why high to low, look out below?
Old November 12th 05, 08:55 PM
jim rosinski
Default why high to low, look out below?
Peter Duniho wrote:
And forget all the stuff others have posted about temperature. That
does nothing but confuse the issue.
The issue is already confused. People like you who want to pretend it's not
only serve to confuse it even more.
"People like you" who have no lives outside of making annoying posts
that say nothing are the scourge of Usenet. To the permanent bit bucket
you go...
Forget "all the stuff others have posted about temperature" at your own
peril. It's every bit as important an altimeter error as that caused by
changes in pressure.
The original question was about "high to low, look out below".
Temperature effects are completely unnecessary in forming an explanation
for that adage. What credentials do you have to back up your
blathering? On second thought, I think you'd be doing us all a favor if
instead you just went away.
Jim Rosinski
Old November 12th 05, 09:01 PM
Rich Lemert
Peter Duniho wrote:
"jim rosinski" wrote in message
While temperature may play a role in altimeter "errors" I believe
it's extraneous to the discussion at hand. The phrase in question says
nothing about why the pressure is changing, only that it does. The
effect of this pressure change on altimeter readings can - and has
been - adequately explained without discussion of temperature.
We can always discuss temperature effects once the pressure effects
are understood. Trying to get someone to grasp two separate concepts at
the same time when it's not necessary does only serve to confuse the
student.
Old November 13th 05, 12:30 AM
Peter Duniho
"Rich Lemert" wrote in message
ink.net...
Why would you believe that? People can and do use that very same mnemonic
to remember the effect of temperature on the altimeter indication.
To pretend otherwise is silly. It happens, and so given that it happens, it
makes perfect sense to explain the error and why the phrase fits (albeit
imperfectly, AS I ALREADY POINTED OUT, before the post that claimed
temperature was irrelevant).
The phrase in question says nothing about why the pressure is changing,
The phrase in question says nothing about pressure at all. The word
pressure is not even used.
only that it does.
The only thing the phrase say that anything "does", is that the altimeter
reads too high in certain circumstances.
The
The effect of this temperature change on altimeter readings can - and has
been -adequately explained without discussion of temperature.
student.
As long as the exact same phrase gets used for two different concepts, you
are stuck teaching two different concepts at the same time.
Now, maybe that really means people ought to stop using the mnemonic. But
you and I have no control over it. Pretending that temperature is
irrelevant is dumb, and is likely to get someone killed.
Pete
Old November 13th 05, 12:35 AM
Peter Duniho
See what copy and paste will get you?
Obviously, that last word should be "pressure".
Old November 13th 05, 01:25 AM
Jim Macklin
IFR in mountainous areas requires 2,000 above obstacles with
5 miles of the intended route. Considering that an
altimeter setting may be from a location nearly 100 miles
away and the temperature may be very much below standard,
that 2,000 foot terrain clearance may be reduced to 0 by
temperature, pressure and venturi effects in the mountains.
Try the calculations on your flight computer for true
altitude. VFR and you should see the granite, but IFR or at
night, you depend on the altimeter.
Of course, now that you can get a GPS altitude that has non
of the errors, you can see the altitude errors on the
pressure altimeter.
Altimeters have other errors besides temperature and as a
purely mechanical device they can fail with no indication at
all. The electric altimeters in the high dollars airplanes
(King Airs and jets) use an air data computer that processes
the raw pressure data and sends the result to a display.
These will flag when there is an error, but the cheap
altimeter used in most general aviation piston airplanes has
no such warning. Thirty years ago one manufacturer decide
to save a few bucks in construction and used Teflon tape for
bearings in the housing. When this tape broke loose and
jammed the gears, the altimeter would just freeze. I once
had a student out in central Illinois doing hood work on a
MVFR day. He seemed to be doing a good job as we flew
around under a 1500-2000 foot overcast. When he took the
hood off, his first remark was "How did we get so low?"
Since I'd been watching in and outside, the slow loss of
altitude did not reach the alarm stage, we were below the
clouds and above the ground. But when he went under the
hood he had a picture of what it looked like and when the
hood came off it was very different and quickly.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
message ...
ink.net...
"errors" I believe
very same mnemonic
indication.
that it happens, it
phrase fits (albeit
that claimed
The word
| only that it does.
that the altimeter
| The
can - and has
temperature.
temperature.
pressure effects
confuse the
| student.
time.
the mnemonic. But
temperature is
| Pete
Old November 13th 05, 01:41 AM
jim rosinski
My apologies to the group for so immediately violating my own stated
rule to ignore this person's posts forever more. But I just can't sit
back and let him spew utter nonsense without challenge. Good GOD man,
when you see the phrase "high to low, look out below" in an aviation
book they mean high to low PRESSURE. They assume the reader has the
intellectual wherewithall to take it from context when they see the big
high and low pressure icons on the same page!
BTW, the moral of the whole "high to low (pressure), look out below"
thing is to make sure on a cross-country or IFR flight to get altimeter
setting updates regularly.
Jim Rosinski
Old November 12th 05, 11:30 PM
Andrew Sarangan
Increase in density does not mean an increase in pressure. This is
where your error is.
Old November 13th 05, 01:00 AM
jim rosinski
Actually it does if the air, or layer of air, you're talking about is
isothermal (constant temperature) or anything close to it. The ideal
gas law, to which the real atmosphere very nearly adheres, states:
pressure = density times temperature times a constant.
Imagine you're in freefall. Pressure goes up and density goes up. And
the above equation tells you by how much, assuming for the moment that
you have a barometer, an isothermal atmosphere, and a calculator during
the plunge!
All this is completely useless for understanding the "high to low, look
out below" rule.
Jim Rosinski
High Voltage Jim Rosinski Piloting 7 October 16th 04 10:48 PM
Viagra and the Mile High Club Cub Driver Piloting 17 May 28th 04 09:22 PM
FS2004: Ceilings/visibility too high ajohnson Simulators 2 March 15th 04 10:55 AM
High DPI pictures of clouds BoDEAN Piloting 2 March 5th 04 12:07 PM
AIM-54 Phoenix missile Sujay Vijayendra Military Aviation 89 November 3rd 03 09:47 PM
