![]() "Eric Greenwell" wrote in message ... Bill Daniels wrote: Lithium Ion rechargeables seem to have recently seen a 50% or so price drop. A 4-cell, 14.8V, 8AH with charger and mounting plate can be had for $169.99 (USD). Can you supply a URL? While I strongly discourage people from making up their own Li-ion battery packs for their glider due to potential safety problems, a _production_ battery pack with it's dedicated charger would likely alleviate most of the concerns I have about using a large Li-ion battery in a glider. I don't worry about the little ones in my PDA, cell phone, or camera. I just scanned a bunch of pages from a Google search. I'll find the one with the specifics. These are basically long endurance laptop batteries. What would be the advantage of this battery over the 12 volt, 7 to 9 amphour SLA for your application? Neither size nor weight seem important in a battery of only 8 amphours, whether SLA or Li-ion. That's a Nimbus you fly, right? It's about a 6 pound weight savings. (1 Lb vs 7 Lbs) for 7-8 AH. That allows the battery to be behind the panel with short wires instead of behind the seat with long wires. Total weight savings are not that important but the battery's effect on balance and weight of the 'non-flying' parts is. I've been running W&B's and 6 pounds is important. This is still too much for me given that a SLA with the same capacity is around $25 but the downward price trend is hopeful. Someone contemplating a transponder, electric T&B and other juice hungry gadgets in a $100,000+ glider might see Li-Ion as a possibility now. Unless it allows the pilot to mount significantly more capacity in the original battery box, eliminating the need to find a place to mount more batteries, I don't see any benefit. Saving a few pounds seems pointless in most gliders, even a SparrowHawk. You can get a lot more capacity for the same volume and weight. As for safety, the motorglider guys are flying around with GASOLINE, right? That burns too. Bill Daniels |
Bill Daniels wrote:
What would be the advantage of this battery over the 12 volt, 7 to 9 amphour SLA for your application? Neither size nor weight seem important in a battery of only 8 amphours, whether SLA or Li-ion. That's a Nimbus you fly, right? It's about a 6 pound weight savings. (1 Lb vs 7 Lbs) for 7-8 AH. That allows the battery to be behind the panel with short wires instead of behind the seat with long wires. Total weight savings are not that important but the battery's effect on balance and weight of the 'non-flying' parts is. I've been running W&B's and 6 pounds is important. This is an interesting idea. It might be an easy way to power a transponder with a separate battery, without the hassle and expense of mounting a 6 pound battery somewhere it won't become a projectile. The Becker and Microair transponders have max input voltages of 30 volts, so no problem with 16.2 full charge voltage that's an issue for you. Encoders, like the ACK 30 I use, have similar values. It would mean using two different chargers, one for the Li-ion, one for the SLA, but that seems like a minor inconvenience. snip As for safety, the motorglider guys are flying around with GASOLINE, right? That burns too. Surprisingly, fire fed by the gasoline is a rare event in motorgliders (wire fires seem more common, along with burns from the canopy focusing the sun), and we continue to hurt ourselves in the usual ways glider pilots do. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
![]() "Eric Greenwell" wrote in message ... Bill Daniels wrote: Lithium Ion rechargeables seem to have recently seen a 50% or so price drop. A 4-cell, 14.8V, 8AH with charger and mounting plate can be had for $169.99 (USD). Can you supply a URL? While I strongly discourage people from making up their own Li-ion battery packs for their glider due to potential safety problems, a _production_ battery pack with it's dedicated charger would likely alleviate most of the concerns I have about using a large Li-ion battery in a glider. I don't worry about the little ones in my PDA, cell phone, or camera. Sometimes Froogle doesn't find the same things on successive searches. Here is an example of what I'm talking about. http://store.linkexpresspc.com/de16liprbafo.html Specifications: - Rating: 14.8V == DOUBLE CAPACITY 8800mAH (8.8AH) - Capacity : 132 WHR 16CELL $149.00 @ LinkExpressPC As for the warning videos and scary stories in the press, most people know these are merely efforts at proactive legal defense. (Lawyer for the plaintiff: "You sold these CHEMICAL FIRE BOMBS for use in CHILDREN'S TOY AIRPLANES?) (Lawyer for the defense: "Gee, yer honor, we warned 'em - see our scary video on the web.) It's an effort to immunize the manufacturer against 'frivolous' lawsuits. In fact, most technically savvy users know Li-Ion batteries are plenty safe if a few simple precautions are used. Mainly, use the correct charger in a fire safe location. Once charged, don't damage the case or short them. That's pretty good advice for any rechargeable battery no matter the chemistry. Bill Daniels |
