![]() Jose wrote: And if the stack has an audio panel worthy of the name, the opposite transceiver's audio is cut off during transmit to prevent an unholy squeal coming down the audio line of the receiver that is still operating. You sure? I've operated split (on different frequencies), and not been cut off when the other pilot was transmitting. Does the audio panel know what frequencies each radio is using? And I have the newest Garmin audio panel. The pilot and copliot can each talk on different frequencies at the same time. |
Newps wrote:
And I have the newest Garmin audio panel. The pilot and copliot can each talk on different frequencies at the same time. We call that *intercom*... If you have radios on different frequencies and are able to talk to each other through them, you need new radios because those old ones have really poor filtering/alignment... |
![]() "Darrel Toepfer" wrote in message . .. Newps wrote: And I have the newest Garmin audio panel. The pilot and copliot can each talk on different frequencies at the same time. We call that *intercom*... If you have radios on different frequencies and are able to talk to each other through them, you need new radios because those old ones have really poor filtering/alignment... He did not say the pilot and co-pilot could talk to each other on different frequencies. What he meant is the pilot could be talking to Tower while the co-pilot could be talking to Unicom (or some other combination ![]() Allen |
We call that *intercom*... If you have radios on different frequencies and are able to talk to each other through them, you need new radios because those old ones have really poor filtering/alignment... "can each talk" is different from "talk to each other" Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
![]() Darrel Toepfer wrote: Newps wrote: And I have the newest Garmin audio panel. The pilot and copliot can each talk on different frequencies at the same time. We call that *intercom*... If you have radios on different frequencies and are able to talk to each other through them, you need new radios because those old ones have really poor filtering/alignment... That's not what I said or meant to say. The Garmin audio panel allows the two pilots to each talk on a separate radio, on different freq's, at the same time. |
On Tue, 22 Nov 2005 10:16:15 -0700, Newps wrote
in :: The Garmin audio panel allows the two pilots to each talk on a separate radio, on different freq's, at the same time. That's not what it says he http://www.garmin.com/products/gma347/ The GMA 347 audio panel builds upon the successful attributes of the GMA 340 while adding benefits such as automatic squelch, digital clearance recorder, and a full-duplex telephone interface. The GMA 347's automatic squelch option makes the entire audio experience quieter and clearer. Since there are some occasions when pilots wouldn’t want an automatic squelch—such as high-noise environments—the GMA 347 also retains the manual squelch adjustment feature. Garmin has also added three more unmuted, unswitched inputs with individual volume control. The GMA 347’s automatic digital clearance recorder helps pilots manage the demands of a busy cockpit. The unit continuously captures the last two and one half minutes of audio switched through the panel. If a pilot misses a frequency change or clearance, he or she can replay the necessary information by simply pressing the “play” button. In addition, the GMA 347 has a full-duplex telephone interface with intercom isolation and disable capability. This feature allows private telephone calls by the pilot or copilot, or multi-party calls with crew and/or passengers. Pilots will also appreciate the integration of the G1000’s “configuration module” into the GMA 347. If the audio panel is ever removed, all of the pilot’s preferred settings are automatically loaded into the unit. Garmin part number: 010-00275-01 |
Larry Dighera wrote:
On Tue, 22 Nov 2005 10:16:15 -0700, Newps wrote in :: The Garmin audio panel allows the two pilots to each talk on a separate radio, on different freq's, at the same time. That's not what it says he http://www.garmin.com/products/gma347/ (...) The so-called "split" function exists on the KMA28, made by PS Engineering, as well as of course the PS Engineering branded audio panels with built-in intercoms. I've a KMA28, and on a few occasions I've been talking to ATC on the pilot side, while a friend would be calling an FBO on their ARINC frequency to arrange for a car, or whatever. For some reason, I can't connect to Garmin's website right now, so I can't see if the 340/347 have this split function or not. -jav |
That's not what it says he http://www.garmin.com/products/gma347/ The GMA 347 audio panel builds upon the successful attributes of the GMA 340 snip The GMA340 certainly has this feature. I use it all the time in my Bonanza. If the 347 is built upon the successful attributes of the GMA340, then Garmin most likely included this feature in that unit as well. -- Peter |
![]() Larry Dighera wrote: On Tue, 22 Nov 2005 10:16:15 -0700, Newps wrote in :: The Garmin audio panel allows the two pilots to each talk on a separate radio, on different freq's, at the same time. That's not what it says he http://www.garmin.com/products/gma347/ I have the 340. |
![]() "Larry Dighera" wrote in message ... On Tue, 22 Nov 2005 10:16:15 -0700, Newps wrote in :: The Garmin audio panel allows the two pilots to each talk on a separate radio, on different freq's, at the same time. That's not what it says he http://www.garmin.com/products/gma347/ The GMA 347 audio panel builds upon the successful attributes of the GMA 340 while adding benefits such as automatic squelch, digital clearance recorder, and a full-duplex telephone interface. Split Com - Copilot may transmit and receive on COM2 while Pilot transmits and receives on COM1 from the GMA 340 spec which the GMA 347 "builds upon" Allen |
RIP Mike Valentine | Mal | Soaring | 0 | December 11th 04 08:27 PM |
Changes in Instrument Proficiency Check Requirements | Richard Kaplan | Instrument Flight Rules | 71 | June 10th 04 08:02 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
Radio silence, Market Garden and death at Arnhem | ArtKramr | Military Aviation | 4 | February 12th 04 12:05 AM |
Use of hand-held GPS on FAA check ride | Barry | Instrument Flight Rules | 1 | August 9th 03 09:25 PM |
