where all your low time parts are... they are in YOUR engine. If you have a rotten old engine, you are better off to go back to the till for newer parts. A factory reman. It usually is cheaper. Horror stories abound on both sides of this one. YMMV. Bill Hale |
Bill:
Good points and ones that really help to make my decision. I have a second run engine that has had problems it's whole life. When I bought the plane I priced it expecting the engine to fall short of TBO. This is not a surprise, but I hate being without the plane. I decided on the Superior Millennium Engine program. It is about the same price as a factory remanufactured engine, but the specs and warranty are better then the factory. Wish me luck and I'll report on how well it comes out. I must admit I was leaning towards a new engine, but I made two calls to providers of new factory engines and the only way to guaranty a speedy delivery date was to pay a 10% up charge. The thought of paying $31K for the engine and another $3,100 for a three to four week delivery was the deciding negative factor. Thanks to all for the help, suggestion and good thoughts. Paul Mandel N43BS wrote in message oups.com... Opinion: If you have a first run engine, you are a good candidate for a fancy overhaul. And you keep track of where all your low time parts are... they are in YOUR engine. If you have a rotten old engine, you are better off to go back to the till for newer parts. A factory reman. It usually is cheaper. Horror stories abound on both sides of this one. YMMV. Bill Hale |
I had good communication w/ Superior. I say communication b/c I didn't need
any warranty work. The 50,100, 250,500 hr reports w/ add to your maint. cost although they do provide the pre-paid sample kits for required oil analysis. -- Thx, {|;-) Victor J. (Jim) Osborne, Jr. "f" wrote in message .. . I decided on the Superior Millennium Engine program. It is about the same price as a factory remanufactured engine, but the specs and warranty are better then the factory. Wish me luck and I'll report on how well it comes out. Paul Mandel N43BS |
Gyrocopter Speed | Mark | Rotorcraft | 36 | August 16th 05 11:28 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
