Seaplane down off Miami Beach....
Old December 22nd 05, 03:09 AM posted to rec.aviation.piloting
Default Seaplane down off Miami Beach....
That is probably true. The odds are that inspections will
not find any other similar cracks in the rest of the Chalk
fleet, I imagine that every Mallard, worldwide, will be
inspected soon. It is even possible that the crack that was
found was recent, metallurgical tests will have to be done
to know for sure. It is even possible that it was caused by
some defect dating back 50 years and was not visible on the
surface.
I'm sure that it will be fixed, too bad, a wing coming off
has only one recovery mode, parachute a la Cirrus.
James H. Macklin
ATP,CFI,A&P
"George Patterson" wrote in message
news:ixoqf.29956$CL.291@trnddc04...
| Jim Macklin wrote:
| Reports I saws this morning said that the NTSB said they
| found a fatigue crack in the main spar, maybe the
conversion
| was not done well or the maintenance was not though
enough.
| I'll bet the fleet is grounded and they require
immediate,
| "before further flight" NDT inspections of the wings,
etc.
| Chalk's has voluntarily grounded thier Mallards and is
performing an exhaustive
| test of the spars on one of them now. The NTSB rep voiced
the opinion that age
| alone would not be sufficient to cause this failure; some
additional stress
| would be required.
| George Patterson
| Coffee is only a way of stealing time that should by
rights belong to
| your slightly older self.
Old December 22nd 05, 03:14 AM posted to rec.aviation.piloting
George Patterson wrote:
Jim Macklin wrote:
Reports I saws this morning said that the NTSB said they found a
fatigue crack in the main spar, maybe the conversion was not done well
or the maintenance was not though enough. I'll bet the fleet is
grounded and they require immediate, "before further flight" NDT
inspections of the wings, etc.
Chalk's has voluntarily grounded thier Mallards and is performing an
exhaustive test of the spars on one of them now. The NTSB rep voiced the
opinion that age alone would not be sufficient to cause this failure;
some additional stress would be required.
A pretty irresponsible statement for an NTSB person. Fatigue can cause
a stressed member to fail at a very low load, much less than even flight
loads. I seem to remember a picture of a Buff whose wing had failed on
the ground. It has been years and I don't remember the details, but it
seems like it was due to something fairly innocous such as refueling. I
believe fatigue was determined to be the root cause.
Matt
Old December 22nd 05, 10:13 PM posted to rec.aviation.piloting
Matt
Center point refueling didn't shut off when tank was full and Ka-boom
went the wing.
Big John
On Thu, 22 Dec 2005 03:14:07 GMT, Matt Whiting
Matt
Old December 22nd 05, 01:27 PM posted to rec.aviation.piloting
Jim Macklin wrote:
Reports I saws this morning said that the NTSB said they found a fatigue
crack in the main spar, maybe the conversion was not done well or the
maintenance was not though enough. I'll bet the fleet is grounded and
they require immediate, "before further flight" NDT inspections of the
wings, etc.
opinion that age alone would not be sufficient to cause this failure; some
George Patterson
Coffee is only a way of stealing time that should by rights belong to
How frequently were these airplanes operated off of water? Wouldn't water
takeoff's and landings typically be more stressful (because you're getting
bashed around by waves) than landing on a nice smooth runway? I suspect it
would be even worse if you dug in a wing float or hit a wave with a wing
float "at speed".
KB
Old December 22nd 05, 03:45 PM posted to rec.aviation.piloting
"Kyle Boatright" wrote in message
it
float "at speed".
The fleet operates off the water every day. Chalks opts to land on the water
at stations were runways are available. It's part of the experience for the
passengers. Seaplane operations are much more demanding than landplane
operations, particularly in sal****er environs. These airplanes were built
tough, but they were designed when finite element analysis was in it's
infancy.
What the press hasn't mentioned, because they don't know, is that seaplane
operations have more incidents than similar landbased operations. It comes
with the territory. Chalks has had numerous hard landings were floats have
been knocked off. A Chalk's Mallard hit a bridge piling with a wingtip
during take-off from Paradise Island a few years back. It happens much more
often at Chalks than at other South Florida operators because of the water
environment. That's just the way it is. Grumman seaplanes are tough, but
there has been additional stress applied to Chalk's spars. I suspect that
the NTSB rep's opinion may be correct. Additionally, there are areas of the
spar that are difficult to inspect visually. Even with a proper inspection
revealing no cracks, work hardening of the metal may have been reaching
catastrophic limits. How does one inspect metal spars for work hardening if
there are no cracks? How long does it take for a crack to propagate to
catastrophic lengths?
The recent ADs for the T-34 and T-6 fleets, and the Aero-Commander 500 fleet
before that (the spar cracks AD, not the dissimilar metal corrosion AD),
should have instigated more research into aging aircraft and work hardening
of the spars. Perhaps this tragedy will be the catalyst.
D.
Seaplane Rating Add-On and Seaplane Rental Peter Bauer Piloting 10 May 29th 05 11:53 AM
American Lake SPB Closing C J Campbell Piloting 23 December 27th 04 03:26 PM
Copalis Beach State Airport threatened? C J Campbell Piloting 1 April 14th 04 10:04 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
