Curious you would introduce "run a whole lot smoother" and "power pulses"
then, if you thought those issues weren't relevant. Very odd. Even stranger that those issues were the sum total of your rebuttal to his post Ya got me there Pete... nothing escapes your eagle-eyed gaze, eh? Not really sure where I was going with that. On reflection, Otis' post would suggest the higher power turbine conversion might have have an adverse effect on the old Mallard airframe, even though as you mentioned the STC should include reinforcing mounts, spars etc. to allow for the increased stress on the airframe. If anything, I'd guess the smoother running turbines should stress the airframe less than the throbbing & vibrating radials in spite of their higher power. (Disclaimer: I'm not an engineer, just an aero turbine analyst) |
Reports I saws this morning said that the NTSB said they
found a fatigue crack in the main spar, maybe the conversion was not done well or the maintenance was not though enough. I'll bet the fleet is grounded and they require immediate, "before further flight" NDT inspections of the wings, etc. -- James H. Macklin ATP,CFI,A&P -- Merry Christmas Have a Safe and Happy New Year Live Long and Prosper Jim Macklin "Ron Natalie" wrote in message m... | wrote: | I'm wondering if fitting turbine engines on the old airframes | didn't pull something loose in the wing/mount. | | Turbines run a whole lot smoother than the round Pratts that were on | originally. They don't have the power pulses that radial engines have. | | Not that they aren't subject to resonance issues. Remember the Electra? |
Jim Macklin wrote:
Reports I saws this morning said that the NTSB said they found a fatigue crack in the main spar, maybe the conversion was not done well or the maintenance was not though enough. I'll bet the fleet is grounded and they require immediate, "before further flight" NDT inspections of the wings, etc. Chalk's has voluntarily grounded thier Mallards and is performing an exhaustive test of the spars on one of them now. The NTSB rep voiced the opinion that age alone would not be sufficient to cause this failure; some additional stress would be required. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
That is probably true. The odds are that inspections will
not find any other similar cracks in the rest of the Chalk fleet, I imagine that every Mallard, worldwide, will be inspected soon. It is even possible that the crack that was found was recent, metallurgical tests will have to be done to know for sure. It is even possible that it was caused by some defect dating back 50 years and was not visible on the surface. I'm sure that it will be fixed, too bad, a wing coming off has only one recovery mode, parachute a la Cirrus. -- James H. Macklin ATP,CFI,A&P "George Patterson" wrote in message news:ixoqf.29956$CL.291@trnddc04... | Jim Macklin wrote: | Reports I saws this morning said that the NTSB said they | found a fatigue crack in the main spar, maybe the conversion | was not done well or the maintenance was not though enough. | I'll bet the fleet is grounded and they require immediate, | "before further flight" NDT inspections of the wings, etc. | | Chalk's has voluntarily grounded thier Mallards and is performing an exhaustive | test of the spars on one of them now. The NTSB rep voiced the opinion that age | alone would not be sufficient to cause this failure; some additional stress | would be required. | | George Patterson | Coffee is only a way of stealing time that should by rights belong to | your slightly older self. |
George Patterson wrote:
Jim Macklin wrote: Reports I saws this morning said that the NTSB said they found a fatigue crack in the main spar, maybe the conversion was not done well or the maintenance was not though enough. I'll bet the fleet is grounded and they require immediate, "before further flight" NDT inspections of the wings, etc. Chalk's has voluntarily grounded thier Mallards and is performing an exhaustive test of the spars on one of them now. The NTSB rep voiced the opinion that age alone would not be sufficient to cause this failure; some additional stress would be required. A pretty irresponsible statement for an NTSB person. Fatigue can cause a stressed member to fail at a very low load, much less than even flight loads. I seem to remember a picture of a Buff whose wing had failed on the ground. It has been years and I don't remember the details, but it seems like it was due to something fairly innocous such as refueling. I believe fatigue was determined to be the root cause. Matt |
