ADF Required
Old February 22nd 04, 01:58 PM
"Peter R." wrote:
He told me what you stated above. If you ask ATC for alternate missed
approach instructions, you can "legally" fly the approach without an
ADF.
Your examiner is wrong. ATC cannot waive Part 97. But, you can substitute an
IFR-certified GPS for the ADF because Flight Standards has issued a national policy
letter permitting that.
And, most IAPs do not have a non-radar alternate missed approach proceddure. It's
either the published missed or radar vectors.
Old February 23rd 04, 03:32 AM
Ted Timmons
If I understood your response correctly, the approach may not be flown
without having either an ADF or an IFR-certified GPS.
It seems to me like very poor planning to design approaches such as the two
I previously mentioned (Rochester, NY KROC ILS RWY 4 or VOR RWY 4). A
pilot could have a day (1,000 foot ceiling) with an extremely low
probability of needing to execute the missed and not be able to "legally"
fly the approach if the ADF was inop.
Has anyone tried to get an approach modified, e.g., get a missed approach
procedure changed to eliminate the ADF requirement?
wrote in message ...
national policy
proceddure. It's
Old February 23rd 04, 11:46 PM
Richard Hertz
"Ted Timmons" wrote in message
two
How is that poor design? That may be all the facilities they had. Years
ago ADF was more prevalent. There are approaches that are not legal even
when the airport's weather is VFR - does that make sense to you either? (3
miles, 1000 ft)
Try it. tell us how it works out.
national policy
proceddure. It's
Old February 25th 04, 01:51 PM
They don't do that unless other facilities or traffic flow won't permit use of
a VOR facility or fix. Having said that, with IFR GPS it is no big deal any
longer.
Old February 22nd 04, 01:20 AM
Newps
Ted Timmons wrote:
When an approach specifies ADF REQUIRED (as in Rochester, NY KROC ILS RWY 4
or VOR RWY 4) is there any legal way to fly the approach without an ADF?
It appears to me that the only reason for the ADF requirement is for the
missed approach. Can the approach be flown leagally by requesting alternate
missed approach instructions that don't require and ADF?
No reason you can't use a GPS for this approach.
Old February 22nd 04, 05:34 AM
Andrew Sarangan
"Ted Timmons" wrote in message . ..
I am not sure how you decided that the ADF is required only for the
missed approach. The AVN NDB serves as the IAF and the holding fix. It
is required in order to fly the feeder route from FAULT intersection.
AVN is also the fix from which the MSA and the 10-NM approach area are
determined. Unless I am looking at the wrong approach chart, it seems
to me that you need the ADF in order to fly this approach.
Old February 22nd 04, 04:06 PM
C J Campbell
Actually, failure of the ADF was one the reasons I installed a Garmin 430 in
my plane. The GPS can substitute for an ADF or DME.
Old February 25th 04, 06:36 AM
Scott
missed approach.
Only with an approach approved GPS that has the paperwork for
installation in the plane. (In which case, you can use it for that
approach, but your alternate still has to be filed such that you can use
non-GPS methods.)
Now that's a great question. I suppose ATC can override anything really.
But then, what do you do in case of lost comm? You can't fly the
published missed. If you're an AOPA member, call up there help line.
They know or can find out just about anything about this stuff.
Scott
www.privacytactics.com -- Protect Your Personal Information Assets
Old February 25th 04, 01:53 PM
Not anything. They cannot construct a non-radar missed approach procedure, nor
can they waive notes on an approach chart (those are regulatory). But, where
they have radar they can give you a vectored missed approach, but only once
you're talking to them.
Old February 27th 04, 06:37 PM
Steven P. McNicoll
procedure, nor can they waive notes on an approach chart (those
are regulatory).
They're regulatory? Please cite the regulation.
The need for equipment requirement notes is determined by evaluating all
SIAP segments, including the missed approach procedure. A few years ago
many of these notes began appearing on procedures where the entire approach
could be flown without use of the specified equipment. Apparently some
approach designers did not have a good understanding of how approaches are
flown.
Which aircraft certification is required for R&D? Netgeek Home Built 5 November 23rd 04 05:59 AM
required eqipment for ifr Mark Instrument Flight Rules 23 December 19th 03 02:22 PM
required readback on clearance [email protected] Instrument Flight Rules 15 September 17th 03 04:33 PM
Why is ADF required on ILS approach? Rich Raine Instrument Flight Rules 27 August 1st 03 05:14 PM
Radio license required? Marty Ross Instrument Flight Rules 10 July 17th 03 09:58 PM
