Bob Moore wrote:
Matt Whiting wrote Except the Electra wasn't a jet. Maybe you are thinking of the Comet. Well...the Electras that I flew certainly had "jet" engines. Even burned kerosene. :-) Gee, Bob, you should know the difference between a turbine engine used as a propjet from one used as a pure jet. :-) Matt |
Matt Whiting wrote
Gee, Bob, you should know the difference between a turbine engine used as a propjet from one used as a pure jet. :-) Hey! Eastern Airlines called them "Prop Jets". By the definitions posted here, there are no "Jet" airliners currently flying, since they are all "Turbo Fans". Right??? :-) Bob Moore |
Bob Moore wrote:
Matt Whiting wrote Gee, Bob, you should know the difference between a turbine engine used as a propjet from one used as a pure jet. :-) Hey! Eastern Airlines called them "Prop Jets". By the definitions posted here, there are no "Jet" airliners currently flying, since they are all "Turbo Fans". Right??? :-) The still derive significant thrust from the exhaust jet, but I'll grant you that it is getting much grayer as the bypass ratios keep increasing. :-) Then again, if it was black and white, what would we have to argue about here? Things would get dull in a hurry. Matt |
Bob Moore wrote:
Matt Whiting wrote Gee, Bob, you should know the difference between a turbine engine used as a propjet from one used as a pure jet. :-) Hey! Eastern Airlines called them "Prop Jets". The airline marketing departments purposely blurred the definitions in the 1950s. American called Electras "Jet Powered Flagships". Braniff called them "Jet Power Electras". I seem to remember one airline declaring that they had an all-jet fleet when they phased out their last piston aircraft, but still flew turboprops. |
Bob Moore wrote:
Matt Whiting wrote Except the Electra wasn't a jet. Maybe you are thinking of the Comet. Well...the Electras that I flew certainly had "jet" engines. Even burned kerosene. :-) Bob Moore The ones I flew had jet turbine engines but they were geared to propellors which makes a difference. They are generally referred to as turboprops whereas the term jet normally refers to a jet engine without external propellors. But the difference is decreasing since most high-bypass jet engines now have internal rotors which produce more than half the thrust using propellor type action but within the engine frame. That air doesn't even go through the combutions chambers, it bypasses them, hence the term high-bypass. But you knew that, Bob, I just mentioned it for those who didn't. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - |
Hi I'm lonely, and I want my mommy...
Matt Whiting wrote: Stubby wrote: Way back, I believe the first jet passenger jet was the Lockheed Electra. The plane mysteriously fell out of the air and very thorough search for a cause was instituted. In the end, again if I remember correctly, the conclusion was that the wing spar failed from fatigue because the wing was nutating, a slight circular motion due to gyroscopic effects. Maybe that's the same thing caused the FL seaplane crash. Except the Electra wasn't a jet. Maybe you are thinking of the Comet. The Electra did, however, have a string of catastrophic early failures, which were eventually traced to metal fatigue in the wing or fuselage structure caused by a vibration or oscillation that occurred in flight and was associated with the design of the plane; and the Comet had a series of catastrophic early failures which were eventually traced to metal fatigue and crack grown around the windows occurring after multiple pressurization and depressurization cycles. Both were prime examples of the learning process associated with civil aviation and aviation technology. Am I recalling this correctly? |
Are you thinking the English Comet? It had several inflight mysterious
breakups before it was discovered that the square windows created stress fractures after several pressurization cycles. I believe it was the first pax airline. |
![]() "Stubby" wrote in message . .. Way back, I believe the first jet passenger jet was the Lockheed Electra. The first jet airliner was the de Havilland Comet. The Lockheed Electra you're referring to was a turboprop. |
Stubby wrote:
Way back, I believe the first jet passenger jet was the Lockheed Electra. The plane mysteriously fell out of the air and very thorough search for a cause was instituted. Sounds like you're confusing it with the DeHaviland Comet. The cause was eventually determined to be the rapid formation of stress cracks around the corners of the rectangular cabin windows. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
