another main problem I had was him letting another plane get so close in IMC that
he had to give me a traffic alert. what happened to this seperation I was suppose to be getting. Teacherjh wrote: freezing level was 7000-8000 [...] I start my decent, between some clouds Between how much cloud? This could be a serious pilot error, or not a big deal so here I am now down from my safe altitude above the clouds [...] I amnow stuck and I needed my clearence or I would be in trouble. ... which is why I ask, above. because he was too busy. noone was talking except me. On that frequency. Controllers often work many frequencies, and do things besides talk on the radio. then he does not want me to do the ILS, he tells me to decend to 2700 ft and to be prepared for the visual. You can request the ILS. But if he's clearing you for a visual, then you can probably complete the visual. Not always though... I got a visual into DXR once, but was in some CB and needed a real approach. The controller asked what I wanted, so I took the Loc 8. and I didnt even tell you about the 1500 fpm downdraft or when my engine started losing power. OK controllers, admit it. You have secret radio control over the weather and the engine. Now if you could only control the hobbs meter for me too! Jose -- (for Email, make the obvious changes in my address) |
![]() Jeff wrote: another main problem I had was him letting another plane get so close in IMC that he had to give me a traffic alert. what happened to this seperation I was suppose to be getting. You pushed him and he probably tried to fit you in, which resulted in the traffic aleart. Have you ever visited the TRACON, plugged in, and asked about the handoff procedures from center to approach control for IFR arrivals? |
the traffic alert came about 20 minutes after the clearance.
you fishing to look for the controller to be 100% right which we all know is not always the case. wrote: Jeff wrote: another main problem I had was him letting another plane get so close in IMC that he had to give me a traffic alert. what happened to this seperation I was suppose to be getting. You pushed him and he probably tried to fit you in, which resulted in the traffic aleart. Have you ever visited the TRACON, plugged in, and asked about the handoff procedures from center to approach control for IFR arrivals? |
![]() "Teacherjh" wrote in message ... On that frequency. Controllers often work many frequencies, and do things besides talk on the radio. When controllers are working many frequencies they typically broadcast on all of them simultaneously. You won't hear other aircraft, but you will hear the controller. |
Steven P. McNicoll wrote:
"Teacherjh" wrote in message ... On that frequency. Controllers often work many frequencies, and do things besides talk on the radio. When controllers are working many frequencies they typically broadcast on all of them simultaneously. You won't hear other aircraft, but you will hear the controller. Is this true for all positions? I think our local controllers (sleepy old ELM) sometimes work tower and ground at the same time and you don't hear the ground communications on tower and vice versa. Matt |
![]() "Matthew S. Whiting" wrote in message ... Steven P. McNicoll wrote: "Teacherjh" wrote in message ... On that frequency. Controllers often work many frequencies, and do things besides talk on the radio. When controllers are working many frequencies they typically broadcast on all of them simultaneously. You won't hear other aircraft, but you will hear the controller. Is this true for all positions? I think our local controllers (sleepy old ELM) sometimes work tower and ground at the same time and you don't hear the ground communications on tower and vice versa. I don't know about in a tower cab, but when positions (ie-sectors) are combined within radar facilities, the frequencies (transmitters and receivers) are routed to whatever position gets the airspace. Thus, the controller can hear on all freq's assigned to his airspace, and only has to key his own mic to transmit. His transmissions are broadcast on all frequencies he is working even though other stations can only hear the voice traffic on their discrete freq. And I'm sure there could be non VSCS exceptions in the wide open spaces of ARTCC's like ZAN, ZLC, ZDV, but surely not in a tiny little piece of airspace that is a Tracon like Phoenix. (not saying they ain't busy, just that Tracons don't usually cover much territory....) Chip, ZTL |
In article , "Matthew S. Whiting"
writes: Is this true for all positions? I think our local controllers (sleepy old ELM) sometimes work tower and ground at the same time and you don't hear the ground communications on tower and vice versa. My experience when this would happen is that tower says "stay with me" or "stay this freq" instead of working me on a different freq. Chuck |
PaulaJay1 wrote:
In article , "Matthew S. Whiting" writes: Is this true for all positions? I think our local controllers (sleepy old ELM) sometimes work tower and ground at the same time and you don't hear the ground communications on tower and vice versa. My experience when this would happen is that tower says "stay with me" or "stay this freq" instead of working me on a different freq. Chuck That happens often on the way back in, but they've always used .9 for clearance delivery and taxi clearance outbound. Often when I arrived late at night I would get the stay with me instruction. However, I always call the ground frequency when heading out and have never been instructed to switch to tower for either my IFR or taxi clearance. Matt |
"cleared to ... when direct ..." | John Harper | Instrument Flight Rules | 21 | February 11th 04 04:00 PM |
Practical IFR Question (for centre controllers) | David Megginson | Instrument Flight Rules | 10 | December 4th 03 11:26 PM |
AOPA and ATC Privatization | Chip Jones | Instrument Flight Rules | 139 | November 12th 03 08:26 PM |
Follow up Alright, All You Dashing, Swaggering Bush Pilots | wmbjk | Home Built | 135 | September 8th 03 06:09 AM |
Riddle me this, pilots | Chip Jones | Instrument Flight Rules | 137 | August 30th 03 04:02 AM |
