We're getting old, folks...
Old January 3rd 06, 04:19 AM posted to rec.aviation.piloting
Default We're getting old, folks...
Jose wrote:
And this differs from regular soldering how?
Yeah, I see the smilie, but I'll answer anyway. With a regular iron or soldering
gun, you can get a bead of solder on the tip. Just get the joint hot, and the
bead flows right into it. The tip on these things doesn't get hot enough for that.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old January 3rd 06, 05:19 AM posted to rec.aviation.piloting
soldering gun, you can get a bead of solder on the tip. Just get the joint
hot, and the bead flows right into it. The tip on these things doesn't get
Plus the fact that the dot of solder on the tip will deform around the
object you are working on to aid in rapid and efficient heat transfer.
It also seems like the cold solder gun depends on having the object you are
soldering having about the correct resistance to make the appropriate amount
of heat.
Thanks for the review, all. I thought there would be major problems, and it
looks like I was right. I'll stick with my soldering gun/iron/butane torch.
Jim in NC
Old January 3rd 06, 01:57 AM posted to rec.aviation.piloting
They offer a heavy duty unit now and there are several
different tips available, at comparatively high price. But
it is very handy when you need to solder a wire splice and
can't bring the work to the bench. If you're trying to
solder very light wires, back them up with a wooden stick, a
clean popsicle stick or buy some at a hobby shop.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"George Patterson" wrote in message
news:yLkuf.16244$yW1.321@trnddc05...
| Morgans wrote:
| Anyone have one, or seen one in action?
| Ok, just tried it out. Here's how they work. The tip is
actually two electrodes.
| When you touch the tip to the work, the work makes the
electrical contact, and
| it heats up like a light bulb filament. The tip doesn't
heat up much, but the
| work does. I tried to tin some 26 gauge stranded copper
wire, and it brought the
| flux to a boil much more rapidly than a hot soldering
pencil iron does.
| Here's the problem. You have to keep both electrodes in
contact with the work.
| In my case, this proved to be impossible; the wire was
just too flexible. I can
| see that there might also be problems heating up both
pieces when soldering two
| items together. Failure to get both pieces hot results in
what's called a "cold
| solder joint."
| There's a little light on top that tells you when contact
is being made. You
| really have to keep this light in sight. The tip has only
one flat surface, and
| the only way it works is to press this surface against the
work. Fortunately,
| the tip can be inserted in the iron in either of two
directions, so it shouldn't
| be much of a problem.
| Anyway. Imagine. There you are under your panel trying to
solder a wire to a
| lug. You hold the wire firmly in place with your left hand
and manipulate the
| soldering iron into position with your right hand. Wiggle
things around to keep
| the little red light on. When the joint gets hot, you
apply the solder with your
| third hand.
| Don't have a third hand? Then maybe this thing isn't for
you.
| George Patterson
rights belong to
Old January 3rd 06, 05:30 AM posted to rec.aviation.piloting
"Morgans" wrote in message
Then they need to get those new "cool" soldering irons, they advertise on
TV all of the time.
Jim in NC
Yes, a co-worker's son gave him one of these irons for Christmas in 2004.
He gave it to me to tryout. Yes, I could get it to solder, but getting a
good joint was very difficult. Plus, since the tips are made of carbon, the
iron leaves small carbon particles in the joint. Not good. Also since the
unit actually passes current through the wires to be soldered, it is quite
possible to get small wires too hot. All told, I'll take my transformer
operated, bench Weller, thank you...even if I have to run an extension cord
for off-bench use.
John Severyn
KLVK
Don't forget to stop by your hospital & donate some blood folks. Flyingmonk Piloting 30 September 10th 05 03:52 AM
Lucky folks David Lesher Owning 9 August 5th 05 02:11 PM
Attention P4M-1Q folks JJ McIntyre Naval Aviation 0 June 4th 04 09:51 PM
Thanks for your help, folks! Jay Honeck Piloting 2 July 16th 03 05:32 PM
