"Ron Lee" wrote in message ... Position and hold (P&H) is an accident waiting to happen. How much time does it take to wait at the holding line then move into position and depart versus P&H and depart? 15 seconds? Larger aircraft can take significantly longer. It all adds up, dropping position and hold will significantly reduce airport capacity and cause significant delays at busy airports. I prefer to verify that the approach path is clear before venturing out on the runway and departing. If you're uncomfortable with position and hold all you have to do is avoid controlled airports. |
| Thread Tools | |
| Display Modes | |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| "position & hold" going away | Paul kgyy | Piloting | 86 | August 29th 05 03:43 PM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| Position and Hold at uncontrolled field | dave | Piloting | 42 | February 26th 04 02:25 AM |
| Coordinated turning stall and spins | Chris OCallaghan | Soaring | 20 | November 18th 03 09:46 PM |
