Eunometic schrieb:
Eunometic schrieb: It does apply for the PA200 Tornado. The APU is not operable in-flight, if you loose both engines and the one-shot battery is down you have to get out of that thing... I didn't think Tornado was fully FBW? The PA200 Tornado is fully FBW with a mechanical linkage backup system... Benjamin |
![]() Benjamin Gawert wrote: Eunometic schrieb: Eunometic schrieb: It does apply for the PA200 Tornado. The APU is not operable in-flight, if you loose both engines and the one-shot battery is down you have to get out of that thing... I didn't think Tornado was fully FBW? The PA200 Tornado is fully FBW with a mechanical linkage backup system... Benjamin Then why does it need a thermal backup battery to remain airborn? |
Eunometic schrieb:
The PA200 Tornado is fully FBW with a mechanical linkage backup system... Benjamin Then why does it need a thermal backup battery to remain airborn? Because besides power for certain important instruments and the radio the EPS battery also powers an electric motor that powers a hydraulic pump. "Mechanical linkage" does not mean that the stick is connected to pushrods and levers that move the control surfaces (which would be silly on a fighter/bomber aircraft with up to ~55000 pounds weight). When in so-called "mech mode" the stick is connected to several hydraulic valves that control the hydraulic actuators. So you need hydraulics pressure, and in cases of double engine out this hydraulic pressure comes from an electric pump that powered by the EPS battery. In normal operation the potentiometers connected to the stick submit stick position data to the flight control system (CSAS and SPILS) which calculate the necessary control surface deflection and control the corresponding actuators. The mechanical linkage is inactive (in emergencies the stick gets linked to the mechanical controls through a honeycomb block which gets squeezed by the stick movement applied by the panicing pilot ;-) This applies to the GR versions (bomber), I don't know if the F versions are somewhat different. Benjamin |
![]() "Eunometic" wrote in message oups.com... Benjamin Gawert wrote: Eunometic schrieb: Eunometic schrieb: It does apply for the PA200 Tornado. The APU is not operable in-flight, if you loose both engines and the one-shot battery is down you have to get out of that thing... I didn't think Tornado was fully FBW? The PA200 Tornado is fully FBW with a mechanical linkage backup system... Benjamin Then why does it need a thermal backup battery to remain airborn? The One Shot Battery is there to provide electrical power to a Fuel pump (or in combination with a Hyd pump). The engines also need electrical power to keep their systems running - without electrics, the engines will "run away" - Very bad thing if you're not near a nice big bit of tarmac...... |
Alternatively, I've always wondered if one could not keep a special
reserve tank for the APU. When the engines quit, the APU automatically starts to power the controls. Would such a system be safe and would it be certifiable? Would it weigh less than the existing system? In a lot of airplanes the APUs (resp. their intakes and exhausts) are mounted in a way that they can't be used inflight. Besides that, if there still is fuel in the tanks it's better served for keeping the engine alive than just the APU... I know that most Boeing and Airbus planes can run the APU in the air. I'm just asking if 30 minutes of fuel for the APU might not weigh less than the ram air turbine. The APU would clearly produce more power than the ram air turbine. If the choice was between flight controls powered for 30 minutes or the main engines powered for another one minite, I would take the former. I must assume that there are some very smart aircraft designers who have already considered and rejected my idea. But WHY was this? Is it a fundementally bad idea, is it a good idea that's against the rules of certification, or what? -Charles Talleyrand |
Charles Talleyrand wrote:
Alternatively, I've always wondered if one could not keep a special reserve tank for the APU. When the engines quit, the APU automatically starts to power the controls. Would such a system be safe and would it be certifiable? Would it weigh less than the existing system? In a lot of airplanes the APUs (resp. their intakes and exhausts) are mounted in a way that they can't be used inflight. Besides that, if there still is fuel in the tanks it's better served for keeping the engine alive than just the APU... I know that most Boeing and Airbus planes can run the APU in the air. I'm just asking if 30 minutes of fuel for the APU might not weigh less than the ram air turbine. The APU would clearly produce more power than the ram air turbine. If the choice was between flight controls powered for 30 minutes or the main engines powered for another one minite, I would take the former. I must assume that there are some very smart aircraft designers who have already considered and rejected my idea. But WHY was this? Is it a fundementally bad idea, is it a good idea that's against the rules of certification, or what? -Charles Talleyrand For one thing you'd be hard pressed to get 30 minutes of glide time from any airliner. Dan, U.S. Air Force, retired |
![]() "Dan, U.S. Air Force, retired" wrote in message news:yDepf.66209$sg5.26836@dukeread12... Charles Talleyrand wrote: For one thing you'd be hard pressed to get 30 minutes of glide time from any airliner. Dan, U.S. Air Force, retired The Air Transat Airbus that ran out of fuel glided for 20 minutes to get to the Azores Keith |
![]() "Keith W" wrote in message ... "Dan, U.S. Air Force, retired" wrote in message news:yDepf.66209$sg5.26836@dukeread12... Charles Talleyrand wrote: For one thing you'd be hard pressed to get 30 minutes of glide time from any airliner. Dan, U.S. Air Force, retired The Air Transat Airbus that ran out of fuel glided for 20 minutes to get to the Azores Keith And there is the 1983 (?86) story of the "Gimli Glider." An Air Canada B-767 that ran out of fuel and landed on an X-ed out runway in Canada that was, at the time, in use by sports car racers. See: http://www.silhouet.com/motorsport/tracks/gimli.html for a great photo. They talk about the RATS but I couldn't find any remarks about elapsed glide time in this story. For giggles, read the post script story about the mechanics who went to rescue the airplane. |
"Casey Wilson" N2310D @ gmail.com wrote in
news:qokpf.21228$eI5.17594@trnddc05: "Keith W" wrote in message ... "Dan, U.S. Air Force, retired" wrote in message news:yDepf.66209$sg5.26836@dukeread12... Charles Talleyrand wrote: For one thing you'd be hard pressed to get 30 minutes of glide time from any airliner. Dan, U.S. Air Force, retired The Air Transat Airbus that ran out of fuel glided for 20 minutes to get to the Azores Keith And there is the 1983 (?86) story of the "Gimli Glider." An Air Canada B-767 that ran out of fuel and landed on an X-ed out runway in Canada that was, at the time, in use by sports car racers. See: http://www.silhouet.com/motorsport/tracks/gimli.html for a great photo. They talk about the RATS but I couldn't find any remarks about elapsed glide time in this story. For giggles, read the post script story about the mechanics who went to rescue the airplane. HAHAHAHAA...too funny....I'd quote it but don't want to be a spoiler. I also liked the part about what was heard on the voice recorder after the EICAS went "bong"..."Oh F___". Damned good flying. I would have officially christend that plane the "Gimli Glider" and painted it's nose with it. I wonder if it's still in service today. That plane's got good karma. Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html Sed quis custodiet ipsos Custodes? Like censorship and not getting support help? Switch to Supernews! They won't even answer questions through your ISP! |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Thunderstorm - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 11:05 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
