On Mon, 24 Oct 2005 22:19:12 +0000 (UTC), (Paul
Tomblin) wrote: In a previous article, Ron Rosenfeld said: An FIP map that I downloaded last night valid at 0900Z showed significant icing probability along your route at 6,000', although it did look doable at 3,000'. The MEA between CTR and ALB is 6,000 though. I'm looking at the possibility of going VFR to the Hudson Valley and then the Mohawk Valley. But there are still those hills to the south of Rochester. Thanks for you advice and everybody else's on this thread. I feel like I've made the right decision, but it's easy to second guess yourself. For sure you made the correct decision. It's a losing game to try to second guess yourself, especially with ice. If you've got clear cut outs, then it may be worth a try. That usually means MEA's above the freezing level, which was NOT the case in your situation. It might also mean an a/c that you know can get above the clouds; thin layers; etc. But in the lee of the Great Lakes one year I picked up enough ice to drop my IAS by about 30 kts. Those lakes are great ice-makers -- better than my refrigerator! You'll do well to treat them with respect. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
(Paul Tomblin) wrote: In a previous article, Ron Rosenfeld said: An FIP map that I downloaded last night valid at 0900Z showed significant icing probability along your route at 6,000', although it did look doable at 3,000'. The MEA between CTR and ALB is 6,000 though. I'm looking at the possibility of going VFR to the Hudson Valley and then the Mohawk Valley. But there are still those hills to the south of Rochester. Thanks for you advice and everybody else's on this thread. I feel like I've made the right decision, but it's easy to second guess yourself. A few years back we were headed for Boulder Colorado and Jefco (BJC). We had diverted tot he south to avoid some heavy stuff to the north. This added a good 250 miles to the trip. We got a late start as my wife had to work in the morning and we weren't out of 3BS until near 2:30 or 3:00 PM. Other than passing through a line of thunderstorms just getting started and at least 3 or 4 hours before they were to be in the area the trip went fine. Well other than the 40 knot head wind. We decided to overnight in the Topeka area as I really didn't want to be getting into the mountain area after dark. The next morning found storms forecast for the entire route so we went airport hopping. Topeka to Salina where we topped off the tanks and had lunch. Things were improving by 1:00 or so and we were off to Hays KS where we spent another hour or so before heading to Goodland. We/I had hopped to go straight to Boulder, but some towering Q had slid off the mountains. We were close to 12,000 over Goodland, but no way were we going to get over or around the stuff to the west. It was just getting bigger and meaner. So we sat on the ground for a while at Goodland. A 182 headed out IFR while I was filing a VFR flight plan. (Below the clouds it was crystal clear) so we headed out with an eye on the map and every airport we passed with the closest to the south always in mind. (the weather got better fast going south). We stayed under the clouds, but by the time we passed Lyman CO, I was beginning to think about heading south to find higher ceilings. Just as I was about to turn the ceiling went up abruptly and visibility was a good 30 to 50 miles. Of course all we could see were those BIG BLACK TOWERING Cumulus. After we passed the south edge of the old Stapelton Airport visibility started getting a bit stinky, but was still legal. Denver APP was going to turn us loose, but I asked if we could hang around with them for a while longer as it was getting kinda stinky around there. They were kind enough to have us stay on frequency until we were recognizing landmarks in the BJC area (Rocky Flats) It was airport to airport and always watching for a way out, just-in-case. It's far better to err on the safe side than find yourself in deep doggie do. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Paul Tomblin wrote:
In a previous article, Ron Rosenfeld said: On Mon, 24 Oct 2005 01:37:41 +0000 (UTC), (Paul Tomblin) wrote: I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. Yes, they would have been much happier had you become an icing accident. Well, the guy who had it booked for Monday and Tuesday wrote to me that he'd been thinking of cancelling anyway because of the weather, so I feel better about that. This morning I look at the airmets, and there are two of them for icing, with a narrow little corridor between them straight between BAF and ROC. Not sure if I trust that narrow corridor to stay open, though. How good are the boundaries of airmets? Are you ever going to encounter the conditions outside the boundaries, or are they pretty conservative about them? I find the FAA weather guys to be pretty conservative about almost everything, but even the best weather folks are wrong as often as they are right. The FAA is especially conservative when calling for icing and this is a real pain with the ever stricter FAA and NTSB interpretations of "known icing." Now that forecast = known, it makes flying in the northeast illegal for about 5 months of the year. I tend to fly if there isn't rain at ground level and the freezing level is at or above the MEA or I can fly VFR. However, I've flown a lot in the winter and am reasonably comfortable taking on reasoned risk. Everyone's risk assessment and tolerance is different and only you know what you are comfortable with. If you are significantly concerned about making the flight, then I'd say that alone probably says it isn't worth it. Flying is supposed to be fun (unless you are getting paid for it) so why make a flight that will give you white knuckles on the yoke? MAtt |
Paul Tomblin wrote:
In a previous article, Robert Chambers said: Yeah I was thinking if you could get to Utica or somewhere a bit closer than BAF. The drive would be shorter if you have to leave the plane there and the drive back to retrieve the bird would be shorter as well. As I was driving out of the parking lot at Barnes, there was a fair chunk of blue sky to the west. I was really tempted to fly west and see how far I could get VFR with maybe a popup IFR clearance for an approach somewhere and rent a car there, and that's what I would have done if I were alone. But my wife doesn't like the uncertainty of not knowing whether we're going to find a rental car or a motel room. On the drive home, we drove through some high hills with low clouds down below the peaks and cold rain, and figured that being in the car was probably the best decision. I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. I might go down on Wednesday and give it a try to see how far I get. I flew from ELM to LEB on Friday for the weekend. Woke up at the hotel in Montpelier, VT Sunday morning to 3" of snow! Luckily, as we drove back south to the airport we ran out of snow and into light mist. I was iffy on attempting the flight home given the low clouds and freezing level, but a twin had departed shortly ahead of me for PA and reported on top at 10,000 with no icing problems. So, I decided to take a look and see how far I could get. Got a little rime at 6,000, but was soon between layers and had a pretty uneventful fight home. I did have to climb to 8,000 to stay between layers near Albany and eventually up to 10,000 to get on top prior to Binghamton, but the descent into ELM was through a thin layer with no problems. One just never knows in this part of the country this time of the year. You certainly can't fault any decision to cancel a flight this time of year in such conditions. I've flown a fair bit in this area and decided the risk was acceptable, but I did have the ILS 18 back into Lebanon on my approach clip as I was climbing out. :-) Matt |
