Off Airport Landings
Old November 3rd 05, 02:27 AM
Default Off Airport Landings
Dave
Easily falls under the "...dangerous and reckless..."
Old November 2nd 05, 03:55 PM
George Patterson
Kev wrote:
Now I have a question: if you're over a forest, is it still considered
better to mush into the tree tops? Or dive into the thick of it as
best you can?
The last time this came up, the best arguments I saw were to attempt a normal
landing in the treetops. Stalling the plane into the trees risks crippling or
death due to compression of the spinal column, and it requires much less
vertical force to kill you than it does horizontal force.
Of course, if your idea of a normal landing is to stall the aircraft just above
the runway, you shouldn't be doing a normal landing in the tree tops. You should
be coming in a few knots faster.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old November 2nd 05, 10:50 PM
Newps
Kev wrote:
Rarely heard tips:
Take off your headphones. If the plane stops quickly, they'll fly
forward off your head, ripping up your ears. Also, this prevents
strangulation from the cord.
Bull****. Been there, done that. You'll never feel it and it won't
hurt later.
best you can?
Fly the plane all the way to the crash. Never stall.
Old November 3rd 05, 12:19 AM
Matt Whiting
best you can?
I'd try to stall or be very close to a stall just as the wheels began to
brush the leaves.
Matt
Old November 3rd 05, 02:23 AM
Matt
How can you tell how high you are or how tall the trees are? If you are
near stall speed, it doesn't take much to cause a full stall and you
are just a passenger waiting for the impact!
Lots of trees in the western regions that exceed 150' and thats a long
way to fall on your nose!
Once your wheels make any kind of contact with the tops of trees, it
will feel like you're being sucked right down into them with a rapid
deceleration and lots of noise as things start tearing off and bending.
Old November 3rd 05, 06:53 PM
Matt
As a matter of fact, I ofen demonstrate slow flight with ZERO
indicated airspeed and make turns while doing so. And, I show it to
students to let them see what is possible.
Having a problem in picking out the quoted areas so bear with me? "The
idea is to fly slowly so as to not tear off the wings and fall to the
ground"? Where else are you gonna fall, and how can you prevent damage
to the airplane like tearing off the wings? I fear you have the image
of the common picture of that airplane sitting in the top of a tree
like it was intended to land there? The reality of it is, you will
crash to the ground or very near it!
As for touching the tops of the trees, I have done it and am more than
roughly correct. I've also had the experiences, many many times of
having my wheels contact crops as I was spraying, and felt the instant
drag forces that suck you down. Certainly we want to be going as slowly
as possible prior to impact but it is much better to do it under
control rather than on the edge and lose control at the first
disruption of our flight attitude and/or.airspeed.
Did you see the clips of the clown in Louisiana doing his abortive
takeoff attempt and wrecking his airplane in the process? I have no
sympathy or empathy for his ineptitude and careless operations. It
happened so fast he had no time to make any corrections and his speed
wasn't high enough for pieces to be torn off. The end result was the
same though. A wrecked aircraft that crashed into trees with extensive
damage to the plane and the vehicle/s he hit enroute to the accident
scene.
Old November 4th 05, 10:52 AM
Cub Driver
On Thu, 03 Nov 2005 11:25:37 GMT, Matt Whiting
I live in PA, so our trees are generally shorter. The goal is to land
slowly enough that you don't tear off the wings and fall to the ground.
I read somewhe "Picture an airport underneath you, and make the
best landing on it that you can." Sounded good to me, and easier to
remember than all that other stuff.
I'd picture it as a grass strip, too, not asphalt
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
In Search of Lost Time: www.readingproust.com
Here we go again Roger Piloting 39 April 7th 05 07:20 AM
Iowa City Airport in the News Dave S Piloting 0 April 6th 05 10:24 PM
WI airport closure Mike Spera Owning 0 March 9th 05 01:53 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Piloting 16 January 20th 04 04:02 PM
