Navajo Down in Ankeny, IA
Old November 9th 05, 04:00 AM
George Patterson
Default Navajo Down in Ankeny, IA
John Doe wrote:
But once again, another twin that fails to make it back to an airport. Why
is it again they have two?
'Cause nobody makes single engines with that much power.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old November 10th 05, 06:46 PM
Why is it again they have two?
Of course you're ruling out turboprop singles, right George? : )
I was amused by the original post quoting FAA records saying the Navajo
had a 160mph cruise speed. My pal's PA-31 has no problem maintaining
180kt in cruise, or around 200mph. Feds.... Sheeesh...
Old November 15th 05, 05:44 PM posted to rec.aviation.piloting
Update: Today's (Tu 11/15) Des Moines paper notes the dipstick was
missing from the plane at the crash site and was found at the airport.
Not in the reports yet: whether the dipstick was found on the ramp or
taxiway where it might've rolled if someone forgot and left it on a
cowling during a preflight, or if it was in the mechanic shop. Report
says the engine oil was "dangerously low," with only 1-2 quarts found
by the NTSB investigators. Pilot had reported an oil leak shortly
after takeoff.
Also not in the news reports: any indication, guess or wild
assumptions whether one engine had stopped. For that, I salute the
local reporters. Just the facts.
Old November 9th 05, 03:15 PM
Jim Burns
The accounts that I've read do not mention any roll or "Vmc" roll, they all
seem to indicate that the airplane was upright and controlled until impact.
Successful single engine operation in twins requires both control and
performance. Usually a configuration that increases control decreases
performance and vise versa. I did not read anything about of loss of
control, only lack of performance. Whether their airplane was configured
properly to obtain the performance required and whether it was capable of
obtaining the required performance, I think, are the questions.
The Navajo, configured properly, "should" be controllable and capable of a
climb of around 250 fpm with full power on the good engine, sea level,
standard conditions, at full gross weight. Ankeny is about 900 feet, temps
were in the 50's, accounts say only two people on board, no mention of
weight or baggage.
If it was an engine out situation would be interesting to know if the bad
engine's prop had been feathered, if the gear and flaps were up or down, and
if the operating engine was making full power. For those in the group that
are not familiar with single engine operations in twins, excess drag created
by a windmilling prop, extended flaps, and extended landing gear can, and
probably will, create more drag than a single engine can overcome. The
airplane may be longitudinally controllable if kept above the Vmc speed for
the conditions and configuration, but the airplane may be so "draggy" that a
climb is not only impossible but it is descending at a abnormally high rate.
"Jay Honeck" wrote in message
2 guys killed in an attempt to return to the airport on a single
engine.
http://www.kcci.com/news/5281008/detail.html#
My condolences to the families.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Prelim NTSB report on the Piper Navajo crash landing gregg Piloting 5 July 16th 05 04:40 PM
Seneca V vs. Navajo operating costs Jarema Owning 1 February 12th 05 10:30 PM
Purchasing a Pressurised Navajo Vigo Owning 5 June 9th 04 07:04 PM
Navajo crash, CLW gatorcog Piloting 0 August 23rd 03 05:21 AM
FS: Piper Navajo Chieftain 350 Manual Mike Aviation Marketplace 0 August 7th 03 12:15 AM