![]() Matt Center point refueling didn't shut off when tank was full and Ka-boom went the wing. Big John `````````````````````````````````````````````````` ``````````````````````` On Thu, 22 Dec 2005 03:14:07 GMT, Matt Whiting wrote: George Patterson wrote: Jim Macklin wrote: Reports I saws this morning said that the NTSB said they found a fatigue crack in the main spar, maybe the conversion was not done well or the maintenance was not though enough. I'll bet the fleet is grounded and they require immediate, "before further flight" NDT inspections of the wings, etc. Chalk's has voluntarily grounded thier Mallards and is performing an exhaustive test of the spars on one of them now. The NTSB rep voiced the opinion that age alone would not be sufficient to cause this failure; some additional stress would be required. A pretty irresponsible statement for an NTSB person. Fatigue can cause a stressed member to fail at a very low load, much less than even flight loads. I seem to remember a picture of a Buff whose wing had failed on the ground. It has been years and I don't remember the details, but it seems like it was due to something fairly innocous such as refueling. I believe fatigue was determined to be the root cause. Matt |
![]() "George Patterson" wrote in message news:ixoqf.29956$CL.291@trnddc04... Jim Macklin wrote: Reports I saws this morning said that the NTSB said they found a fatigue crack in the main spar, maybe the conversion was not done well or the maintenance was not though enough. I'll bet the fleet is grounded and they require immediate, "before further flight" NDT inspections of the wings, etc. Chalk's has voluntarily grounded thier Mallards and is performing an exhaustive test of the spars on one of them now. The NTSB rep voiced the opinion that age alone would not be sufficient to cause this failure; some additional stress would be required. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. How frequently were these airplanes operated off of water? Wouldn't water takeoff's and landings typically be more stressful (because you're getting bashed around by waves) than landing on a nice smooth runway? I suspect it would be even worse if you dug in a wing float or hit a wave with a wing float "at speed". KB |
"Kyle Boatright" wrote in message
How frequently were these airplanes operated off of water? Wouldn't water takeoff's and landings typically be more stressful (because you're getting bashed around by waves) than landing on a nice smooth runway? I suspect it would be even worse if you dug in a wing float or hit a wave with a wing float "at speed". The fleet operates off the water every day. Chalks opts to land on the water at stations were runways are available. It's part of the experience for the passengers. Seaplane operations are much more demanding than landplane operations, particularly in sal****er environs. These airplanes were built tough, but they were designed when finite element analysis was in it's infancy. What the press hasn't mentioned, because they don't know, is that seaplane operations have more incidents than similar landbased operations. It comes with the territory. Chalks has had numerous hard landings were floats have been knocked off. A Chalk's Mallard hit a bridge piling with a wingtip during take-off from Paradise Island a few years back. It happens much more often at Chalks than at other South Florida operators because of the water environment. That's just the way it is. Grumman seaplanes are tough, but there has been additional stress applied to Chalk's spars. I suspect that the NTSB rep's opinion may be correct. Additionally, there are areas of the spar that are difficult to inspect visually. Even with a proper inspection revealing no cracks, work hardening of the metal may have been reaching catastrophic limits. How does one inspect metal spars for work hardening if there are no cracks? How long does it take for a crack to propagate to catastrophic lengths? The recent ADs for the T-34 and T-6 fleets, and the Aero-Commander 500 fleet before that (the spar cracks AD, not the dissimilar metal corrosion AD), should have instigated more research into aging aircraft and work hardening of the spars. Perhaps this tragedy will be the catalyst. D. |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Seaplane Rating Add-On and Seaplane Rental | Peter Bauer | Piloting | 10 | May 29th 05 11:53 AM |
American Lake SPB Closing | C J Campbell | Piloting | 23 | December 27th 04 03:26 PM |
Copalis Beach State Airport threatened? | C J Campbell | Piloting | 1 | April 14th 04 10:04 PM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
