"Tarver Engineering" wrote in message ... "Gig Giacona" wrote in message ... "Tarver Engineering" wrote in message ... So, Ron, wht did you mean by this post, other than what it clearly says? "Ron Natalie" wrote in message m... "Tarver Engineering" wrote in message ... No, homebuilts are type certificated under Part 21 as Experimental. No John, they are not. They do not have type certificates. What they have are individual airworthiness certificates issued under 21.191.There is no type certification of experimentals. You had best get with the "experimental aircraft association" on that one, Ron. ![]() With the exception of paragraph (b) which has nothing to do with amateur-built aircraft where the hell is the word TYPE anywhere in 21.191? Non-sequitur. JTarver You are without a doubt the most obnoxious poster in the rec.aviation.* groups. I that is saying something. You keep telling Ron that amateur-built aircraft have a type certificate. Yet NO where in the FAR are the words "amateur-built" and "type" ever in the same paragraph. What the regs clearly show is that amateur-built aircraft are flown under an experimental AIRWORTHINESS certificate. To when your side of the argument all you have to do is cut and paste the damn reg you think you are quoting. |
| Thread Tools | |
| Display Modes | |
| FAR 91.171 interpretation | James L. Freeman | Instrument Flight Rules | 8 | September 21st 03 07:00 AM |
