antenna ground planes
Old November 4th 05, 12:44 AM
COLIN LAMB
Default antenna ground planes
A full wave antenna wound not be what you normally want. A 1/4 wave antenna
gives you a good omnidirectional pattern, with limited nulls off the end.
If you installed a full wave vertical ground plane on an aircraft, it would
have a bit of gain - up.
Remember that gain is not free. It is realized taking the energy from one
direction and increasing it in another. Which direction are you going to
take it from? Easy when you are at a fixed location. Not so easy when you
are flying around in an aircraft.
What you hope to accomplish in a good installation is th make sure all the
connectors are installed properly, the coax is good and the antenna is tuned
for the proper frequency.
Regarding the ground plane, sometimes you have to do the best you can. If
there is not enough vertical room for a dipole or a ground plane, you could
install a 24" wire vertically in the vertical tail and then install a single
24" wire in the horizontal axis, also in the vertical tail. That will not
be perfect, but sometimes you have to live with less. You could also have
one vertical wire and three horizontal wires, serving as the ground plane,
with one in the vertical tail and two in the horizontal tail.
Colin
Old November 4th 05, 06:56 AM
Rob Turk
"raptor" wrote in message
I wonder about something else. How long would a "full wave" antenna
have to be for aviation comm radios? I've got some old walkie talkies
that have those very long pull out antenna's, they must be 5 or 6
feet. Are those full wave?
The lenght of the antenna is proportional to the frequency used. Your
'walkie talkies' are most likely 27MHz CB type. A full wavelength would be
11 metres, which is a bit long to handle ;-)
On your plane, the comm frequencies are from 118MHz to 136MHz. The
wavelength in the middle of that range is about 2.35 metre. You can probably
hide a full wave antenna for that frequency in a fuselage but there's other
considerations like impedance and radiation pattern that influence the
decision. I'm sure Jim will be able to tell you the nitty gritty details, I
would have to look it up..
Rob
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
Ground Stops and Ground Delay Programs [email protected] Piloting 1 February 18th 05 01:29 AM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 12:27 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 05:21 PM