Bill Daniels wrote:
Can you supply a URL? While I strongly discourage people from making up their own Li-ion battery packs for their glider due to potential safety problems, a _production_ battery pack with it's dedicated charger would likely alleviate most of the concerns I have about using a large Li-ion battery in a glider. I don't worry about the little ones in my PDA, cell phone, or camera. Sometimes Froogle doesn't find the same things on successive searches. Here is an example of what I'm talking about. http://store.linkexpresspc.com/de16liprbafo.html Specifications: - Rating: 14.8V == DOUBLE CAPACITY 8800mAH (8.8AH) - Capacity : 132 WHR 16CELL $149.00 @ LinkExpressPC I think this style would be much more suitable than a laptop battery: http://tinyurl.com/8zl55 Essentially the same ratings and price ($169 with charger), it has a standard output connector and a easier to mount shape. Google "external laptop battery" without the quotes. There is a wide range of price and power in this style. Something like this might be very practical for gliders, though I still want to know more about maximum ambient temperature and altitude allowed, and built-in safety features. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
![]() "Eric Greenwell" wrote in message ... Bill Daniels wrote: Can you supply a URL? While I strongly discourage people from making up their own Li-ion battery packs for their glider due to potential safety problems, a _production_ battery pack with it's dedicated charger would likely alleviate most of the concerns I have about using a large Li-ion battery in a glider. I don't worry about the little ones in my PDA, cell phone, or camera. Sometimes Froogle doesn't find the same things on successive searches. Here is an example of what I'm talking about. http://store.linkexpresspc.com/de16liprbafo.html Specifications: - Rating: 14.8V == DOUBLE CAPACITY 8800mAH (8.8AH) - Capacity : 132 WHR 16CELL $149.00 @ LinkExpressPC I think this style would be much more suitable than a laptop battery: http://tinyurl.com/8zl55 Essentially the same ratings and price ($169 with charger), it has a standard output connector and a easier to mount shape. Google "external laptop battery" without the quotes. There is a wide range of price and power in this style. Something like this might be very practical for gliders, though I still want to know more about maximum ambient temperature and altitude allowed, and built-in safety features. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA Yep, that's a better example. I think I saw that one on my earlier search but I couldn't find it the second time. There are quite a few of these on the market from a variety of vendors. The price is falling as they become a commodity. I think I could build a box for an internal laptop battery that would have contacts and a restraining latch. Just push the battery in until it clicks - no wires to futz with. Many laptops and gadgets sit on car seats in the sun and then get turned on. I have certainly done that but I don't know of any problems. I remember trying to boot a laptop I left on a car seat in Phoenix. It was so hot I couldn't hold it. After it booted, I couldn't read the LCD until the A/C cooled it down. Generically, Li-ion polymer batteries are tolerant of temperature extremes. The laptop batteries are regarded as 'smart' batteries in that they have processor chips inside that manage them. I think they may even limit the voltage to 14.8V. Bill Daniels |
Bill Daniels wrote:
I think I could build a box for an internal laptop battery that would have contacts and a restraining latch. Just push the battery in until it clicks - no wires to futz with. Perhaps a suitable solution for a knowledgeable person like yourself, but the typical laptop battery has a half-dozen contacts, so I wouldn't know which ones need connecting. I don't even know if the charger can be connected directly to battery, or if it goes through some other circuitry in the laptop. These issues don't exist with external laptop batteries, and their approximately 4" x 6" x 1" shape would make mounting them easier than the oddball shapes the laptops use. We already futz with one cable out a lead-acid glider battery - not a problem there. Many laptops and gadgets sit on car seats in the sun and then get turned on. I have certainly done that but I don't know of any problems. I remember trying to boot a laptop I left on a car seat in Phoenix. It was so hot I couldn't hold it. After it booted, I couldn't read the LCD until the A/C cooled it down. Generically, Li-ion polymer batteries are tolerant of temperature extremes. The laptop batteries are regarded as 'smart' batteries