carb ice experience
Old October 24th 05, 11:21 AM
Cub Driver
Default carb ice experience
On Sun, 23 Oct 2005 15:54:42 GMT, George Patterson
Now what was the difference between that experience and the ordinary
one where the rpms drop, then rise back to 1500?
The Selway Kid just mentioned that carb heat application also bypasses the air
filter in most aircraft. IMO, the most likely problem here is a clogged filter.
Yes, it bypasses the filter on the Cub.
Now you scare me. Clogged filter? Got unclogged?
(Must be more to carb heat than that. Bypassing the filter ought to
increase performance in every instance, or at least never decrease it.
But pulling carb heat on, in the Cub, does definitely cause a decrease
in power. In a go-around, the climb picks up as soon as I kick the
carb heat in.)
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
In Search of Lost Time: www.readingproust.com
Old October 24th 05, 03:51 PM
George Patterson
Yes.
in power.
The heat normally creates a rich mixture, which causes a decrease in power.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old October 24th 05, 04:54 PM
Jonathan Goodish
In article jy67f.6582$%A1.1101@trndny01,
in power.
The reduction in power caused by the application of carb heat is mostly
due to the decrease in air mass flow through the engine, i.e. a
reduction in volumetric efficiency.
JKG
Old October 24th 05, 05:32 PM
Orval Fairbairn
Yes.
in power.
George Patterson
If the carburetor attach flange nuts are loose, the mixture will be very
lean, due to air leaks around the base. Applying heat will enrich the
mixture, possibly correcting a too-lean condition. I have seen a few
planes with loose carburetor attach nuts.
Old October 24th 05, 05:03 AM
Robert M. Gary
I got carb ice almost every time I flew the cub. On cold 6am flights,
the Cub just loved to suck up the ice. I learned to leave the carb heat
in during touch-n-go operations until climbing out because I lost the
engine once after shutting off the carb ice as I was moving the
throttle forward. The engine ran far enough to get me 300 feet up then
started to die. Luckily, turning around at 300 feet is very easy in a
Cub, not so easy in a Mooney. I kept a timer for cruise and ran 15
minutes heat off then 15 minutes heat on. I would also often get ice in
the time it takes to taxi to runup. I learned to clear out with heat
first. For some reason, the cub got ice much more than the Aeronca with
the same engine, I think it has something to do with how heat moves
around in the cowl.
-Robert
Old October 24th 05, 11:19 AM
cjcampbell
Cub Driver wrote:
But the other day, first cold day, I had quite a different experience.
The engine may have been running rough when I taxied--hard to know
with earphones, but I had a feel it was rough. Did the mag check.
Pulled carb heat on. Whoom! Rpms went up to 1700.
The reason it zooms back to 1700 is that the ice melted and you were
giving it enough gas for 1700. The engine running rough on taxi is a
good indication of that, too. The rpms may have dropped momentarily,
but the ice release was apparently very sudden and it appeared to have
just gone up. Did the rpms increase again when you turned carb heat
off? They should have.
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 01:48 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 07:26 PM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
Carb Temperature Gauge fly_the_skies Home Built 6 January 14th 04 03:32 PM
