"Larry Dighera" wrote in message
... [...] I find your qualification of "pretty much anywhere that there *isn't* Class G airspace" to lack any mention of the necessity for the Special VFR clearance to be flown within the CONTROLLED AIRSPACE SURFACE AREA OF AN AIRPORT. Why? Pick a point in space that is "near the surface" (for the purposes of this discussion, let's say 500', but anything lower than the floor of the basic Class E airspace would be fine) that is NOT Class G airspace. The odds that you can obtain a Special VFR clearance in that airspace are excellent, because near the surface, the usual reason for the airspace NOT being Class G airspace is that it's the controlled airspace around an airport. So I must be misinterpreting what you wrote, or FAR §91.157. Yup, you must be. [...] Ah. So implicit in being less than 700' AGL while being in Class B, C, D or E controlled airspace, is the notion that you are within an airport's surface area of controlled airspace, for it is the only controlled airspace charted to the surface. Yes. If you understand this, I don't see why you still don't understand what I wrote. [...] In decades of flying, I had never considered the fact that controlled airspace ONLY reaches the surface at airport surface areas be they controlled airports or not. Why not? And why is that relevant here? [...] If "91.157 grants them this right elsewhere (with a Special VFR clearance)," it must be possible to obtain Special VFR clearance at (for example in southern California): Paso Robles (PRB) an uncontrolled airport Blythe (BLH) an uncontrolled airport Needles (EED) an uncontrolled airport Desert Resorts Regional (TRM) an uncontrolled airport Imperial Co (IPL) an uncontrolled airport Within the Class E surface extensions of many controlled airports Is that actually the case? Yes. A tower at the airport in question is not required for a Special VFR clearance. Pete |
On Fri, 2 Dec 2005 10:25:28 -0800, "Peter Duniho"
wrote in :: Yes. A tower at the airport in question is not required for a Special VFR clearance. I had no idea that was the case, but the AIM confirms it: http://www.faa.gov/ATpubs/AIM/Chap4/aim0404.html#4-4-5 b. When a control tower is located within the Class B, Class C, or Class D surface area, requests for clearances should be to the tower. In a Class E surface area, a clearance may be obtained from the nearest tower, FSS, or center. |
... Yes. A tower at the airport in question is not required for a Special VFR clearance. I had no idea that was the case, but the AIM confirms it: Yes, I know. ![]() For what it's worth, it helps to remember that a Special VFR clearance is in essence an IFR clearance for VFR traffic (even though, obviously, it's not literally an IFR clearance at all). That is, the Special VFR clearance has the same effect for the VFR aircraft than an IFR approach clearance has for an IFR aircraft: it dedicates the controlled airspace protecting the approach and airport to that one aircraft. So, just as one can obtain an IFR approach clearance for an uncontrolled airport, one can obtain a Special VFR clearance for an uncontrolled airport, and for the same reasons. Pete |
On Fri, 2 Dec 2005 17:11:37 -0800, "Peter Duniho"
wrote in :: So, just as one can obtain an IFR approach clearance for an uncontrolled airport, one can obtain a Special VFR clearance for an uncontrolled airport, and for the same reasons. That's not quite how I understand it. Isn't a Special VFR clearance only available in controlled airspace? IFR approach/departure clearances are available in Class G airspace as well, right |
Class is uncontrolled, no clearances are available. You can
depart an airport that is in Class G and begin an IFR when you enter controlled airspace...a clearance will read something like "...enter controlled airspace heading 240 degrees..." In the "old days" it was easy to describe, special VFR was only available in what was called a control zone, which was the controlled airspace around an airport from the ground up to 14,500. Now, SVFR is, in theory, available in any airspace except Class A and such Class B as are listed in Appendix D, but it is still tied to an airport based lateral boundary. You can't fly a cross-country under SVFR unless the two airports are "touching" their designated airspace. The purpose of SVFR is to get VFR only aircraft (pilots) in and out of airports when the local weather is good enough for basic VFR once you get to the Class G or from the Class G to the airport. -- James H. Macklin ATP,CFI,A&P "Larry Dighera" wrote in message ... | On Fri, 2 Dec 2005 17:11:37 -0800, "Peter Duniho" | wrote in | :: | | | So, just as one can obtain an IFR approach clearance for an uncontrolled | airport, one can obtain a Special VFR clearance for an uncontrolled airport, | and for the same reasons. | | That's not quite how I understand it. Isn't a Special VFR clearance | only available in controlled airspace? | | IFR approach/departure clearances are available in Class G airspace as | well, right |
... That's not quite how I understand it. Isn't a Special VFR clearance only available in controlled airspace? IFR approach/departure clearances are available in Class G airspace as well, right No, not really. You can certainly fly IFR through Class G airspace, and it may even involve a clearance as you transition into or out of controlled airspace. But IFR flight in Class G doesn't require an ATC clearance, nor could one be granted (since by definition, ATC doesn't control the uncontrolled Class G airspace). Pete |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Lockheed wins Presidential helicopter contract | Tiger | Naval Aviation | 0 | January 29th 05 05:24 AM |
aero-domains for helicopter pilots and helicopter companies | secura | Rotorcraft | 0 | June 26th 04 07:33 AM |
