Somehow, I am comforted to know that my commercial transatlantic flight
captain with 15,000 hours and a copilot still uses a checklist before landing, even though everything is normal procedure for him or her. |
Sure, and in my 2000 hours in F-4s my pilot and I always used a
checklist before landing - but it was for items that needed to be setup or checked to ensure a safe landing - not basic airmanship issues! If I recall correctly, the pre-landing checks for the F-4 was Gear - down, Flaps - full down, Hydraulic pressures - good, Warning lights - check, Anti-skid - On. Nothing about speed to fly based on fuel weight, wind, pattern, use of the speed brakes to slow down, etc. - these are part of the landing procedure and did not need a checklist. There was a Descent checklist that was accomplished during the initial descent to take care of the administrative cleanup of the cockpit - such things as fuel on internal tanks, cabin pressure, altimeter settings, etc. that was meant to ensure the jet was configured for an approach. Most of the glider "landing checklists" fit better in this category - and as such should be accomplished BEFORE entering the pattern. Used this way, they make sense. I just don't think they are useful or appropriate while in the pattern - by then it's too late or even counterproductive! In my case, I use Wind Water Wheels when I'm about 4 miles out, and have to decide on the pattern direction, speed to fly based on winds and ballast, whether to drop ballast or not, etc. Also which way the gear handle works, if flying a new ship (a low downwind is NOT the time to be guessing which way is down!). It's my cue to put my brain in Land mode, and clean up the cockpit prior to setting up for the landing evolution. In the pattern, I concentrate on lookout and conditions, and configure the ship on downwind - gear, flaps as required by wind, spoilers. And fly the pattern as needed. I do not go through a checklist at that point - it's too distracting. And I recheck the Gear when I roll out on final. Flaps are really optional in my ship, and spoilers are obvious! Works for me so far - YMMV, of course. Kirk 66 |
There is no 100% guaranteed method of avoiding gear
up landings, but a pre-landing checklist and warning devices help. You don't hear of many commercial jet transports landing gear up! When I learnt to fly I was taught a 'downwind' check (UFSTALL). My so far one and only gear up landing occured on a marginal scrape back to the airfield, when I was so low that I had to join the circuit straight onto base leg. No downwind leg equalled no checklist and me forgetting to lower the wheel. Fortunately as in Martin's case no damage done, as I made a decent landing on smooth grass. Derek Copeland ------------------------- At 20:36 05 January 2006, Martin Gregorie wrote: That's important too. My only wheel-up was because I'd forgotten to raise the wheel but did remember to move the lever during landing preparations.... ..... fortunately it was a good greaser landing in a Discus I. Thanks to the CG hook being proud and the grass smooth I didn't even scratch the gel coat. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
Reference FAA Glider Flying Handbook (FAA-H-8083-13) published in
2003... page 7-34 FAA recommended checklist for the traffic pattern FUSTALL F - Flaps (on some gliders you may not want to change the flaps throughout the pattern due to high forces) U - Undercarriage S - Speeds (based upon wind and sink expected) T - Trim Set A - Airbrakes / Spoilers (I have had occurrences where one popped all the way out when first opened.. I'd like to know that on downwind! (ASW-17 .. Yes the hotelier fittings were pinned!!), also on the 2-33 - if the handle goes all the way back against the stop the brake will not work, etc..) L - Lookout (Safe landing area.. otherwise land somewhere else) L - Land I have over 4000 hrs in gliders of all kinds, probably 1/2 of that instructing around the country, and am a test pilot for many years. I still mentally use a checklist, especially after long (10hr+) flights. The object is to train the student in preparation for other ratings as well. A checklist does not prevent one from using judgement, rather .. it is a tool. By the way I flew F-4s (all models) for 20 yrs USAF. E. Douglas Whitehead wrote: WWUFSTAALLL W-WIND W-WATER U-UNDERCARRAGE F-FLAPS S-SPEED T-TRIM A-AIRBRAKES A-ANNOUNCE L-LOOK L-LOOK L-LOOK I trim the A/B speed and from base to final I may reduce the A/B and keep the nose down particularly if it is turbulant. I trim the Landing Flap speed with the nose down. Doug Whitehead (EDW) |
At 15:24 06 January 2006, Jettester wrote:
Reference FAA Glider Flying Handbook (FAA-H-8083-13) published in 2003... page 7-34 FAA recommended checklist for the traffic pattern FUSTALL F - Flaps (on some gliders you may not want to change the flaps throughout the pattern due to high forces) U - Undercarriage S - Speeds (based upon wind and sink expected) T - Trim Set A - Airbrakes / Spoilers (I have had occurrences where one popped all the way out when first opened.. I'd like to know that on downwind! (ASW-17 .. Yes the hotelier fittings were pinned!!), also on the 2-33 - if the handle goes all the way back against the stop the brake will not work, etc..) L - Lookout (Safe landing area.. otherwise land somewhere else) L - Land I have over 4000 hrs in gliders of all kinds, probably 1/2 of that instructing around the country, and am a test pilot for many years. I still mentally use a checklist, especially after long (10hr+) flights. The object is to train the student in preparation for other ratings as well. A checklist does not prevent one from using judgement, rather .. it is a tool. By the way I flew F-4s (all models) for 20 yrs USAF. I like your FUSTALL. One point about the spoilers, once you crack em open, don't lock em again or you are right back where you started. The good thing about aviation is, we haven't left one up there yet. I guess the last 'L' makes it official. You will land. The first bragger has no chance. How about 21,000+ hrs in everything from J3s H13s to B747-400s? Let's here it from all those airline types. Yeh,Yeh Big deal. Chuck |
I guess they will all serve their purpose, but I can
never understand checklists that include things that you will do anyway. Speed - surely we don't need a check to fly at the correct speed. Trim - don't we all adjust the trim when we change attitude/speed. Lookout and land - you're not telling us you wouldn't lookout and check the landing area and actually land without having it in a checklist? Checklists should, IMO, only include things that you physically need to do prior to landing. Waterballast should be in there, you're more likely to need a reminder to dump it than you are a reminder to do the things you should always be doing anyway; like looking out, flying at an appropriate speed and trimming. At 15:24 06 January 2006, Jettester wrote: FAA recommended checklist for the traffic pattern FUSTALL F - Flaps (on some gliders you may not want to change the flaps throughout the pattern due to high forces) U - Undercarriage S - Speeds (based upon wind and sink expected) T - Trim Set A - Airbrakes / Spoilers (I have had occurrences where one popped all the way out when first opened.. I'd like to know that on downwind! (ASW-17 .. Yes the hotelier fittings were pinned!!), also on the 2-33 - if the handle goes all the way back against the stop the brake will not work, etc..) L - Lookout (Safe landing area.. otherwise land somewhere else) L - Land |
![]() "Mark Dickson" wrote in message ... I guess they will all serve their purpose, but I can never understand checklists that include things that you will do anyway. Speed - surely we don't need a check to fly at the correct speed. Trim - don't we all adjust the trim when we change attitude/speed. Lookout and land - you're not telling us you wouldn't lookout and check the landing area and actually land without having it in a checklist? Checklists should, IMO, only include things that you physically need to do prior to landing. Waterballast should be in there, you're more likely to need a reminder to dump it than you are a reminder to do the things you should always be doing anyway; like looking out, flying at an appropriate speed and trimming. The above makes sense; but while we are at it, I feel that the landing checklist should not include things that the glider does not need. When we teach a new student a generic landing check such as USTALL or some such and there is no handle in the glider marked "Undercarrage", then what are we really teaching the student? Answer: we are teaching the student to mouth "Undercarrage" and then do nothing! Given the law of primacy, we are setting them up for a future wheels-up accident. For this reason, the landing checklist should be specific to the glider and probably posted in the cockpit. Vaughn At 15:24 06 January 2006, Jettester wrote: FAA recommended checklist for the traffic pattern FUSTALL F - Flaps (on some gliders you may not want to change the flaps throughout the pattern due to high forces) U - Undercarriage S - Speeds (based upon wind and sink expected) T - Trim Set A - Airbrakes / Spoilers (I have had occurrences where one popped all the way out when first opened.. I'd like to know that on downwind! (ASW-17 .. Yes the hotelier fittings were pinned!!), also on the 2-33 - if the handle goes all the way back against the stop the brake will not work, etc..) L - Lookout (Safe landing area.. otherwise land somewhere else) L - Land |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