in that they have processor chips inside that manage them. I don't know how smart a laptop battery is, and I suspect some of the smarts are inside the laptop; for example, in the situation you describe, the laptop likely cut back it's processor speed and LCD brightness to reduce the power taken from the battery, protecting it from overheating. The battery used by itself might not be able to protect itself properly, because it's designed to be used only in the laptop. The external batteries might offer this protection, since they are intended to be used by themselves. I don't know if that's true, but I'd like to know before I started using one in a glider. I think they may even limit the voltage to 14.8V. A number of the external batteries can be set to different output voltages, which might be useful, but I don't know how they do that. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
A Lear Jet caught fire when a battery overheated and burned a hole in the
fuselage. This was caused because the new battery had such a tremendous current capacity. No, it was not a lithium ion, it was a nicad. That was about 35 years ago and the FAA issued cautions about the problems created by nicad batteries. I have also read about people being seriously burned when the nicad batteries they were carrying in their pocket shorted out on their keys, burning a hole in their pants and in one case leaving an imprint on the thigh of the victim. Any device that stores or creates energy is a potential hazard. What is required is that the user understand the potential hazards and minimize the risks. We drive around in cars full of gasoline, which may burn or explode in an accident, on tires that may suddenly deflate because of an object striking them. And, we are 4 feet away from a vehicle coming the opposite direction going 50 miles per hour. Sometimes where we draw the line between what is safe and what is not is rather arbitrary. Colin |
COLIN LAMB wrote:
.../.. I have also read about people being seriously burned when the nicad batteries they were carrying in their pocket shorted out on their keys, burning a hole in their pants and in one case leaving an imprint on the thigh of the victim. There was story in Model Aviation a few years ago about just that happening to an RC model flier. He put his NiCd glow-starter in the same pocket as his keys without capping it. Unfortunately his pocket also held half a dozen .45 cartridges from the morning's target practice.... -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
At 02:12 15 November 2005, Marc Ramsey wrote:
Bill Daniels wrote: I'm not suggesting lash-ups. A discrete 'brick' or 'slab' battery pack with matched charger is what I am talking about. Well, that is what you would do, but you are more careful than most... I've read the warnings from the model airplane sites. The warnings seem to all be about charging. I never charge a battery in the glider. Look more carefully, there are also warnings about explosions resulting from short circuits. I've seen a similar video where they just shorted the terminals together, and let the cell sit for a minute or two... There is a cure for that, a fuse. Regs in the UK require a fuse within a very short distance from the batttery, 2.5 ins from memory and I use 3 amp. Not a lot of opportunity for a short of any sustained time with that arrangement if the terminals are insulated as they should be. A standard lead acid battery will do very spectacular things if shorted out as well, I remember (many many years ago when young) trying to light a cigarette using a strand of winch wire across the winch battery terminals, worked fine until the top blew off the battery. It would seem that even then smoking could damage your health. PS You needed a good pair of gloves :-). I think we might have invented the automobile cigar lighter without knowing it. |
![]() "Don Johnstone" wrote in message ... At 02:12 15 November 2005, Marc Ramsey wrote: There is a cure for that, a fuse. True, but there is no fuse that can protect from an internal short circuit. Any type of battery can (at least rarely) do this. I have seen both lead acid and NIMH batteries burn up this way. (It the case of the NIMH it was an irate firefighter whose portable radio had nearly caught fire.) Naturally, the more energy in the cell, the more heat, smoke, and (possibly) flames you can expect. Lithium batteries have a very high energy density and the innards love to burn, so internal shorts are a particular concern with them. How great is the danger as a practical matter? That is the true question here! Vaughn |
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
60 years from Battle of Tali-Ihantala June-July 1944 - which decidedthe fate of Finland | Jukka O. Kauppinen | Military Aviation | 1 | June 29th 04 03:00 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 06:32 PM |
