Heavy landing 777
Old December 16th 05, 06:19 PM posted to rec.aviation.piloting
Default Heavy landing 777
jfp wrote:
also if you pass the terminal exit point i believe it would be a push back, (very expensive) as no more exit points exist
Notwithstanding that any jet can go backwards with the use of the
reversers, why a push-back beyond the exit point - isn't the apron
there wide enough to accommodate a 180-degree turn?
Ramapriya
Old December 16th 05, 11:13 PM posted to rec.aviation.piloting
That's never wise with low engines. The book may even have a minimum
forward speed for reversers.
Ramapriya
Old December 16th 05, 10:11 PM posted to rec.aviation.piloting
"jfp" wrote in message
Hi a recent landing at Antigua in a 777 was very hard, and the pilot
applied
the brakes really heavily, probaly in my assumption, because of the short
runway and a slight overshoot of touch down point, also if you pass the
no more exit points exist, my point is does a very heavy landing strain
777 aircraft unduly especially the undercarriage
If you are referring to VC Byrd, you are wrong. It is plenty long enough and
does have a turning point at the end. As for the undercarriage, it will
survive very hard landings. One of my buds has recorded in excess of 2 g's
with the only damage being to his ego. The monocoque fuselage will buckle
first. Search the web and you'll come across some pictures of a B-767 in the
Dominican Republic 2 years ago exhibiting such damage.
D.
Old December 17th 05, 03:02 PM posted to rec.aviation.piloting
jfp wrote:
Hi a recent landing at Antigua in a 777 was very hard, and the pilot applied
no more exit points exist, my point is does a very heavy landing strain the
777 aircraft unduly especially the undercarriage regards Frank
If you can find a copy of the TV documentary 21st Century Jet on the
building and certification of the 777, you'll see that it's designed
to take much more severe braking than what you witnessed.
Old December 17th 05, 05:10 PM posted to rec.aviation.piloting
Ron,
I watched the same. As I recall, the heavy braking test also resulted
in some wheel fires.
-Robert
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
